Mid Atlantic Impreza Club
Old 09-02-2011, 11:09 PM   #1
apache
Member#: 160799
O2 WRX
Thumbs down Late-Spool Issue. Advice? Assistance?
My car is a 100% stock '02 wrx sedan.
I'm hitting target boost, but it's not coming on until around 4K rpm.
This issue has come up within the last week and a half or so. Prior to that, I was getting full boost at just over 3k in third, and whatever the target boost is in 1st and 2nd. In short, it was running great and making proper boost at all times.
The issues seemed to pop up out of the blue. I drove home from work, parked the car for about two hours, and when I took it back out it felt boggy.
The only thing I've done to the car in the last few months is change the gear oil to Redline Heavyweight Shockproof.
I smoke tested it today and found a pretty decent post-MAF air leak, which I fixed. This had no effect on the boost problem. I have not checked it for a boost leak yet.
I tried removing the vac line from the wastegate actuator to eliminate the boost control system as a possible cause. With that hose removed, the boost would spike to well above target if I let it, but still would not get there before 4k rpm.
I haven't thoroughly checked it for exhaust leaks, but I got a good look at the exhaust manifold tonight and didn't see any signs of a leak.
I've had the car for a few months and have never removed the turbo, uppipe or manifold myself. Whether or not they were moved before I got the car I have no idea. The exhaust sound hasn't changed at all.
Anyone have any experience with this problem, or wanna help me figure it out??
apache is offline   Reply With Quote
Old 09-02-2011, 11:52 PM   #2
Tut4u2
Member#: 40424
05 STi
Tired turbo? wastegate?
Tut4u2 is offline   Reply With Quote
Old 09-03-2011, 12:35 AM   #3
apache
Member#: 160799
O2 WRX
Both of those came to mind.
I'm not getting any smoke from the turbo at all. How would I verify that, other than by checking for shaft play? Spin the wheel and see if it drags?
The wastegate actuator I can test with a vacuum pump...
Old 09-04-2011, 12:42 AM   #4
apache
Member#: 160799
O2 WRX
anyone?
Old 09-04-2011, 07:40 AM   #5
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Check the actuator (and if you bypassed the BCS and got spiking... you did not bypass correctly).
Pre-turbo exhaust leak would be my guess - or a HUGE block in your post-turbo exhaust.
There are assuming your post-MAF leak is fixed now.
Abnormal is offline   Reply With Quote
Old 09-04-2011, 11:41 PM   #6
apache
Member#: 160799
O2 WRX
How do I check the actuator? I disconnected the arm from the wastegate and moved it around to make sure it wasn't sticking. It seemed to move freely enough. I haven't checked the diaphram for a leak yet.
I bypassed the BCS by removing the hose from the actuator. This does in fact bypass the BCS, does it not, since it would then have no affect on boost control? I still don't fully understand this clusterf**k boost control system...
I don't hear any major exhaust leaks, but I haven't checked it all that carefully. I still have both of the stock cats, so I wouldn't be surprised if one or both of them were clogged.
Old 09-05-2011, 03:31 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If you don't find a pre-turbo vacuum leak in the vacuum lines, the thought that comes to my mind is your stock uppipe is clogged. I would REALLY recommend you take it to Kienan at All Aspects on Tilden St in Chesapeake.
Old 09-05-2011, 03:44 PM   #8
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
How many miles on the turbo and car? How are you monitoring boost? Does it hold any less to redline? Any abnormal noises heard? You can be looking at anything from a (upipe) gasket issue to a blown turbo. Tough one to diag over the internet!
Steve.804 is offline   Reply With Quote
Old 09-05-2011, 05:25 PM   #9
kuntryquest
Member#: 278027
2005 Legacy GT
Pearl
Is it fading off at all once you hit peak boost? Heck I would check all your vac hoses. Also check your post turbo exhaust. Other than that I would point to the turbo.
kuntryquest is offline   Reply With Quote
Old 09-05-2011, 05:43 PM   #10
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
That would be exactly how not to bypass it Just disabling it...
Put a hose on the compressor nipple, then attach the other end to the actuator. That's it. Direct vacuum connection. EBCS is now bypassed.
Old 09-05-2011, 08:15 PM   #11
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Question for the gurus...
Would the pre-turbo cat breaking down or oem egt probe cause said problem?
Old 09-05-2011, 09:53 PM   #12
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
The cat busting and clogging the flow of exhaust would certainly cause an issue for a turbo - which is spooled by the flow of exhaust gases through said pipe.
The EGT, unlikely. Cat's a much more likely candidate.
psirst (Elmer) had a similar issue - Glowing red uppipe is a good sign it's clogged
EDIT:
This is why I usually recommend an uppipe be the first mod for anyone with a catted uppipe!
Old 09-06-2011, 07:57 PM   #13
apache
Member#: 160799
O2 WRX
UPDATE:
My uppipe is leaking. I smoke-checked the exhaust and found a leak in the uppipe, somewhere behind the heatshield where I can't see it. I can see that it's not the gasket but the uppipe itself, somehow. I think maybe my blown-to-s**t engine mounts may have had something to do with it...possibly a crack in the weld. Either way, the uppipe has to go. I noticed the other day that the lag is substantially worse when the car is cold, and not nearly as bad when warm. This could have meant a lot of things, but the easiest to check was the exhaust.
I'll update this when I know for sure that it's fixed. Thanks for the advice.
edit:
To answer some of your questions...
-The car has 84,xxx miles on it.
-I'm monitoring boost with the factory boost gauge.
-Once it finally reaches target boost, it holds until it gets close to redline and then tapers off. Seems normal, minus the late spool.
-No abnormal noises or smoke.
Old 09-21-2011, 07:25 PM   #14
apache
Member#: 160799
O2 WRX
Update:
I replaced the stock uppipe with a new catless one, problem is fixed.
With the catless uppipe and stock exhaust I got full boost by ~3400 in 3rd, 4th & 5th. After gutting the stock downpipe, I get full boost by ~3100 in 3rd, 4th & 5th.
Need some possible Legal Advice/assistance SwiftShifter87 North West Impreza Club Forum -- NWIC 8 09-21-2009 11:08 PM
Ticking noise / Starting issue... advice please. 93 Impreza SubyZ Normally Aspirated Powertrain 0 06-26-2007 08:17 PM
Major paypal issues. Advice please? Overlord2kx Off-Topic 13 02-28-2007 10:09 PM
Possible Wheel Bearing issue...advice / recommendations needed GonzoWRX Mid Atlantic Impreza Club -- MAIC 12 10-26-2006 11:45 AM
