Old 10-06-2010, 08:51 PM   #1
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
Default leaking somwhere with pics...
So i was checking our family beater and I think something is leaking
I have to check it again tomorrow when its brighter out. But from the pictures u think its the power steering?
lionken07 is offline   Reply With Quote
Old 10-06-2010, 09:10 PM   #2
cmiovino
Member#: 134005
2004 WRX Premium
Your power steering looks like it's definitly leaking. I doubt it would be oil if it's that high up in the engine bay.
Old 10-06-2010, 11:35 PM   #3
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Oil pressure sensors can leak and spray oil around in that area too.
PhilSine is offline   Reply With Quote
Old 10-07-2010, 05:29 PM   #4
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
It looks like it might not be the power steering fluid. I just check it again and it's at the full mark. hmmm....
Old 10-07-2010, 06:22 PM   #5
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
is any of the leaking fluid fresh? Wipe you finger in it and feel and smell it. should be able to tell the difference between engine oil and any other fluid... it will smell slightly burnt if it has more than a cpl thousand miles on it and shouldn't have any orange or green tint to it if you wipe it on a sheet of white paper. power steering will usually have an orange/red tint unless its very old.
If observations are inconclusive, the best thing to do it wash the engine with a degreaser for engines/motors and rinse it well with a hose minimizing how much water you get on the ignition bits. Once its clean, regular observation should reveal the source of the leak.
Old 10-07-2010, 07:09 PM   #6
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
I used a paper towel and they look like black powder like stuff. Checked Engine oil also it's full as well. I'm totally lost...
Old 10-08-2010, 01:05 PM   #7
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Well, clean it all off and start from scratch. Now that you know where to inspect, do it often and see where the leak is coming from.
Old 10-08-2010, 05:27 PM   #8
LHMTECH
Member#: 260239
Ya very likely power steering pump is leaking, not uncommon at all. And that is traditional how they leak onto the block below the pump.
LHMTECH is offline   Reply With Quote
Yet another Dash Leak -- with Pics! wagonovsky Service & Maintenance 4 01-18-2006 09:44 AM
Oil leak questions w/pics methinkadoo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-20-2005 11:10 PM
some fluid leaking probs w/pics homurcules Normally Aspirated Powertrain 41 09-11-2005 01:33 AM
Coolent leak.With pics!!!! wrxtuner02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-26-2003 07:20 PM
AutoWeek leaked the MY02 pics early macrac General Forum Archive 15 08-16-2000 12:50 AM
