Old 01-22-2011, 09:40 AM   #101
ogintheback
Member#: 99163
Will this cable work for 2005 STi and windows vista? Any other hardware needed?
Thanks
ogintheback is offline   Reply With Quote
Old 01-23-2011, 12:40 PM   #102
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
just got a cable for my 03. it doesn't work with ecu flash. i paid noting for it but its just frustrating
wrxsubiemod is offline   Reply With Quote
Old 02-05-2011, 02:07 PM   #103
gottasubby
Member#: 238703
04 wrx
silver soon to be blue
Any 02-03 guys willing to sell your cable? Pm me
gottasubby is offline   Reply With Quote
Old 02-07-2011, 10:01 PM   #104
artemis53
Member#: 260497
2006 2.5i
Seconded! I have an 06, and I am wanting to log and tune. please...if you have a cable you want to get rid of, LMK!
artemis53 is offline   Reply With Quote
Old 02-07-2011, 11:23 PM   #105
Drifter2be
Member#: 265122
2004 WRX
Java Black Pearl
Haven't tried to tune with it yet, because I still need to order my flash block connector, but it works perfectly with RomRaider and learning view for logging. 2004 WRX
Drifter2be is offline   Reply With Quote
Old 02-08-2011, 10:28 AM   #106
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Keep us posted.
Subian is offline   Reply With Quote
Old 02-08-2011, 12:26 PM   #107
MattPersman
Member#: 139385
i posted this in the vag-com thread i figured i would post it here too
I am using a 9 dollar and some change shipped to me from china cable off ebay and was able do learning view, and flash using an older version of ECUFLASH. this thing looks the same as the cable that busted finger is selling. I am sure i will be told its completely customized and not a 10 dollar cable
MattPersman is offline   Reply With Quote
Old 02-22-2011, 09:23 PM   #108
robtmc
Member#: 23659
Chapter/Region: HIIC
2002 WRX Sport Wagon
Platinum Silver
FYI, after examining the BFM cables, seeing no way they would work as a 1.3 (at least with early WRX years), went ahead and bought the parts to make my own from the 1.3 schematic. Major difference is the OBD L line is talking to the DTR/DSR serial lines separately, where the BFM like a Vag attempts to do both K and L comms through the TX/RX lines. Suspect there is something sent over the L line that cannot work with the cheap cables since DTR/DSR are not connected to anything.
Even though the schematics are free, you can't make a duplicate of the 1.3 and sell them. Patented. So there seem to be two choices for early WRX guys: buy the real thing or make your own.
While waiting for the parts, saw member skibbz had a Tacktrix 1.3 for sale. Snapped it just to be thorough, got it today. Had to revamp the drivers to make sure it was using the Tacktrix stuff and not the FTDI from earlier attempts with the Vag-com thing. Now it shows up as a Tactix 1.3 Subaru in the lower right hand of the Ecuflash window. Still have Ecuflash 1.29a loaded, though this should work with a clean install of 1.42.
Went out the the garage just now, connected the test wires, started Ecuflash and stepped through until the "turn key on and hit ok". No special clever timing, just key on and OK. Connected instantly and dumped the ROM. Total time from ripping open the package to ROM saved was maybe 2 hours, most of which was driver purging and making sure all was in order, on a desktop and the laptop.
All this thrashing around so many have with the BFM/Vag-com stuff (including me), and the correct circuit works painlessly. I knew this would work, just gratifying to see it through after hours of poring over circuits and old posts.
Will be interesting to see if my home built, with FTDI EEPROM loaded with the 1.3 info (minor changes, TXD and DTR inverted) works. Know I need 1.29a to avoid the ID check, big deal. No reason it will not work, just maybe not be pretty like the real thing.
robtmc is offline   Reply With Quote
Old 07-25-2011, 09:25 PM   #109
guciodog11
Member#: 160264
95 20G'd EJ255 GC8
cable does NOT work with ECUFlash and 2004 STi ECU....only learning view and romraider logger work fine.
guciodog11 is offline   Reply With Quote
Old 07-25-2011, 09:33 PM   #110
Jäger
Member#: 269943
2005 WRX
filthyfriday.com
Cable works with my 2005 wrx. I was getting a low voltage error, and got it working by running 12v power to the top left connector of the flash block.
