Old 10-06-2010, 02:31 PM   #1
spinx2005
Member#: 166276
1991 panda gsx
monster
Default What grit sandpaper?
I have a clear coat on my headlight. It's starting to peal
and I want to take it off and re clear them. So what
grit sandpaper did I use and do I wet sand?
spinx2005 is offline   Reply With Quote
Old 10-06-2010, 02:40 PM   #2
wrxBRAH
Member#: 256841
2004 FXT
I used the 3M kit. It came with 400, 600 and 1200grit..
wrxBRAH is offline   Reply With Quote
Old 10-06-2010, 03:15 PM   #3
nairbmik
Member#: 220259
09 2.5i
SSM
Start with something low, then move your way up. Maybe 600 first then 1000
nairbmik is offline   Reply With Quote
Old 10-06-2010, 03:28 PM   #4
wakeboard_dude5
Member#: 213051
2004 WRX Wagon
600, 800, 1000, 1500, 2000, followed by polish and wax. or get the 3m kit, i've found the kit to be easiest
wakeboard_dude5 is offline   Reply With Quote
Old 10-06-2010, 03:54 PM   #5
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
i used myheadlight.com kit
just make sure to take your time!
blakkboxer is offline   Reply With Quote
Old 10-06-2010, 07:23 PM   #6
spinx2005
Member#: 166276
1991 panda gsx
monster
well i already had brought that meguairs kit. I knew that was a mistake because it didnt come with any sandpaper to take the clear coat off.
well il just buy the sandpaper.
and last do i wet sand?
Old 10-07-2010, 12:55 AM   #7
Chasey
Member#: 242109
2004 WRX Wagon
Yeah wetsand, all the kits that come with sandpaper always have "wetsand lubricant" with them, its basically scented water lol. I went as high as 2000 grit on mine, then use a plastic polish which will basically be a paste wiith super fine abrasive thingies in it and work that really well, then make sure you seal it with something, i just use wax but i notice i have to wax it alot to keep it up. Some kits actually come with sealing wipes to, not sure exactly what they are though.
Chasey is offline   Reply With Quote
Rear Wiper Rusted/Sandpaper grit? Falkonite Newbies & FAQs 2 07-14-2009 01:39 PM
What Grit? Suby666 Tire & Wheel 3 03-19-2009 11:12 AM
sanding sideskirts, what grits to use Gso2k Interior & Exterior Modification 3 07-13-2008 11:15 PM
what GRIT??? e-diggity Interior & Exterior Modification 8 07-03-2007 10:24 AM
Sanding down brake rotor deposits: What grit of sandpaper should i use? edkwon Brakes, Steering & Suspension 1 04-15-2003 01:23 PM
