Old 10-08-2010, 05:01 PM   #1
sidewayz
Member#: 5810
2001 S366 2.5RS
Default Equal length twin scroll Borg Warner
Tucker @ Area1320 just got done tacking this sucker up. The prototype kit will be on their shop RS to see how it performs.The turbo is a Borg Warner S366
sidewayz is offline   Reply With Quote
Old 10-08-2010, 06:43 PM   #2
karlknaupp
Member#: 60871
2004 WRB WRX
looks sick. i see fred has been at "their" shop too..
karlknaupp is offline   Reply With Quote
Old 10-10-2010, 01:53 AM   #3
TIGWERKS
Member#: 256615
Very brave for tacking together that whole thing without welding as you go. I suspect you'll have to add material or change a thing or 2 due to the shrinking of material in each joint throwing it off.
TIGWERKS is offline   Reply With Quote
Old 10-10-2010, 10:43 AM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
not when its bolted to a jig that was made for it you wont
Old 10-11-2010, 08:05 PM   #5
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
looks good much respect. One thing I wanted to ask is the support bracket a temp thing/flange locator or is that how your gonna do it?
scubydrew is offline   Reply With Quote
Old 10-11-2010, 08:31 PM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
That was just a flange locator. Tucker is finishing up welding tomorrow. I'll stop in and get some pics
Old 10-11-2010, 11:25 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
material?
eg33GC is offline   Reply With Quote
Old 10-11-2010, 11:40 PM   #8
TIGWERKS
Member#: 256615
says sch10 304 on the material
Old 10-12-2010, 10:18 AM   #9
eg33GC
Member#: 206851
56 Belair
Pro Street
how can you read that?
hope it is 304L.
Old 10-15-2010, 03:33 PM   #10
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
Doesn't matter. Metals including stainless steel shrink when they are welded on. This becomes more problematic when there are a lot of weld joints like what's there. No matter what you do, it's going to move a little. That doesn't necessarily mean you are going to have to add material, but it might change the flange locations a bit, or change the way the tubes meet up with the flanges.
kcpaz is offline   Reply With Quote
Old 10-18-2010, 11:10 AM   #11
racerfab1
Member#: 91849
04 STi
^^^ Not neccesarily true. I understand your point, though. Really depends on robustness of the jigging and whether the welder skips around alot or not... He might also be tacking the whole thing together in order to dis-assemble it and make his jigs from the tacked-up pieces. Then go back and start welding, making whatever adjustments might be needed. I've been working in Indycar, ALMS, and Nascar as a fabricator for over a dozen years and don't see anything wrong with how he's doing it. COT cages are not as thick, but they are completely welded in fixtures without a problem. Total shrinkage over a 5' rollcage section of chassis is less than 1/16". Obviously 4130, not 304...
racerfab1 is offline   Reply With Quote
Old 10-18-2010, 12:14 PM   #12
sidewayz
Member#: 5810
2001 S366 2.5RS
the only spot that moved was where the up pipe connects. that part wasn't in a jig and it BARELY moved.. A little adjustment and she is all good
Old 10-24-2010, 09:19 PM   #13
reid-o
Member#: 103631
2004 STI
When you mock up the up pipe, do you do create jig that simulates the firewall too?
Or do you just sort of assume that you have sufficient clearance if you tuck the turbo close up against the block?
I'm thinking of trying to make my own off of JDM twinscroll header, but the thought of pulling the motor and putting it back several time for fitment is not appealing.
reid-o is offline   Reply With Quote
Old 10-25-2010, 09:48 AM   #14
sidewayz
Member#: 5810
2001 S366 2.5RS
Measure measure measure lol. The kit was recently just tossed in a car and while tight, there is room
Old 10-28-2010, 12:01 PM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Any updates on this? I'm curious to see how it turns out.
Old 10-28-2010, 05:43 PM   #16
sidewayz
Member#: 5810
2001 S366 2.5RS
its all welded and just sitting around.. apparently the owner of the manifold kinda disapeared.
Old 12-16-2010, 04:51 PM   #17
loafman
Member#: 256373
2003 WRX, 2011 STI
Looks sweet!
loafman is offline   Reply With Quote
Twin scroll borg warner ej207: 693whp 439tq @ 28psi absolute cubuff Proven Power Bragging 48 10-07-2010 05:30 PM
2005 STI Borg Warner Twin Scroll - Pump gas/Race gas numbers P&L Motorsports Inc. Proven Power Bragging 77 06-24-2010 06:12 PM
Unequal length twin scroll header gumby647 Built Motor Discussion 6 03-28-2009 12:02 PM
GP Moto Borg Warner Twin Scroll Turbo kit strong_auto_concepts NWIC Private Classifieds 13 10-29-2007 03:42 PM
Equal length headers, twin scroll on USDM 2.5... gills STi Forum Archive 21 05-02-2003 06:50 PM
