Old 10-07-2010, 10:37 PM   #1
furburger
Member#: 260205
2009 WRX - 5 Door
DGM + Rock Chips
Default 2009 WRX Boost Creep issues...
Hello, I have been researching and trying to find answers. It seems like a lot of opinions are on the fence about the issue. Let me explain...I have a 2009 WRX 5 Door. Currently it is only Stage 1. I was looking to go to stage 2. I was looking to purchase an Invidia Catless DP and keep my STOCK catback. My question is: Is having the stock catback with the catless DP enough to prevent the possibility of boost creep? I understand that the VF52 has a mechanical boost creep that cant be tuned out...EWG and Wastegate porting is out of the question as of right now...I would be running this set up with EM of course.
Thank you for the help and opinions.
p.s. I was planning on keeping the stock catback from here on out on the vehicle. I figure the price of a catback can go towards other parts. To me the catback is good for the sound and minimal gains.
furburger is offline   Reply With Quote
Old 10-08-2010, 12:01 AM   #2
usfsfire42
Member#: 242630
.. Flu shot
technician.
my friend has a wagon also same year with an invidia catless dp and invidia n1 race exhaust and he got it tuned and doesnt have any problems that we noctice with boost creep,he also has an aem intake and grimmspeed boost controller. the boost leves dont spike or anything i think with a good tune you can mitigate this issue fairly well
usfsfire42 is offline   Reply With Quote
Old 10-08-2010, 11:07 AM   #3
Mr. Fancypants
Member#: 17626
2005 STI
nice name lol! Definitely use EM and should be good with the stock catback. Just make sure to keep an eye on the boost guage/Accessport monitor etc.
Mr. Fancypants is offline   Reply With Quote
Old 10-08-2010, 02:43 PM   #4
Spec7
Member#: 254571
2009 WRX
Dark Gray
What is EM? (Please excuse my ignorance)
I have a Cobb catted downpipe fitted to the stock exhaust on my '09 sedan. The
consensus on the Cobb forums seemed to be that this was fine, but your post concerning boost creep kind of concerns me.
Didn't have much luck with a google search, it actually came right back to this post. Could the OP or someone else elaborate on the concern please?
Spec7 is offline   Reply With Quote
Old 10-08-2010, 02:46 PM   #5
CenCalWRX
Member#: 255402
2008 WRX
EM if I'm correct stands for engine management.. Like a Cobb Access port.. Or a different pro-tune
CenCalWRX is offline   Reply With Quote
Old 10-08-2010, 05:13 PM   #6
Spec7
Member#: 254571
2009 WRX
Dark Gray
Ahhh. That makes sense, thank you.
Old 10-08-2010, 05:23 PM   #7
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Boost creep should not be so bad on this, maybe the Nasioc'ers scared ya a bit but if it does become an issue I know you said you were not ready for EWG and porting but you can do just porting on just the hot side and not have to re-tune, and it will help with any creep. You don't need to run an EWG to have it ported but either way going stage 2 you should look into an aftermarket BCS boost control solenoid and a good solid tune!
Will
GrimmSpeed is offline   Reply With Quote
Old 10-08-2010, 07:17 PM   #8
economan
Member#: 221981
2008 STI
WHY? Why would you want to increase your turbo flo with a modified down pipe into a stock exhaust? I don't get it.
economan is offline   Reply With Quote
Old 10-08-2010, 10:00 PM   #9
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
the stock exhaust can handle a good amount of power being 2.25" or 2.5". its the cats that are hurting stuff so you can replace the DP and still get power out of the CBE till your up above 300ish.
synolimit is offline   Reply With Quote
Old 10-09-2010, 02:22 PM   #10
furburger
Member#: 260205
2009 WRX - 5 Door
DGM + Rock Chips
Thank you for the help guys! I do hear that the boost creep is a real issue in 4th and 5th gear at the higher rpms...Im happy to know that I can port my waste gate and not need to retune. And as for the catback...5-10hp to me isnt worth it as of right now...keeping the stock look/sound but with a increase in the overall performance is what I am after as of now...my thought of keeping the stock exhaust (2.5") would keep some back pressure on the waste gate and minimize the possibility of boost creep. Im not in a position as of now to get a boost controller or a protune. I didnt know if when I do get the protune if the tuner can lower the waste gate duty cycle if boost creep is still an issue...Thanks again!
Old 10-09-2010, 04:40 PM   #11
Jakubgt
Member#: 233051
Full catless TurboXS TBE flashed with cobb stage 2 maps. 4th & 5th had issues with creep pretty bad. I ended up taking the downpipe off and flashed to stage 1. Some other users have had issues with their VF52 and a catless TBE setup.
This spring I plan on getting protuned at P&l and adding a GM 3-port boost solenoid. If that doesn't cure my creep, i'll either add a cat or just go with an EWG setup
Jakubgt is offline   Reply With Quote
Old 10-09-2010, 04:58 PM   #12
thatkhmer
Member#: 217500
2009 SWP Wrx
2010 WW Evo X
Correct me if i'm wrong, but after the downpipe isn't it mostly just free flowing air and too much back pressure anyways? so keeping the stock catback wouldn't be restrictive really correct?
btw when i was getting tuned for stage 2 and CAI by Naji (road tuner) my stock map was overboosting to 17psi, when it shouldve been at 12.9 psi, at 4500 rpms i believe. At least thats what naji said
thatkhmer is offline   Reply With Quote
Old 10-09-2010, 05:27 PM   #13
Studebaker83
Member#: 169443
2008 WRX with VF-52
World Rally Blue
When I did my researched before buying my downpipe I found going catless is the primary reason for boost creep with the 08+s.
Studebaker83 is offline   Reply With Quote
Old 10-09-2010, 06:01 PM   #14
baba0023
Member#: 231744
2020 sti stg15
obsidian blk pearl
^. i bought catted for that reason
baba0023 is offline   Reply With Quote
Old 10-09-2010, 06:09 PM   #15
Studebaker83
Member#: 169443
2008 WRX with VF-52
World Rally Blue
Me too
09 WRX boost creep issue Darkmatter1986 Engine Management & Tuning 13 02-22-2010 10:53 PM
Boost Creep Issue for a French Guy Sous Bas Roue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-24-2005 12:23 PM
Perplexing Boost Creep Issue lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 3 12-09-2004 07:30 AM
Boost creep issue solved by Imprezd MACHWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-02-2004 02:32 PM
FYI,,boost creep issue and keeping one cat jagcars26 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 11-28-2003 10:54 PM
