Old 10-07-2010, 06:15 PM   #1
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
Default 93 Legacy Wagon idle issue.
I've got a 93 wagon 5mt and it's been a total beast for the past 2 years. Anyway this morning I was in stop and go traffic (in about 50 degree weather, one of the first chilly days of the year) and I noticed the idle was hovering around 2k.
So I tapped the throttle while I was in neutral and it dropped down to about 650-700ish and threw a CEL. I decided to take the back road and see if I could make it to school... Well, about ten minutes later the engine quit at a stop sign. All electronics worked fine still. The car started right back up, the CEL went away and I drove to school fine with no more issues.
The idle got pretty low (500-600) a few times on the way home about 8 hours later, but has been pretty much normal. Is this something I need to be concerned about?
burritotown is offline   Reply With Quote
Old 10-09-2010, 07:16 AM   #2
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Perhaps your IACV is on it's way out? See if you can throw the code again, and diagnose the CEL with the diagnostic wires. If you don't know how to check the CEL here is a video I made:
Here is the link for the codes:http://troublecodes.net/Subaru/
And if you diagnose the CEL and it happens code 42 (IACV) Here is a video I made on how to replace it:
Fairly easy job, I had part numbers too, I cannot find them though. Do it when the engine is cold to avoid any coolant leaking everywhere.
If you end up getting another code, report back here and we can see where to go from there.
Jessekrs123 is offline   Reply With Quote
2001 Outback suspension setup in a 93 Legacy Wagon ? subjfd Legacy Forum 11 02-22-2006 07:40 PM
Is 5spd manual 93 legacy wagon rear diff.. 2slofouru Transmission (AT/MT) & Driveline 3 01-28-2006 12:04 AM
Is there a direct turbo swap for my sisters car? its a 93 Legacy Wagon LS AWD Generalee01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-23-2005 02:27 PM
90-93 legacy wagon Skibum4444 North West Impreza Club Forum -- NWIC 3 01-24-2004 04:43 PM
93 legacy wagon auto "turbo"!!!!! felix Legacy Forum 11 06-02-2000 12:15 AM
