Mid Atlantic Impreza Club
Closed Thread
Old 10-08-2010, 05:07 PM   #126
MRF582
Member#: 48219
. Always drive
the race line .
I believe Paul is using one in his STX WRX. Also factor in cost for tapered roller bearings from Subaru. You won't be able to salvage them from the old diff.
This LSD is the only thing I would buy from OBX.
MRF582 is offline
Old 10-08-2010, 05:23 PM   #127
SWP sube
Member#: 236667
2007 SWP
390 whp Limited STi
does anyone have a tial 44mm vband EWG for sale?? or any other 44mm vband??
SWP sube is offline
Old 10-08-2010, 05:56 PM   #128
sk84fun21
Member#: 113300
WRB, LOUD
recommendations on a place to take scrap parts for $$. i have a bunch of old rotors, springs, struts and various other metal parts. also a place for cat pipes? i have a dual cat pipe i need to get rid of
sk84fun21 is offline
Old 10-08-2010, 08:05 PM   #129
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
forgot to mention to everyone that there is a dyno day tommorrow at J&S.
sorry on the short notice but anyone that doesent have anything to do feel free to stop down
mecpgh is offline
Old 10-08-2010, 10:49 PM   #130
sk84fun21
Member#: 113300
WRB, LOUD
Old 10-09-2010, 12:46 AM   #131
Cereb Daithi
Member#: 112349
...more fresh powder
Cereb Daithi is offline
Old 10-09-2010, 01:18 AM   #132
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
hey Tom, so i had a minute to think about things and some scratch paper to do some maths:
1200cc/min injectors, X4 @90% duty cycle is 72CC of fuel a second. so assuming you're at full throttle for the duration of a 5 second turn(HAHAHAHA!!!), that's 360cc of fuel used up.
if you continue it on for a full hour they flow out 259.2l/hr
incidentally, looking at fuel pump maps of pressure/flow, you're best off going with dueling walbros. a single 044 flows ALMOST enough at 80psi, but dueling walbros flow more than enough, and a single walbro at like 10psi flows just enough, but i don't know if i'd trust it to fill the swirl pot. running the numbers out further, i get 430.92 lb/hr of fuel flowed with those 1200cc injectors at 90% IDC, which at 11:1 AFRs is ~79 lbs/min of air. which is ~597g/sec and ~780 hp worth of air. which brings me to three questions.. could you really sustain max lat while simultaneously disposing of nearly 800 hp? for 10 seconds? and the 1200cc/min is from raising the base pressure on what injectors from, to...? are you looking for horsepower or acceleration or a laptime?
in conclusion i think a .5l swirl pot is more than sufficient, and suggest dueling walbros, intank, with a 0.5l in tank baffle setup. pumps, sumps trapdoors, whatever. better than external setups. also. if you're flowing that much fuel. you may need to run a large, like half inch aluminum fuel line to the front of the car. and use the stock feed line as a return.
reason i post instead of PM or txt is there's more than one else out there building a high HP car that may appreciate these ruminations...
PS dave, i'ma lick that cage. in a dirty, you're my bitch sort of way. you can't watch.
glhs377 is offline
Old 10-09-2010, 10:47 AM   #133
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Originally Posted by MRF582 View Post
Whoops But you knew what I meant.
Hahaha, Guilty. You make so few mistakes at the keyboard I just couldn't pass it up.
Originally Posted by GregsblueRex View Post
If you vote on overall build. There is no question you'll vote for me or Jake15. If you like bling, drift or hellaflush...my car is not your choice. Now if you like an 11 sec legacy who sees tracktime and keeps up with vettes on the straights, I'm your guy.
That old school leggy is pretty nice too. I am partial to wagons as well. But...
I Am a power/performance first kind of guy so you're getting my vote all the way to the end.
Tenacious Bee is offline
Old 10-09-2010, 12:15 PM   #134
GregsblueRex
Member#: 31997
08 QSM Spec Bizzle
96 XJ Beater
New photoshoot pics are up over in top scoob. For those that are interested:
http://forums.nasioc.com/forums/show....php?t=2056261
Teaser:
GregsblueRex is offline
Old 10-09-2010, 02:27 PM   #135
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Just voted for you dude!
dexterous is offline
Old 10-09-2010, 06:02 PM   #136
GregsblueRex
Member#: 31997
08 QSM Spec Bizzle
96 XJ Beater
Thanks for all the votes guys.
And Cereb...that powdered cage looks SICK. Got a link on specs of what this thing will be?
Old 10-09-2010, 06:40 PM   #137
Cereb Daithi
Member#: 112349
Old 10-09-2010, 07:02 PM   #138
spoonracing13
Member#: 122035
2006 TR
So a few weeks back I started hitting only 14.8psi on a off the shelf map from Cobb (stage 2 93octane) which used to hit 15.8 or so max.
