Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 10-08-2010, 07:07 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default New Turbo inlet Hose From PERRIN Performance
Always Trying To Innovate And Improve Our Products We Have Done It Again
Introducing The NEW Turbo Inlet Hose From PERRIN Performance
MSRP $229.99
Used for years in Aerospace and medical equipment, silicone is now seeing a resurgence as a durable and superior material in performance motorsports. Silicone technology allows us to design a turbo inlet hose that is better in all aspects than the OEM part and increases your engines horsepower.
Smoother Air Flow To Turbo
The PERRIN inlet hose is perfectly smooth on the inside and has a significantly larger internal diameter than the OEM part. The increased air flow by removing the pleats found in the OEM hose makes more horsepower, decreases turbo spool time, and improves acceleration.
SS Internal Support Wire Special Feature!
The PERRIN inlet hose is reinforced with a stainless steel support wire that is embedded within the silicone layers. The support adds rigidity to the hose and prevents collapse when used with restrictive filter elements and large turbo applications running extreme amounts of boost.
Blow Off Valve Connection NEW!
The PERRIN inlet hose has a machined aluminum insert which is bonded into the layers of silicone, giving you a solid blow off valve hose connection and makes installation go even easier.
Large High Flow Spigots
All spigots on the PERRIN inlet hose are 1/2"ID for maximum flow from crank case vents and other vacuum connections. All connectors used on our hoses are glass reinforced nylon (rated to 400 degrees F) which will withstand engine bay temps found from normal driving to extreme racing conditions.
Click HERE to read more at PERRIN Performance Dot Com and check out the dyno charts and proven performance gains.
PERRIN is offline   Reply With Quote
Old 10-13-2010, 02:39 PM   #2
ejicon
Member Sales Rating: (19)
Member#: 2452
08 2.5 WRX
WRB Mica
I ordered one of these a early last month. By any chance, does it have all these nice new features that I read here? How'ever the case, still pretty excited about being able to install this. Also, would be nice to see a real installation video vs the time-lapse, stop motion one that is currently available.
Thanks
ejicon is offline   Reply With Quote
Old 10-16-2010, 10:38 PM   #3
PERRIN
NASIOC Manufacturer
Member#: 6776
why Is The PERRIN Turbo Inlet So Much Better?
Old 10-16-2010, 10:44 PM   #4
PERRIN
NASIOC Manufacturer
Member#: 6776
Old 10-16-2010, 11:24 PM   #5
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Thanks. I actually purchased a 2008 Wrx version. Anything new/different with that model? Updated installation?
Old 10-26-2010, 12:17 PM   #6
PERRIN
NASIOC Manufacturer
Member#: 6776
Click HERE To See The Latest From PERRIN Performance.
Wholesale clients, contact your PERRIN Performance Sales Rep For Your Specials.
Old 10-26-2010, 12:46 PM   #7
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
I ordered a MAF hose with this Halloween deal. I'm very excited and looking forward to installing it with my Turbo Inlet hose.
You guys Rock!
Old 11-09-2010, 08:29 PM   #8
ed10
Member Sales Rating: (13)
Member#: 198026
2002 Impreza WRX
Nulla Tenaci Invia EstVia
What would I need to make this work with my cobb afta maf hose??
ed10 is offline   Reply With Quote
Old 11-09-2010, 08:34 PM   #9
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Shouldn't it just mate right up?
Old 11-09-2010, 08:38 PM   #10
ed10
Member#: 198026
2002 Impreza WRX
if the Perrin keeps the maf side the same size then it should, since the cobb wraps around the factory inlet hose. I just wanna be 100% sure before I buy the Perrin and be stuck waiting for another part.
Old 11-10-2010, 02:06 AM   #11
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Ah. Ok. Definitely a PERRIN question.
I'm sure they'll be able to answer this soon.
Old 11-10-2010, 06:27 PM   #12
ed10
Member#: 198026
2002 Impreza WRX
Just to help others out Perrin replied to my pm and the answer to my question is:
"You do not need an adapter to connect it to the Cobb hose. The Turbo Inlet Hose will come with everything you need"
Good to know
Old 11-14-2010, 07:09 PM   #13
PERRIN
NASIOC Manufacturer
Member#: 6776
Turbo Inlet Hoses Are In Stock And Ready For Your Subi.