If you guys are getting the low voltage error, let me know. I can make a video to show you my setup.
Jäger is offline   Reply With Quote
Old 07-26-2011, 07:55 AM   #111
lethaldose
Member#: 189360
The real question would be what operating system your running. If its windows 7 it will attempt to automatically overwrite the BFM drivers, you have to make sure all UAC controls are off, you are administrator, and go in through device manager.
lethaldose is offline   Reply With Quote
Old 07-26-2011, 04:01 PM   #112
guciodog11
Member#: 160264
95 20G'd EJ255 GC8
i used the device manager to install the packaged drivers, restarted and i still have the same problem.
Old 08-03-2011, 09:54 PM   #113
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
any updates
scootarida1 is offline   Reply With Quote
Old 08-03-2011, 11:05 PM   #114
\Rogue
Member#: 9502
06 STI
Mine worked on my 06 Sti
\Rogue is offline   Reply With Quote
Old 08-06-2011, 11:26 AM   #115
guciodog11
Member#: 160264
95 20G'd EJ255 GC8
after 13 hours of installing/reinstalling drivers and multiple hard drive wipes, i got it to work with 1.29 and an 04 STi ecu
Old 08-07-2011, 01:02 PM   #116
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
so it will flash? and what did you have to do to get it to work with windows 7
Old 08-07-2011, 11:05 PM   #117
kylers2k
Member#: 290576
x2 on the windows 7. just ordered a bfm cable and just bought a new laptop loaded with windows 7
kylers2k is offline   Reply With Quote
Old 08-08-2011, 07:21 AM   #118
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
well I guess if I dont get an answer in a couple of days then I will let everyone know how it works with windows 7 (64 bit) because it just shipped so hopefully it will be here by the end of the week
Old 08-08-2011, 12:47 PM   #119
alottaboost
Member#: 158029
2016 STi Limited
Pure Red
If this is simply a VAG-COM cable, rebranded, they work fine with Win7 64 bit. I'm using a $20 eBay one currently.
alottaboost is offline   Reply With Quote
Old 08-08-2011, 01:11 PM   #120
\Rogue
Member#: 9502
06 STI
Windows 7 64 bit works.
Old 08-08-2011, 02:04 PM   #121
guciodog11
Member#: 160264
95 20G'd EJ255 GC8
I'm running 7 and x64 too... I had to use ecuflash v.1.29 and everything works great
Old 08-08-2011, 02:07 PM   #122
\Rogue
Member#: 9502
06 STI
I am also using the most recent version of ECUFLASH.
Old 08-08-2011, 06:39 PM   #123
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Okay thanks I will also update if I can get it to work with my 2005 Forester XT on windows 7 64 bit
Old 08-10-2011, 07:00 PM   #124
Magnum
Member#: 105363
00 RHD V2 Sti
01 Lightning
Works on my 04 sti.
I had to downgrade ecuflash software to 1.29 and worked perfect.
Windows 7, 32bit
Magnum is offline   Reply With Quote
Old 08-10-2011, 09:27 PM   #125
Raziel1
Member#: 237733
2004 WRX
Win 7 64bit
Used the BFM cable to read and flash roms with ECuFlash. Romraider works fine.
When I first started trying I was getting the low voltage error. Figured out a way to make it work..pm if u need help
Raziel1 is offline   Reply With Quote
Anyone try the K&N Typhoon Intake system for the WRX? BrysImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-02-2002 02:03 PM
Anyone try the Eibach springs from Subaruparts.com? BrysImpreza Brakes, Steering & Suspension 1 09-20-2001 05:53 PM
Anyone try the Forge strut tower bar? dead-eye Brakes, Steering & Suspension 2 07-30-2001 09:00 PM
Anyone try the clear Subaru fog light protectors? Arnie Technical Forum Archive 3 08-22-2000 09:59 AM
Anyone try the AVS Sports? Tim Prudence Technical Forum Archive 14 07-28-2000 12:49 AM
