Mid Atlantic Impreza Club
Closed Thread
Old 10-10-2010, 08:37 PM   #151
Nowski
Member#: 153726
2005 STi
Originally Posted by dexterous View Post
Then you may want to take it somewhere out of the area...
Any ideas of a good place thats not too too far?
Nowski is offline
Old 10-10-2010, 09:33 PM   #152
WastingTime
Member#: 181927
99 RS - RBP
10 DSP
Andrewtech Automotive is ~4 hrs away in MD
They are the best of the east coast
WastingTime is offline
Old 10-10-2010, 09:57 PM   #153
sk84fun21
Member#: 113300
WRB, LOUD
Originally Posted by sk84fun21 View Post
recommendations on a place to take scrap parts for $$. i have a bunch of old rotors, springs, struts and various other metal parts. also a place for cat pipes? i have a dual cat pipe i need to get rid of
anyone??
sk84fun21 is offline
Old 10-10-2010, 10:37 PM   #154
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
anyone??
D&D recycling under 62st br, beside all foriegn auto parts, lawenceville
PDLTURBO is offline
Old 10-10-2010, 10:37 PM   #155
sk84fun21
Member#: 113300
WRB, LOUD
thanks
Old 10-10-2010, 11:19 PM   #156
dmross
Member#: 2818
2000 2.5RS
Originally Posted by GregsblueRex View Post
If you vote on overall build. There is no question you'll vote for me or Jake15. If you like bling, drift or hellaflush...my car is not your choice. Now if you like an 11 sec legacy who sees tracktime and keeps up with vettes on the straights, I'm your guy.
Well said, voted.
dmross is offline
Old 10-11-2010, 12:14 AM   #157
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
watson, people just chuck them. pick up WRX brakes for almost nothing and be much happier.
dave, R can watch.
well. long story short, the quaife, close ratio trans, solid urethane mounts, rebuilt factory axles, axxis ultimates and the straight TEs with hankook v12 evos make it pretty crazy and damn is it sharp. does everything you want IMMEDIATELY!
too bad i wasnt' done 18 hrs ago
why wasn't i done? well, the ohlins turned out to be broken/blown, which i found out friday night ~ 10pm, after designing new tophats for them and using the mockups to cycle them, so i switched gears into making the wagon good to go for the trackday, as on thrusday i picked up a giant screw right near the outer sidewall tread in the STi. getting thw wagon track ready meant finishing the braking system and getting decent pads and changing trans and engine oils. no problem, right? well, Tom helped IMMENSELY with getting me the front rotors, tried buying pads but nobody has anything performance for 04wrx around. bought a set of $230 EBC reds that dont' even goddamned fit, and finally dug up some almost shredded axxis ultimates from when i got the brakes from shek. the rears disintegrated when i was cleaning up the edges, so i just did the fronts, then dropped on my 1 1/165" SVX master cylinder, with the two bottom holes drilled and tapped for 1/8" NPT(try finding one of those local on a saturday!!) got it all together and bench bled and then bled all the brakes. whats this? no, not happening. ok. pedal still going to the floor? wtf? ran super blue, gravity bled the whole thing. it's midnight now and i've been working on this car and driving around trying to find the crap i need to actually get things done for the past 13 hours. actual work on the car isn't too hard or long. only a few hours. hardest bit was reflaring the lines. after the bleeding, flushing and gravity bleeding, pedal still goes to the floor. something is seriously wrong with this master cylinder or soemthing i cant' see, so i go over to the civic, and start working on it to get it ready for leaving at 6am to head out to nelson ledges.
at this point i'm covered in brake fluid and filthy as the damned wagon is still really low, have a bunch of work to do to get the civic trackworthy. put the shifter in, fill it up the trans, drop in axles, put the not all together horrible tockico illuminas and progress springs back together, change the engine oil, and then disaster. i cant' get any of the bolts in it. ~2:30am i throw in the towel. spent he next 45 minutes cleaning up and another 45 mins tryign to get clean in the shower. this suck. wake up ~ 10am, pull the trans and EVERY threaded hole on the friggin trans was crossthreaded and/or full of some crap paste that turns brand new bolts into round edged piles of ****. so my new bolts from the dealership are ****ed, and couldn't get an m12x1.25 tap ANYWHERE today, so took my best old bolt and turned it into a thread chaser, but pulling the trans i just installed and chasing every threaded hole took ~6 hrs. most of that was chasing threads. i did all this by hand as my air ratchet valve disintegrated after doing 2 bolts, what else is going to go wrong? put the trans back in, and get everything else buttoned up, i've done this dozens of times before. normally swapping a transmissino takes ~2 hrs. anyway it's 10pm now, go out for a drive. civic is AMAZING, still need to figure out what's wrong with the wagon's MC. oh and my projector took a **** cause my stepdad hit it with a boken. after an hour of digging in it, found out he knocked some grounds loose along with busted the case. i'm skipping a lot to make it quick, but i'm pretty convinced i have crap luck, trying to change it, any ideas? at least today a paint can didn't explode in my face, right? ahh. world is tellin me cars can go fukk themselves i think.
