Old 03-22-2012, 07:53 AM   #176
ScoobyNub
Member#: 269662
Originally Posted by skyer672 View Post
So I just bought one of these for my 06 WRX, cant get it to work with ECU flash, wont read anything. Im running 64-bit on Vista. Am I ****ed? Should I just suck it up buy a Tactrix 2.0? Anyone else get this thing to work on the same model or have the same issue?
as far as i know the 06 will not work with the bfm/vag cable since they're can-bus. so your only option so far is an openport 2.0 unless someone got the vag-com cable with can-bus working.
ScoobyNub is offline   Reply With Quote
Old 03-22-2012, 09:00 AM   #177
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Wrong. The 06-07 WRX are DBW, non CAN-BUS.
I use 1.42.2595 Ecuflash and an unmodded vag-com cable in my 07 WRX
Black94Snake is offline   Reply With Quote
Old 03-22-2012, 10:12 AM   #178
Madjax
Member#: 299271
2002 Forester 2.0 XT
does it matter if i don't add those copper lines you have on the chips?
all i did was add the red and white wires you have.
If you have a post 05 sub, It doesn't matters
Madjax is offline   Reply With Quote
Old 03-22-2012, 08:05 PM   #179
ScoobyNub
Member#: 269662
i have an 04 sti and an 02 wrx which means i'll need to add those 2 copper wires then?
Old 03-23-2012, 01:04 AM   #180
03WRXer
Member#: 142905
Default I have a BFM cable on the way for v8 swap in 03wrx
Hi guys. I wish I looked into this cable issue before buying mine, but it's too late now. I'll let you know if it works for me.
I have a USDM 2003 WRX with a v8 JDM STI Spec-C swap. I believe my swap is a 2004 v8 (twinscroll ball bearing turbo). Not sure if because I have a 2004 JDM STI ECU, this problem wont effect me?
What do you guys think? If it doesn't work, I could do that modification to the BFM cable?
P.S. My 2004 JDM ECU is 16 bit right?
03WRXer is offline   Reply With Quote
Old 03-23-2012, 03:54 AM   #181
Madjax
Member#: 299271
Yes, + cuts.
Old 03-23-2012, 04:01 AM   #182
Madjax
Member#: 299271
If you've got a 16bit ecu, you have to MadMod.
This mod is fairly simple, but do not drink coffee before ...
Old 03-24-2012, 08:23 PM   #183
03WRXer
Member#: 142905
Default BFM cable didn't work on my v8 JDM STI swap
I got the BFM cable. It worked with Learning view, and logged with RomRaider logger, but didn't work with ecuflash. I tried all the timing tricks. I got the same error messages as everyone else.
Just thought I'd post my results. Time to get a VAG cable, and do the "madmod".
Old 04-17-2012, 04:34 PM   #184
03WRXer
Member#: 142905
Default Help with Madmod on VAG cable
Hey, so I got a VAG cable off ebay for like $5.
http://www.ebay.com/itm/180837590917...#ht_2954wt_938
I did the madmod but it still doesn't work. Maybe I screwed up?
This is the mod I did:
http://forums.nasioc.com/forums/show...&postcount=153
It works the same after the mod as before. Any tips for me to try?
I can data log with RomRaider logger. But I can't read from ECU. I am trying to read with ECU Flash. I get the same error as before. I have the test mode connectors hooked up, but I don't have the jump block on because I'm just trying to read from ECU.
Maybe I need a different version of ECU Flash? I'm using EcuFlash Version 1.32.1399
I can't figure out how to attach a pic of my mod. I tested all solder connections with a voltmeter.
Any tips would be great! Thanks.......
Edit: I hooked up jump block. It works fine now. Thanks.
Old 04-17-2012, 05:31 PM   #185
Madjax
Member#: 299271
Hi,
EcuFlash Version 1.32.1399 is the good one, have a look to the drivers: take the Tactrix ones.
Old 04-17-2012, 06:42 PM   #186
03WRXer
Member#: 142905
Edit: OOOOPS, yep. I just needed to hook up the jump block. works fine now. Thanks.
Could it be because I don't have the jump block hooked up? I didn't think it needed to be to read from ecu......
What tactrix drivers should I try? Hmm, I'll look for them online.
I read in another forum to check my BAUD rate. Here are the instructions they posted:
"You may need to adjust the cable's/driver's COM port settings in order to get it to work properly:
1. Go into Device Manager for Windows(right click "my computer" on desktop, go to Properties, then Hardware tab and click "Device Manager" button)
2. Look under ports(COM and LPT) for the FTDI port(cable must be plugged into the computer at this point) and right click and go into properties for the FTDI cable driver.
3. Go to the Port Settings Tab click the ADVANCED button and look at the BAUD Rate. If it is 9600; you will need to drop the box and change it to 4800.
4. This should slow the data rate of the driver/port and allow the cable to connect to the car's ECU properly. Be sure to note the COM port number assigned to the FTDI port as you will need to select it in the logging software.
I can't find "(COM and LPT) for the FTDI port" on my Windows 7 operating system.
Maybe my BAUD rate is 9600 instead of 4800?
What do you guys think? Could this be the problem? I'm gonna look some more for this setting...........
Last edited by 03WRXer; 04-23-2012 at 07:58 PM. Reason: Just needed to hook up jump block
Old 04-18-2012, 02:06 AM   #187
Madjax
Member#: 299271
Read my original post !
