Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 10-06-2010, 08:02 PM   #1
04wrxwag
Member#: 194889
Default 04 wrx coil install on 98 Legacy motor
I got everything adapted to use a JDM 98 Legacy 2.0 motor in my 04 Subaru (it look 10 months) except the coils. I'm sure someone has done this before or knows what I'm dealing with. The 98 coils have two wires, and the 04 wires have three wires, as if there is a trigger in addition to power and ground, and there is a transistor on the coil pack to do the switching. I'm looking for suggestions. The simple solution is to extend the plug tip by about an inch and use the 04 coils, which will just leave a gap around the coil for dirt and water to get into the area around the plug, but should work electrically. Any advise?
04wrxwag is offline   Reply With Quote
Old 10-11-2010, 10:34 AM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
http://forums.nasioc.com/forums/show....php?t=1192028
how did you get around the different crank pickups?
Old 11-05-2010, 12:36 AM   #3
04wrxwag
Member#: 194889
Default crank pick up
I used the newer harness, flywheel, sensors, cam gears, intake, etc. on the older long block...intending to install it this weekend. Still have a few unknowns.
Stock WRX exhaust on 98 Legacy? ethantudor Normally Aspirated Powertrain 3 11-17-2009 05:40 PM
04 STI suspension on 98 Legacy L wagon ? IllNastyImpreza Legacy Forum 19 07-11-2008 09:02 PM
98 legacy motor 2.5 dohc 13 b lover MWSOC Private Classifieds 6 08-13-2007 06:20 PM
98 Legacy motor 13 b lover MWSOC Private Classifieds 4 08-04-2007 11:11 AM
A Floating IPOD install in 98 Legacy ashwinearl Legacy Forum 4 03-14-2005 01:12 AM