glhs377 is offline
Old 10-11-2010, 08:37 AM   #158
watson 29
Member#: 175479
00 2.5RS
STM
That's what I was looking for. one of you guys that upgraded your front brakes and had you old ones laying around.
watson 29 is offline
Old 10-11-2010, 08:45 AM   #159
explicithero
Member#: 15893
2004 STi
The color of the burgh
I might have a set I'll look in my parts shed.
explicithero is offline
Old 10-11-2010, 09:48 AM   #160
dmross
Member#: 2818
2000 2.5RS
Geeze man, sounds like a bad run. Happens to all of us. A lot of people are lazy and would have given up, thereby ending what a persistent person such as yourself would perceive as a long string of bad luck. Look at it the other way - you are no less lucky, you are just accomplishing more so naturally more bad things are also happening.
dmross is offline
Old 10-11-2010, 09:54 AM   #161
ruby-ru
Member#: 44535
2003 PSM WRX
Twinscroll Goodness!
I have all the brakes off of my wrx since I switched to brembos. I even have an almost brand new set of pads but they are far from performance pads. They were just to get me through until my brembos arrived.
ruby-ru is offline
Old 10-11-2010, 09:55 AM   #162
ruby-ru
Member#: 44535
2003 PSM WRX
I see a promising self help career in your future. "I love me cause I'm somebody!"
ruby-ru is offline
Old 10-11-2010, 10:54 AM   #163
ogre96
Member#: 196595
2008 WRX
Dark Gray Metallic
Any one know of a good transmissions shop near new kensington that isn't a rip off. I need a new clutch and don't have a garage to work in.
Sent from my ADR6300 using Tapatalk
ogre96 is offline
Old 10-11-2010, 10:58 AM   #164
dmross
Member#: 2818
2000 2.5RS
The key to "finding happiness" is recognizing the flaw in the cliche. You don't find happiness, you create it. That will be $1000 please. But wait, for a limited time we have partnered with Alphashek Industries to offer you massive discounts if you sign up for our free Subaru R&D pamphlet!! Unlock the secrets to personal happiness and EJ ringland failure for the low combo price of $1800!!! That's over 60% saved! No CODs accepted.
dmross is offline
Old 10-11-2010, 11:23 AM   #165
spoonracing13
Member#: 122035
2006 TR
I got my clutch & flywheel put in by Aamco past the Dairy Queen/McD's for like $400 labor.
No noticeable issues.
spoonracing13 is offline
Old 10-11-2010, 11:51 AM   #166
glhs377
Member#: 125388
97 240hp NA GF6
haha! no it's mainly Rochelles' Mother and stepdad are here and i had prepayed for the trackday on sunday, and got excited. first trackday in 2 years, barring snowx. i'm gonna hit one a month minimum this coming summer. and i can say now that i've driven the pants off it, that alloy wheel repair right over here at the end of Gross st in bloomfield is AWESOME! straightened the crap out of my TEs(though they complained they were like springs! and the hardest to straighten wheels they ever came across) all of them are now round!! and hankook v12 evos are friggin wild! no inside wheelspin the quaife either, and the 10% closer ratios REALLY help. love it! so Dan, drive the civic now!
also the big lump where the piece of **** craftsman 17mm wrench broke and flew into my forehead is gone.
watson, sorry i junked mine. got 30 bucks form all the junk. call all foreign, wrx calipers are same cost through them. like 30 bucks each.
glhs377 is offline
Old 10-11-2010, 12:08 PM   #167
MRF582
Member#: 48219
. Always drive
the race line .
Jason, do not ever sell the STI. And you should've done the trackday with replacement wheels/tires for your STI. Do the wheels/tires off the wagon fit your STI?