You need this jump block and the green test mode connector pluged !
Old 04-20-2012, 01:36 AM   #188
03WRXer
Member#: 142905
Ok. I'll try it with the jump block. I tried with the jump block when I was trying to get the BFM cable to work, but it didn't work either way.
I thought the jump block was required only when flashing? And just the green test mode connectors were all that was required to read from ECU. Right?
Is it just because of the way the VAG cable works with the madmod, the jump block is required?
I'll test it tomorrow with the jump block. I hope that's all that is wrong!
Thank you.
Old 04-21-2012, 10:28 AM   #189
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Has anyone had any issues with the newest version of romraider? I don't want to download the newest version with fast poll overwriting my current version if I'm only going to have problems.
2gnt2wrx is offline   Reply With Quote
Old 04-22-2012, 05:26 PM   #190
Madjax
Member#: 299271
For whose who asked via PM: more MadMod (forget the 12v regulator, it works)
General view:
Cut one:
Unsolder and lift one:
Wire 2:
Direct Plug +12v and L line (forget the 12v regulator):
Have Fun!
Old 04-22-2012, 06:33 PM   #191
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
Thanks for responding so quick. I just ordered two of these today because my tactrix 2.0 broke on me after a few sessions and i refuse to buy another one. The mini usb fell off of the board. My car is flashed with my own speed density tune using Carberry's/Cardibble's wonderful setup but it's running the higher boost version of my map. It runs great but i can't log for knock right now so i have to stay off of the gas.
If you would like a copy of my map send me a pm. The only issues i have had is not being able to tell if the car has a vac leak or not because it will still run normally with sd. At 15 psi the tmic hose popped off and i thought the turbo was damaged because i wasn't reading any boost and the car was still running great.Also the top of the map isn't tuned past 6200 on the fuel side. It's close to 10.5-10.8. at 6700. Once the AFR's are good uptop i was going to advance the timing some because i retarded the ignition map around peak torque. 0 knock on my car atm
2.5 hybrid 8.8:1 estimated compression
8cm td06h 60-1
ported heads
tgv deletes
catback
modded blue injectors
walbro pump
93 octane
Purpose_Built is offline   Reply With Quote
Old 04-23-2012, 12:11 AM   #192
mikeyPSF
Member#: 236475
Default Tactrix repairs USB failures
If the USB broke off an OpenPort contact Tactrix ([email protected]). It's covered under warranty. They're almost always repairable unless someone has tried to make a previous repair with too large a soldering iron, in which case it's easy to damage them beyond repair.
mikeyPSF is offline   Reply With Quote
Old 04-23-2012, 07:45 PM   #193
03WRXer
Member#: 142905
Yep. Thats all that was wrong. I plugged the flash block (jump block) in, and wala!
I'm able to read from ecu. I also did a "test write to ecu" and that worked too.
Thanks for the MADMOD! It's works great. I did the madmod without the regulator on a $5 ebay VAG cable.
My car is a 2003 WRX with a 2003 JDM STI swap.
Time to go do some data logging, and start tuning....
Thank you.
Old 04-23-2012, 09:45 PM   #194
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
If your tactrix usb breaks, send it back and they will fix it. Don't be like me and throw a tantrum.
Old 04-24-2012, 08:43 AM   #195
ehiddenidentity01
Member#: 279169
2004 impreza wrx sti
wrb
i have a bfm cable... it sucks never worked right since i got it. it sucks spending the money on tactrix but its problem free. u dont wanna risk damaging your ecu because of a bad connection
ehiddenidentity01 is offline   Reply With Quote
Old 04-24-2012, 11:33 AM   #196
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
So I've read the whole damn thread, but I don't remember my question being addressed: I have a normal VAG-COM cable, and the jumper block. My car is a USDM 04 WRX. Do I need to do the MadMod?
Travisty is offline   Reply With Quote
Old 04-24-2012, 12:33 PM   #197
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Have you tried flashing your car yet?
Old 04-24-2012, 01:55 PM   #198
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Well at least you didn't tell me to search, lol.
I bought the car a month ago and immediately tore into the motor, and now that I'm getting close to getting it running I'm just trying to have everything I need to tune and log. So no, I haven't tried it yet.
Old 04-24-2012, 04:15 PM   #199
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
mad-modding your cable will not cause it to stop functioning correctly. so, if you have the time... have at it!
Old 04-25-2012, 06:13 PM   #200
toneh
Member#: 317065
Hi been following this for a while , madjax has emailed the latest mad mod details , excellent , but I've ordered a cable and it came today but it's totally different inside
The cable I ordered was a vag 409.1kkl
Does any one know the specific vag cable to go for or which fleabay seller that currently has them listed the same as the mad mod pics
I'm in the uk but will order from anywhere if needs must
Cheers tony
toneh is offline   Reply With Quote
Anyone try the K&N Typhoon Intake system for the WRX? BrysImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-02-2002 02:03 PM
Anyone try the Eibach springs from Subaruparts.com? BrysImpreza Brakes, Steering & Suspension 1 09-20-2001 05:53 PM
Anyone try the Forge strut tower bar? dead-eye Brakes, Steering & Suspension 2 07-30-2001 09:00 PM
Anyone try the clear Subaru fog light protectors? Arnie Technical Forum Archive 3 08-22-2000 09:59 AM
Anyone try the AVS Sports? Tim Prudence Technical Forum Archive 14 07-28-2000 12:49 AM