Old 11-15-2010, 03:03 AM   #14
meccjoo
Member Sales Rating: (24)
Member#: 97522
do these only come in black? i want a red one.
meccjoo is offline   Reply With Quote
Old 11-15-2010, 07:24 AM   #15
ed10
Member#: 198026
2002 Impreza WRX
Black red and blue
Old 11-15-2010, 01:47 PM   #16
meccjoo
Member#: 97522
looks like they only make the new version in black
Old 11-15-2010, 04:30 PM   #17
PERRIN
NASIOC Manufacturer
Member#: 6776
Correct, Any color you want as long as it's black.
Old 11-15-2010, 07:31 PM   #18
joewagon
Member Sales Rating: (1)
Member#: 144448
02 WRB WRX Wgn
Hybrid GST Tuned
Can you send me the price shipped to 94541?
joewagon is offline   Reply With Quote
Old 11-18-2010, 05:34 AM   #19
orangecurtain
Member Sales Rating: (5)
Member#: 211625
2003 WRX
Midnight Black
Do you guys have any Thanksgiving sale on this item?
orangecurtain is offline   Reply With Quote
Old 11-28-2010, 06:57 PM   #20
sanjosuby
Member Sales Rating: (2)
Member#: 217877
2007 6speed vf37 WRX
same on the thanksgiving/black friday deal... pm me a price shipped to 95129
sanjosuby is offline   Reply With Quote
Old 11-28-2010, 10:14 PM   #21
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Go here: Look at the top of the page. Enjoy
http://perrinperformance.com/
Old 11-29-2010, 04:13 AM   #22
nolant
Member Sales Rating: (12)
Member#: 124118
02 wrx wagon
MBP
I just ordered one of these directly from Perrin. I'm looking into the install some more, and it seems like people are removing the PS hard line in order to gain more clearance.
a) Is this necessary? It is not mentioned in Perrin's published installation instructions.
b) If I do remove the PS hard line, do I need to be concerned with fluid draining out? Or is this line dry when the engine is off?
There seem to be some people having issues with this piece, but I'm hopeful that the 'new' updated hoses will fit with no problems.
I'll post my results regardless.
thanks.
nolant is offline   Reply With Quote
Old 11-29-2010, 01:36 PM   #23
L.F.O.D
Member#: 242686
2008 WRX 4dr.
LR
thanks.
Waiting to see how this gets answered before i order. Thanks for the good questions.
L.F.O.D is offline   Reply With Quote
Old 11-29-2010, 01:51 PM   #24
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
L.F.O.D.
Installation/Fitment of the Perrin Turbo Inlet will be slightly different than what nolant's would be. He has an 02 WRX and you have an 08 WRX.
Part number for the 08 WRX is: PSP-INT-421BK
Part number for the 02 WRX is: PSP-INT-401BK
08 WRX's don't have the Power Steering line running above the Turbo Inlet like the 02 WRX's do.
I have yet to install my turbo inlet because I'm waiting for a few more parts to come in before I get a custom tune and what-nots... but I've heard from a few people that installation on our year WRX's is somewhat less complicated than pre'08 WRX's.
Old 11-29-2010, 06:24 PM   #25
L.F.O.D
Member#: 242686
2008 WRX 4dr.
LR
Thanks man. Now i feel stupid.
New Turbo Inlet hose and Exedy Clutch neuspeed SCIC Private Classifieds 9 03-18-2009 09:18 AM
I need a new turbo inlet hose tortuga Texas Impreza Club Forum -- TXIC 16 11-13-2007 08:45 AM
Fs: New Turbo Inlet Hose gingertooth Tri-State Area Private Classifieds 8 02-04-2007 12:19 PM
wtb turbo inlet hose from jdm sti turbocolin Private 'Wanted' Classifieds 1 12-18-2005 09:49 PM
New turbo inlet hose. jnorth85 Service & Maintenance 13 12-07-2005 09:51 AM