I've since reset the ECU, changed my plugs (90k), cleaned my OEM boost control solenoid with MAF cleaner and now removed my intercooler to get at the turbo to look for anything obvious.
I'm considering adjusting the wastegate arm 2 turns. Am I way off the fairway here?
spoonracing13 is offline
Old 10-09-2010, 07:54 PM   #139
dexterous
Member#: 23553
2014 WRX - Daily
LOL, I have been looking at dual walmart pump setups for a day or so. It appears that it would be hella cheap in comparison to my other options. Chances are it would be far quieter as well.
Old 10-09-2010, 10:20 PM   #140
bluesmobile440
Member#: 247485
2006 WRX TR
Originally Posted by Cereb Daithi View Post
This is absolutely jaw dropping...I don't even want to know how much moola is going into this thing
bluesmobile440 is offline
Old 10-09-2010, 10:50 PM   #141
dexterous
Member#: 23553
2014 WRX - Daily
PMed you.
Old 10-10-2010, 12:08 AM   #142
dexterous
Member#: 23553
2014 WRX - Daily
I am finally going rotated so I have a ton of stuff to sell ASAP:
(Note, GT Spec header is gone. I also have a sale pending on the turbo)
Silver Perrin Side Feed Fuel Rails: $275 (7000 miles). I have run these fuel rails for a few years without a single issue. Unlike most Perrin stuff, these are very high quality and work really well. The kit is 100% complete and also includes about $150 in coated pyroshielded fuel lines.
My Dom3 XTR Turbo with 3" inlet: $1400 (1800 miles). This is an awesome turbo, my car made 473wtq and 461whp on this thing! Its got some kind of magical bearings and billet wheel that allow it to spool up very quickly for its size.
-Deatschwerks 950cc side feed injectors: $450 (Extremely rare, 1500 miles). These injectors are super super rare! Every so often Deatschwerks releases a single set of 950cc side feed injectors made up of freakishly high flowing side feed units. I was super lucky to be able to purchase this set 100% new last winter. I am pretty sure that I have the original box, flow sheets, etc for these.
-100% New Pink eBay "H" Brace (just as good as the super expensive ones): $40
-TurboXS 4" down pipe: $200 (1800 miles)
TiAL 44mm EWG: $275 (5000 miles)
Old 10-10-2010, 02:44 AM   #143
glhs377
Member#: 125388
97 240hp NA GF6
i have some **** luck. cant even make the trackday. went form 3 trackable cars to zero this week. on the bright side i wont be waking up at 5am. it'll probably take me til lthen to scrub myself clean.
glhs377 is offline
Old 10-10-2010, 08:34 AM   #144
dexterous
Member#: 23553
2014 WRX - Daily
O no, what happened?
Old 10-10-2010, 10:43 AM   #145
hostile silence
Member#: 163878
05 STi & CBR1000rr
OBP & Blue and Yellow
anyone interested in showing/giving me a hand installing sidefeed injectors so i can install turbo and get tuned?
not the most appealing thing to do im sure, but i would really appreciate it, and buy lunch and beers
hostile silence is offline
Old 10-10-2010, 11:52 AM   #146
Nowski
Member#: 153726
2005 STi
Well I replaced my gear oil and still have some grinding when downshifting from 5th to 4th. I think the syncrhos are going bad. Can anyone recommend a good transmission shop in the area? If im going to spend over a grand id like to go somewhere that knows what theyre doing
Thanks,
Nowski is offline
Old 10-10-2010, 11:52 AM   #147
dexterous
Member#: 23553
2014 WRX - Daily
Need to buy a set? Buy my injectors and I will come to your house and install them!
Old 10-10-2010, 11:53 AM   #148
dexterous
Member#: 23553
2014 WRX - Daily
Originally Posted by Nowski View Post
id like to go somewhere that knows what theyre doin,
Then you may want to take it somewhere out of the area...
Old 10-10-2010, 08:29 PM   #149
watson 29
Member#: 175479
00 2.5RS
STM
Hey guys. anyone got stock front brakes/calipers for sale, or know any who's selling them. Let me know guys. send me a pm.
watson 29 is offline
Old 10-10-2010, 08:31 PM   #150
Cereb Daithi
Member#: 112349
I won't tell R
Enough that I don't keep a strict record of what I spend so I don't depress myself..
Closed Thread
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Camera Thread #62902.0031 V6.0 BacDoc Off-Topic 115 11-12-2007 04:22 PM
I miss the old Pittsburgh thread... you know, the one that crashed NASIOC? dmross Mid Atlantic Impreza Club -- MAIC 12 05-29-2006 03:10 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
