Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-07-2010, 05:00 PM   #1
SequentialTT
Member#: 254651
Default 97 Outback - Need Help!
I bought a 97 outback about 2 months ago and it was driving awesome until this week. It started by running really terrible at a red light while stopped in drive. It seemed to only give me problems while stopped at an idle, but more recently it's been having terrible power loss until about 3000rpm and having a poor idle some of the time. I replaced the o2 sensor but it's still running very poor. Over the length of this week it went from driving perfect to almost unable to run. Any suggestions?
SequentialTT is offline   Reply With Quote
Old 10-07-2010, 05:18 PM   #2
scoobyoutback73
Member#: 116512
1999 impreza sport
catalytic converters ?
scoobyoutback73 is offline   Reply With Quote
Old 10-07-2010, 05:20 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
I suggest you check for codes......it must have some if it's running that bad.
Jay
Old 10-07-2010, 09:26 PM   #4
SequentialTT
Member#: 254651
it had the check engine light on when I bought it, p035 for knock sensor, but that was when it was running fine. I need to scan it again, just dont own a scanner. only paid $1000 for the car
Old 10-07-2010, 09:28 PM   #5
SequentialTT
Member#: 254651
That was my next guess. I was thinking about dropping the whole exhaust tomorrow. I did just run some seafoam through the tank and in with my oil, that's what made me think something gummed up my o2 sensor. It happed the next full tank after the seafoam.
Old 10-08-2010, 08:03 PM   #6
SequentialTT
Member#: 254651
replaced both cats today, still running the same. also replaced the fuel filter. did a junk yard run and got a used coilpack and plug wires (the ones that were on there looked very new) but it's still running ****ty. going to try new spark plugs tomorrow, wish me luck. any suggestions on anything else?
Old 10-08-2010, 09:17 PM   #7
sol_tegra
Member#: 259406
02 WRB WRX
is the check engine light on or flashing? if its on check for codes and if its flashing then most likely its misfiring.
sol_tegra is offline   Reply With Quote
Old 10-08-2010, 09:21 PM   #8
GrundleJuice
Member#: 165749
Investigate that knock sensor
GrundleJuice is online now   Reply With Quote
Old 10-09-2010, 12:08 PM   #9
SequentialTT
Member#: 254651
It's not flashing, and the knock sensor I grabbed a used one at the wrecker yesterday going to install it right now with new plugs
Old 10-10-2010, 12:47 AM   #10
SequentialTT
Member#: 254651
Solved! Previous work was done on the harness that plugs into the MAF sensor. Looked pretty ****ty so I cut it out and put on some new wire runs like a champ once again. Better than before, no more engine light since I changed out that knock sensor.
Issue with 96 Legacy Outback - need help! evilwankel Electrical & Lighting 0 12-14-2008 01:36 PM
ABS issues on 97 GT - need help Lee MD Legacy Forum 14 10-04-2006 07:53 PM
Building a Turbo Outback - need help with stock ECU serrs Legacy Forum 12 12-14-2004 04:34 AM
Premature brake wear - 2003 LL Bean Outback - Need Help! HB_Dad Brakes, Steering & Suspension 4 03-01-2004 09:28 AM
Stereo Install - 97 Outback Sport - Help! susan Car Audio, Video & Security 2 11-18-2002 11:48 AM
