Old 10-07-2010, 09:39 AM   #1
tilldeath303
Member#: 256472
2010 2.5i
Spark Silver
Default how to remove old coat of wax from car?
I have read various things saying not to use dawn soap on your car. If this is the case what should I use? Anything I can grab locally??
tilldeath303 is offline   Reply With Quote
Old 10-07-2010, 12:01 PM   #2
IIdiceII
Member#: 90438
any of the chemical guys citrus car washes in the proper dilution will safely strip the wax off your car and theyre cheap.
IIdiceII is offline   Reply With Quote
Old 10-07-2010, 12:13 PM   #3
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Why not use dawn soap? Many detailers use it all the time.
I use Dawn Soap to prep my car for waxing and for a 16 year old car, I'd say it worked just fine.
[IMG][/IMG]
Smoke is online now   Reply With Quote
Old 10-07-2010, 12:14 PM   #4
tilldeath303
Member#: 256472
2010 2.5i
Spark Silver
thanks for the info will get an order into them ASAP, just need something I can get locally. If nothing is out there I guess I'll just use dawn for the time being and hope it isn't as bad as some say.
Old 10-07-2010, 12:16 PM   #5
tilldeath303
Member#: 256472
2010 2.5i
Spark Silver
[IMG][/IMG]
From what I've read it actually removes oils from the paint. Don't know if it's true and as long as you're following up with a proper detail I can't see how it would hurt anything however I'd like to be as safe as possible.
Old 10-07-2010, 12:18 PM   #6
IIdiceII
Member#: 90438
oils from the paint? come on lol...
think about that for a second. its fine on the paint. the reason people say dont use it is because it strips the protection but if thats the plan then its fine.
follow up with a good detail and make sure you protect everything including the trim/weather stripping.
Old 10-07-2010, 12:25 PM   #7
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
If Dawn stripped clear coats and oils from car paint, then I wouldn't feel safe using it on my mom's German china.
Like what Dice said. People say that because they use it on a regular basis for years and their paint fades.
It DOES what it supposed to do, strip any protection. Follow up with some clay bar if necessary and a good wax and I guarantee you'll be impressed.
Old 10-07-2010, 12:36 PM   #8
chaltig
Member#: 226274
2002 WRX wagon
+1 for chemical guys, i use it before i wax and detail clients cars, and its awesome.
chaltig is offline   Reply With Quote
Old 10-07-2010, 01:48 PM   #9
tilldeath303
Member#: 256472
2010 2.5i
Spark Silver
thanks a ton guys for clearing that up, I figured that was the case and I was missing something. Dawn it is! any dilution ratio or just a good squeeze or two and fill up the bucket?
Old 10-07-2010, 01:53 PM   #10
Kilo6_one
Member#: 229396
No specific ratio...... i just used palmolive to do my car. Ive used Dawn too, it really made no difference. One thing i have done is soap up the whole car, let it sit for about a minute to do its magic and then continue washing.... but i wash my car in a enclosed area, don't do this in the sun. LOL
Kilo6_one is offline   Reply With Quote
Old 10-07-2010, 05:04 PM   #11
Leftlane2
Member#: 251904
2010 WRX 5 Door
SSM
When I mounted the factory rear bumper protector and side moldings on my car, the instructions from Subaru specified rubbing alcohol for cleaning the surfaces. It removed the wax easily, but the car was pretty new.
Leftlane2 is offline   Reply With Quote
Old 10-07-2010, 05:18 PM   #12
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Rubbing alc will severely soften the clear coat for a while ( hours ) if not damage it. Its acts like the purple or blue stuff used to prep PVC pipe before gluing it.
The Subaru Manufacture says to use it so the adhesive gets a good bite for proper adhesion.
dangerousatom is offline   Reply With Quote
Old 10-07-2010, 05:27 PM   #13
Noek
Member#: 206316
2009 STI StageII
I use CG as well but I will use dawn too...heard some claim that dawn can be tough on plastics over a while but I've never encountered this.
Noek is offline   Reply With Quote
Old 10-07-2010, 11:23 PM   #14
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....they say to use it because it will effectively remove any residue, wax/sealant, etc. on the surface so the adhesive will adhere directly to the paint and not some product that may compromise the mounting. It's the same reason it's used by many to prep scratches/chips before touching up and the same reason many professionals use IPA for wipe-downs of paintwork to remove polishing oils, LSP's, etc. Something like Prep-Sol is also effective for this. I would be curious to hear where you learned that it will soften and damage paint.
OP, Dawn should be perfectly safe for periodic use. I've used it in the past and still do in a pinch myself. If you're really concerned, AutoAesthetica has mentioned success in simply using some car wash products in a concentrated solution. I've read his posts and I believe he knows what he is talking about. Also, if you plan on claying the car, keep in mind that action alone would be enough to remove many wax/sealants in itself. ....add a prewash with the Dawn, a strong solution of car wash soap, etc., and that and it's sure to strip off whatever you have on the finish.
Personally, I typically use CG CWC as some others have mentioned here as well. There are other popular washes out there including decontamination systems like Valugard ABC and FinishKare that are even more thorough.
Kean is offline   Reply With Quote
How to Remove F***in dog hair from Car brrrrrbecold Car Care & Detailing 28 09-17-2009 08:54 PM
is it possible to remove the smell of smoke from furniture? if so, how? doubledribble Off-Topic 17 02-27-2006 04:38 PM
How to remove old bushes Dr. Shred Brakes, Steering & Suspension 9 08-04-2003 06:14 PM
How long should you wait to put a coat of wax on a repainted door? mrtrex Interior & Exterior Modification 15 07-27-2003 05:32 PM
Quick help- how to remove old wax? riddler Car Care & Detailing 11 04-01-2002 12:59 AM