Dan, nice!
MRF582 is offline
Old 10-11-2010, 01:20 PM   #168
glhs377
Member#: 125388
97 240hp NA GF6
wheels hit the brembos, i tried! sti overheats oil in 2 laps at nelsons in cooler weather if i wasnt' hustling about tryign to sort out the issue i would've seen your message and grabbed your wheels. fix your bmw, another nice week, we can go on a sweet NA drive.
glhs377 is offline
Old 10-11-2010, 02:20 PM   #169
mator
Member#: 150674
PGH AWD Meet 2014
Sept 19th-21st 2014
Guys I need your help, my clutch is toast on my DailyDriver "02 Bugeye WRX" and I dont have the full potential to change out my Clutch and Flywheel. My friend that normally helps me smashed his hand last week and cant help me with the swap.
So here it is if anyone is interested:
Free Beer "your choice" and Pizza for help with Clutch/Flywheel Swap. + I have some subaru shirts to give out. I also have a Liftand Tranny Jack that we will be able to use.
Message me if you would be interested in a group swap maybe tomorrow evening?
http://forums.nasioc.com/forums/show....php?t=2067517
mator is offline
Old 10-11-2010, 02:30 PM   #170
Nowski
Member#: 153726
2005 STi
wow everyone seems to be needing some help with transmission stuff today
Nowski is offline
Old 10-11-2010, 04:19 PM   #171
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Tom,
Just saw your post about going rotated. What do you have in mind ? I will have a few extra bucks after the holler days/ 1st of the year. I am on te fence between one of Dale's set ups or an sti suspension/drive train swap. Car is plenty fast now with more potential left in it so I am leaning towards the chassis stuff but I am fickle.. I would like to know what you are considering.
Tenacious Bee is offline
Old 10-11-2010, 06:13 PM   #172
MXracer52
Member#: 183916
2005 STI
AW
I have a few things I'm looking to get rid of.
Deatshwerks 850cc sidefeed injectors $250
Side feed tgv deleted $125
Gimmick turbo inlet and aftermaf $125
PM me if interested in anything
MXracer52 is offline
Old 10-11-2010, 08:52 PM   #173
garagedefeat
Member#: 101399
2001 Forester L
Originally Posted by tenacious bee
Correction. Pistons have nothing to do with knock resistance.
this isn't true. The design of the piston [dome] has a lot to do with knock threshold...an important part of why a 4g63 can make 700rwhp on straight 93 octane .
I don't know how true this is, but an Subaru engine builder told me the weird Cosworth dome is most anti-detonant of the o.t.s. options for EJ's.
watson - i have Ryan's old front brake setup. Stock wrx calipers painted red, higher end slotted rotor and some upgraded pad. PM me if interested and i'll get the rotor/pad specs.
Jason - do you have 5x114 hubs on the sti? if so, you can borrow my wheels if you do the track day.
garagedefeat is offline
Old 10-11-2010, 09:04 PM   #174
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
Originally Posted by MRF582 View Post
I believe Paul is using one in his STX WRX. Also factor in cost for tapered roller bearings from Subaru. You won't be able to salvage them from the old diff.
This LSD is the only thing I would buy from OBX.
I've had no problems with the obx diff, I talked with other autox's who have then before i bought it. I was able to re-use the subaru bearings, but it was dumb luck that i got them off the factory diff and on the obx.
and it's an esp wrx , lol. No diff upgrade allowed in stx
PDLTURBO is offline
Old 10-11-2010, 11:01 PM   #175
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Lots o parts for sale here! I will give VERY good deals to the locals especially if you pay cash.
Perrin side feed fuel rails: http://forums.nasioc.com/forums/show...php?p=32124321
TurboXS Down Pipe: http://forums.nasioc.com/forums/show...5#post32128525
DW 950cc side feed injectors: http://forums.nasioc.com/forums/show...8#post32124308
Super awesome Dom3 XTR Turbo: http://forums.nasioc.com/forums/show...9#post32124199
dexterous is offline
Closed Thread
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Camera Thread #62902.0031 V6.0 BacDoc Off-Topic 115 11-12-2007 04:22 PM
I miss the old Pittsburgh thread... you know, the one that crashed NASIOC? dmross Mid Atlantic Impreza Club -- MAIC 12 05-29-2006 03:10 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
