Old 10-06-2010, 09:32 PM   #1
Malaka628
Member#: 167745
2007 WRX TR
Crystal Grey Metallic
Default Need some recommendations
I had a compression test the other day after seeing a lot of white smoke come out of my exhaust and I either blew the head gasket or cracked a ring.
Power Mods
Blouch TD05 20g 8cm^2
Turbo XS 4" Downpipe
P & L 3" Race Catback
P & L High Flow Intake (Powder Coated Red)
P & L 38mm EWG Kit (Modified Turbo XS Up-pipe with Tial Wastegate)
P & L Front Mount Intercooler (Piping Powder Coated Red with Black Core)
Tial BOV
Samco Turbo Inlet
Cobb Access Port
T.G.V. Delete
HOA 3 Port Boost Control Selenoid
Deatschwerks 1000cc Injectors
Walbro 255lph Fuel Pump
Car had made 357 whp and 350 wtq on 19 psi.
Since I will be pulling the motor to fix this problem I want to buy parts to make it more reliable. What part do you guys recommend with keeping the pricing pretty reasonable? the most I want to do with this build is push this turbo close to its max
Thanks, Greg
Malaka628 is offline   Reply With Quote
Old 10-06-2010, 11:30 PM   #2
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
If your going to pull it might as well get some forged beef in there.
Some decent pistons and rods. Eagle rods and any piston of your choice really.
Not much else is needed beyond that other then the usual new water and oil pumps, gaskets, and bearings.
project_skyline is offline   Reply With Quote
Old 10-07-2010, 08:06 PM   #3
Malaka628
Member#: 167745
2007 WRX TR
Do I need to do anything with the heads?
Old 10-08-2010, 10:58 AM   #4
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
If there is no damage to them its not necessary but if you really want to you could have them cleaned, decked, and get a good valve job.
Need some recommendations for video editing software TimStevens Off-Topic 64 05-12-2011 10:34 AM
need some recommendations Dfence410 Water/Methanol Injection, Nitrous & Intercooler Cooling 1 10-28-2008 12:15 PM
I need some recommendations please White_Rex Canada Region Private Classifieds 0 04-26-2006 10:06 AM
Need some recommendations on paint EtoS Interior & Exterior Modification 0 04-06-2006 12:31 AM
OT Cigar Aficionados: need some recommendations gongzero Off-Topic 32 08-23-2004 03:52 PM
Message Board Statistics All times are GMT -4. The time now is 02:24 PM.
