Old 10-07-2010, 12:11 AM   #1
choleaoum
Member#: 255484
2010 EVO
Default Wastegate Solenoid Delete?
Hey how's it going, it seems that the previous owner deleted the hoses that connected to the wastegate solenoid, what are the symptoms or problems or even REASON why he would do that?
choleaoum is offline   Reply With Quote
Old 10-07-2010, 01:04 AM   #2
Corinator
Member#: 211974
2004 WRX STi PTE6466
2002 Sentra SE-R Spec V
It would just cause the turbo to run at wastegate spring pressure. What type of turbo is it? EWG or internal? If it is an external gate, it is pretty common to just get a like 25psi wastegate spring and run no solenoid or boost controller in general. I tend to see evo owners do that a lot with 30/35r turbos.
Corinator is offline   Reply With Quote
Old 10-07-2010, 01:53 AM   #3
choleaoum
Member#: 255484
2010 EVO
Great what a relief, I'm honestly not sure at all but I bought the car like this.. it's the stock TD04 turbo what looks like the stock wastegate as well.
Old 10-07-2010, 02:37 AM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Chances are good that he wasn't actually running it that way. For example he may have been running it with an MBC or aftermarket BCS that he kept when he sold the car.
Is the compressor nipple just hooked up up to the actuator? That's actually a pretty safe setup. It leaves you with low boost, so it costs you power, but it's not going to cause any damage.
Old 10-07-2010, 02:51 AM   #5
choleaoum
Member#: 255484
2010 EVO
Yeah it is, sick I'm not to skimpy about power right now just want my car running great. This is my first subaru so I don't know where the hell anything goes but I know how everything works lol.
Old 10-07-2010, 04:47 AM   #6
Corinator
Member#: 211974
Well with the stock TD04 the wastegate spring should be 7psi iirc and I believe a stock wrx runs 11psi on the factory tune. So you are getting robbed of some power, but like NSFW said, it won't hurt anything. In the future if you get an exhaust, it would be smart to get a grimmspeed boost control solenoid and get it tuned to stage 2. That way you would get more boost (like 17psi, tune dependent) and the boost control solenoid would make your car spool the turbo faster too. So it is basically a win win situation.
Old 10-07-2010, 12:09 PM   #7
choleaoum
Member#: 255484
2010 EVO
I have a straight pipe exhaust lol and a short ram intake. I should buy that grimspeed boost control solenoid huh, I've heard real good things about there products.
Old 10-07-2010, 01:45 PM   #8
Corinator
Member#: 211974
Yeah I personally run one and it made a pretty huge difference in spool. Turbo hits a lot harder with it.
Old 10-07-2010, 02:36 PM   #9
choleaoum
Member#: 255484
2010 EVO
Thanks for the help bro appreciate it. I'm going to pick one up soon as soon as I get this car running flawlessly. I just need seats now lol.
Old 10-07-2010, 06:40 PM   #10
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Thats great to hear, awesome!
Hey well let us know if you have any questions at all, we are here to help! Feel free to call us too if you want to order that way, otherwise you can check out one of our many dealers that carry these! Importimageracing.com, rallysportdirect, jscspeed, etc... you might even get a sweet deal through them!!
I promise you will not be dissapointed, and install is a breeze
Will
GrimmSpeed is offline   Reply With Quote
Old 10-07-2010, 09:56 PM   #11
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
MAKE SURE YOU GET A TUNE for the new boost solenoid. The EBCS (like the Grimmspeed) typically need at least 1/3 less wastegate duty cycle compared to the stocker.
If you don't get a tune, you'll be overboosting pretty badly and could be risking your motor.
phlegmon is offline   Reply With Quote
Old 10-08-2010, 12:55 AM   #12
Corinator
Member#: 211974
I would also like to add that you need a real personalized tune, not just an off the shelf stage 2 map like the Cobb AP2. Get an e-tune, dyno tune, or personalized map of some sort.
Old 10-08-2010, 02:51 PM   #13
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
um, with no line running to the wastegate you're going to OVERboost to whatever it takes for the exhaust to force the wastegate open. To run at wastegate pressure you need to run a vacuum line directly from the compressor port to the wastegate.
AQ Motorsports is offline   Reply With Quote
Old 10-09-2010, 04:32 AM   #14
Corinator
Member#: 211974
I just assumed it was hooked up. I figured it wouldn't be left just completely disconnected. I figured what he meant by solenoid delete was that the solenoid was removed but the line was kept.
Old 10-09-2010, 01:42 PM   #15
choleaoum
Member#: 255484
2010 EVO
It's wired correctly, the compressor to the wastegate or w.e lol. There's no more T in between the line.
Wastegate solenoid wiring HELP bwco Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-12-2004 01:07 AM
Wastegate Solenoid - Needed for swap? ShooterRS Subaru Conversions 12 04-24-2004 01:13 AM
fix a stuck wastegate solenoid? cdvma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-22-2004 07:49 PM
stock wastegate solenoid xxsive25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-30-2003 05:22 PM
PO244 wastegate solenoid High input GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-04-2003 09:07 AM
