Old 08-11-2011, 01:39 AM   #126
Drifter2be
Member#: 265122
2004 WRX
Java Black Pearl
windows 7 64bit, could read but never got it to write, even after jumping pins 11 and 16, voltage errors. Gave up, spent the money on a legit cable.
Drifter2be is offline   Reply With Quote
Old 08-11-2011, 07:16 AM   #127
scootarida1
Member#: 154534
2005 Forester XT
Originally Posted by Raziel1 View Post
Win 7 64bit
Used the BFM cable to read and flash roms with ECuFlash. Romraider works fine.
When I first started trying I was getting the low voltage error. Figured out a way to make it work..pm if u need help
What version of ecuflash do you have? My cable should be in Friday just wanna make sure I have the best shot of getting this to work right the first time.
scootarida1 is offline   Reply With Quote
Old 08-12-2011, 04:35 PM   #128
no1v2
Member#: 263771
The BFM cable is exactly the same as the VAG-COM KKL USB cables that go for under $10 shipped on eBay. Try this eBay search. Just sayin'...
This means they'll only reflash/read the ECU image on 32-bit non-CANbus Subarus. So early WRX is out of luck. They will log on any modern Subaru, including 16-bit, and including CANbus.
no1v2 is offline   Reply With Quote
Old 08-14-2011, 12:54 PM   #129
\Rogue
Member#: 9502
06 STI
damn under 10 bucks
\Rogue is offline   Reply With Quote
Old 08-14-2011, 02:18 PM   #130
quazimoto
Member#: 70395
This info is nothing new. Obviously BFM has just been buying the same cable and charging 5x as much as the Ebay vendors.
quazimoto is offline   Reply With Quote
Old 08-14-2011, 03:28 PM   #131
lethaldose
Member#: 189360
99 Subaru Forester
Built EJ255 GT35 Rotated
FWIW try out a vagcom cable, 9 out of 10 times you will get voltage errors and trouble communicating with ECUFlash. Some will log however but glitchy under a higher list of parameters , and some will have a hit or miss on the voltage error. Comes down to pin placement, and connection points on the boards to set things apart and make them work. BFM cables have worked with 2002/03 WRX ECU's not just USDM but JDM and other Europe models. But the timing issue which did not seem hardware related, is was forced them to pull support.
I'am in no part representing them, just stating some additional information for the masses.
lethaldose is offline   Reply With Quote
Old 08-22-2011, 04:40 PM   #132
cineris
Member#: 263329
2011 Impreza WRX
Anybody know if the BFM or vag-com cables work for a 2011 wrx? Don't think this matters, but I have windows 7 64 bit.
cineris is offline   Reply With Quote
Old 08-22-2011, 06:25 PM   #133
scoobydo2.0
Member#: 261290
2004 WRX
Nope, won't work on your 2011 WRX. Anything past 07 runs a CANBUS ECU, and the BFM cable doesn't support those ECU's. They don't really work with any of the WRX ECU's, but that's purely subjective.
scoobydo2.0 is offline   Reply With Quote
Old 08-22-2011, 11:50 PM   #134
cineris
Member#: 263329
2011 Impreza WRX
Thanks for that, any idea what cable(s) might work for me?
Old 08-23-2011, 07:13 AM   #135
\Rogue
Member#: 9502
06 STI
Open port 2.0
Old 08-23-2011, 08:19 AM   #136
scoobydo2.0
Member#: 261290
2004 WRX
^^^ What he said, the Tactrix 2.0 cable is your only option.
Old 08-23-2011, 11:09 AM   #137
cineris
Member#: 263329
2011 Impreza WRX
I figured that would be the case. Oh well, still cheaper than an accessport.
Old 08-23-2011, 12:47 PM   #138
kylers2k
Member#: 290576
Fwiw... the evo scan 1.3 cable works flawlessly with 01 02 and 03. Just ecu flash 1.29 and get the latest definitions and your good to go. No errors whatsoever. Bfm doesn't work with bugeyes I have one of those also. Good for logging but that's it.
kylers2k is offline   Reply With Quote
Old 11-27-2011, 03:38 PM   #139
I3oostedScooby
Member#: 85390
06 WRX
STEEL GREY
gotta revive this thread i have an 04 and keep getting the low voltage crap when trying to load a new map into the car... whats the fix?
I3oostedScooby is offline   Reply With Quote
Old 11-27-2011, 03:40 PM   #140
Jäger
Member#: 269943
2005 WRX
filthyfriday.com
run a power line from your battery to your flash block. if your looking at it with the clip facing upwards, its the top right connector.
Jäger is offline   Reply With Quote
Old 11-27-2011, 06:00 PM   #141
I3oostedScooby
Member#: 85390
06 WRX
STEEL GREY
tried top right and left still nothing
Old 11-27-2011, 06:22 PM   #142
Jäger
Member#: 269943
2005 WRX
filthyfriday.com
Does it raise the voltage at all? In the log error message area. It has to be around 11-12 volts. Turn on your lights and AC if it goes over.
