Old 10-08-2010, 04:58 PM   #1
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
Default 1999 2.5 4-cylinder missfire
I just bought a 1999 legacy GT Limited (208K) for $2,600, and got a CEL on the way home. advance says it is a misfire in all four cylinders. I got home and started poking around and found the intake box was not firmly attached to the engine, could this cause my problem? I feel i got a good deal even with any issues it has short of the engine blowing up.
Tbird Man is offline   Reply With Quote
Old 10-08-2010, 05:09 PM   #2
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
Probably not the issue, but anything is possible. Was it running crappy, or just throw the light with no other symptoms?
sachilles is offline   Reply With Quote
Old 10-08-2010, 05:33 PM   #3
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
it seems to run ok, maybe a slight miss feeling now and then, but nothing obvious. the CEL starts flashing every now and then.
Old 10-08-2010, 09:19 PM   #4
sol_tegra
Member#: 259406
02 WRB WRX
pull you spark plugs n look for carbon tracking....
sol_tegra is offline   Reply With Quote
Old 10-08-2010, 11:16 PM   #5
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
I bought plugs and wires today to put on it. bought an air filter too before i realized it has a K&N. I am also going to put some lucas in the fuel.
Old 10-09-2010, 09:39 AM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
If it has an MAF sensor clean the MAF sensor and get a regular air filter. a loose or leaking intke can cause a misfire, and usully on all cylinder if it does. this is because the quantity of air measured is different than the actual amount entering the cylinders (because of the leak), so the ratio of fuel to air will be off. if its off enough, misfires due to extremely lean or rich mixtures may occur. any codes for "sys lean bank 1" or anything like that?
Old 10-09-2010, 12:25 PM   #7
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
ok, so the last guy who had it was an idiot. he put a silicone boot between the TB and the intake, he tried to clamp the boot to the rubber part of the intake and obviously that is where my leak was. removed boot as well as replacing plugs/wires, runs better but still off. when i stab the throttle it hesitates and i hear a gulping sound from the intake, Could this be injectors or fuel system? or perhaps it needs to recalibrate?
Old 10-09-2010, 02:32 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i dont know how the 95 ECU works, but on the current systems a large fuel trim would be skewed from the leak and it would need to be driven enough to re-adjust to normal. Or resetting the ECU would hopefully start it from a default calibration which should be close to what it needs to be. Dont know how to reset that ECU for sure but disconnecting either battery terminal for a few minutes may work.
Old 10-09-2010, 02:59 PM   #9
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
this is actually a '99 LGT, my '95 runs fine.
Old 10-09-2010, 05:32 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Can't hurt to reset the ECU now that you've replaced the plugs and wires and fixed the intake.
Patrick Olsen is online now   Reply With Quote
Old 10-10-2010, 12:08 PM   #11
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
Reset the ECU, runs 1000% better now, thanks for all the help.
FS: 1999 2.5 RS coupe 5 speed! Rally Blue! PA! vettez062002 Private Vehicle 'For Sale' Classifieds 8 11-27-2009 09:03 AM
all 4 cylinders missfiring, but car seems to be running ok csimp3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-04-2009 11:08 PM
Swap 1999 2.5 RS engine for 2001 2.5 RS engine c0mrade Subaru Conversions 5 06-15-2006 09:19 PM
2.5 L Cylinder heads 4 sale 1997 fastonthefly Private 'For Sale' Classifieds 0 03-01-2006 10:23 PM
stock 2.5 RS cylinder #3 & 4 misfires sorakiu Normally Aspirated Powertrain 12 06-13-2003 05:49 PM