It should be the top right btw
Old 11-27-2011, 06:30 PM   #143
I3oostedScooby
Member#: 85390
06 WRX
STEEL GREY
still says only 4.24 volts hooked up to the top right i have just under 12 volts on the wire
Old 11-28-2011, 03:54 PM   #144
SuperDuper
Member#: 131101
2004 AW STi
Just a little FYI shipping from BFM is PAINFULLY slow. I bought mine on the 21st and I still haven't seen it, and I am in the same state as them.
SuperDuper is offline   Reply With Quote
Old 11-29-2011, 10:14 AM   #145
alottaboost
Member#: 158029
2005 STi
I bought the same VAG-COM cable on ebay and had it in 2 days. Just find a US shipper on ebay and return the BFM one. It's the same exact thing.
alottaboost is offline   Reply With Quote
Old 11-29-2011, 10:21 AM   #146
SuperDuper
Member#: 131101
2004 AW STi
Im pretty much commited to the BFM cable right now. It just sucks to deal with a vendor that works at their own pace. I ordered a tial bov 3 days after I ordered the cable and it's already installed on my car, and that came from IL.
My main problem is that they use First class mail which doesn't give you a real tracking number, it only states that the USPS may have your package, it doesn't even tell me it has left BFM yet.
Old 11-29-2011, 05:49 PM   #147
I3oostedScooby
Member#: 85390
06 WRX
STEEL GREY
well i got mine to work finally.... had to rig up a flash block and everything worked out good i thought the actual cable was the flash block had no idea about the white plug...either way all is good!
Old 11-30-2011, 11:18 AM   #148
SuperDuper
Member#: 131101
2004 AW STi
Rig up? what did you use? 2 paper clips?
Old 12-10-2011, 08:59 AM   #149
Madjax
Member#: 299271
2002 Forester 2.0 XT
Hi,
With the BFM cable on my car I could only datalog with Ecuexplorer and Learning View.
After some research using the datasheets of FT232RL, the LM339 and patterns of a VAG cable, I was able to make this cable to flash & read on WRX02 and Forester 2.0 XT EDM 02 (same engine as 2002 WRX ... but with TD035) with ecuflash, after some modifications.
Some people say that BFM and VAG cable are the same, so ...
You need to:
hardware
* Separate the L line from the line K
* Attach the pin 15 to pin 9 on the OBD port
* Send 12V regulated on the plug 11 on the OBD port
* (connect green plugs each other, jump the white plug)
Software:
* The firmware of the cable does not need to be changed (TRX and DTR are not inverted)
* Install Ecuflash 1.32 with the tactrix drivers included.
* Set COM port to 4800 bps
*I run it on Seven 64.
Tools:
How to:
The K and L line:
- Picture of the module before modification: red lines = front , blue lines = back side
- Picture of the module with modification to do: light blue lines = wire to cut, fuchsia lines = new wire to solder
Cutting the down line is easy: a little help with a Dremel
For the top one, I unsoldered leg of the IC and I left in the air. You must be very careful because it is very fragile.
I connected the legs with wire fairly fine (0.006 inch)
Finished, it look like that:
For the +12v regulated on the plug 11 on OBD port
Take the ground on the pin 4 or 5
take the 12v on pin 16
get a low drop regulator type LM2940 (ebay)
welding the LM2940 output on pin 11.
Rear view pinout of cable OBD :
Tada:
if you want to thank me : tune my map :-) http://www.mediafire.com/?hkh09sgv9obz0ug
Ecuflash 1.32 : http://www.mediafire.com/?266b5ht6xzgumfb
EDIT 2012/04/22
You can do it without the 12v regulator
More pics on this post : http://forums.nasioc.com/forums/show...&postcount=190
if you need any more information , ask me .
Have Fun
Madjax is offline   Reply With Quote
Old 12-14-2011, 04:30 PM   #150
robtmc
Member#: 23659
Chapter/Region: HIIC
2002 WRX Sport Wagon
Platinum Silver
Excellent work. I posted several times about the K and L line issues, and how BFM and Vag did not work and never would.
Thought about doing what you accomplished, but got cold feet looking at the tiny leads and my crappy eyesight. Maybe if I had a microscope to work under and inspect things. Luckily I found a Tactrix 1.3 cable cheap and forgot about the modifications...........
robtmc is offline   Reply With Quote
Anyone try the K&N Typhoon Intake system for the WRX? BrysImpreza Factory 2.0L Turbo Powertrain 2 01-02-2002 02:03 PM
Anyone try the Eibach springs from Subaruparts.com? BrysImpreza Brakes, Steering & Suspension 1 09-20-2001 05:53 PM
Anyone try the Forge strut tower bar? dead-eye Brakes, Steering & Suspension 2 07-30-2001 09:00 PM
Anyone try the clear Subaru fog light protectors? Arnie Technical Forum Archive 3 08-22-2000 09:59 AM
Anyone try the AVS Sports? Tim Prudence Technical Forum Archive 14 07-28-2000 12:49 AM
Message Board Statistics All times are GMT -4. The time now is 06:25 AM.
