Welcome to the North American Subaru Impreza Owners Club Thursday December 25, 2014
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 10-08-2010, 08:09 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Smile NEW Turbo Inlet Hose From PERRIN Performance
Always Trying To Innovate And Improve Our Products We Have Done It Again
Introducing The NEW Turbo Inlet Hose From PERRIN Performance
MSRP $229.99
Used for years in Aerospace and medical equipment, silicone is now seeing a resurgence as a durable and superior material in performance motorsports. Silicone technology allows us to design a turbo inlet hose that is better in all aspects than the OEM part and increases your engines horsepower.
Smoother Air Flow To Turbo
The PERRIN inlet hose is perfectly smooth on the inside and has a significantly larger internal diameter than the OEM part. The increased air flow by removing the pleats found in the OEM hose makes more horsepower, decreases turbo spool time, and improves acceleration.
SS Internal Support Wire Special Feature!
The PERRIN inlet hose is reinforced with a stainless steel support wire that is embedded within the silicone layers. The support adds rigidity to the hose and prevents collapse when used with restrictive filter elements and large turbo applications running extreme amounts of boost.
Blow Off Valve Connection NEW!
The PERRIN inlet hose has a machined aluminum insert which is bonded into the layers of silicone, giving you a solid blow off valve hose connection and makes installation go even easier.
Large High Flow Spigots
All spigots on the PERRIN inlet hose are 1/2"ID for maximum flow from crank case vents and other vacuum connections. All connectors used on our hoses are glass reinforced nylon (rated to 400 degrees F) which will withstand engine bay temps found from normal driving to extreme racing conditions.
Click HERE to read more at PERRIN Performance Dot Com and check out the dyno charts and proven performance gains.
PERRIN is offline
Old 10-11-2010, 01:45 PM   #2
teiva-boy
Member Sales Rating: (16)
Member#: 22825
I must say, the cut-away is impressive. Thank you for showing that!
teiva-boy is offline
Old 10-14-2010, 04:22 AM   #3
fastwrx25
Member Sales Rating: (37)
Member#: 126441
03 bugeye
I believe this is the legendary unicorn of inlet hoses. thanks for finally doing this.
I have the old one, do they really collapse? normally they won't right?
well, if I ever replace mine, this is the one I'll get.
fastwrx25 is offline
Old 10-15-2010, 02:20 PM   #4
kirbwrx
Member Sales Rating: (24)
Member#: 110450
2007 Spec.b Refugee
284hp 320tq Cobb Tuned
so the BOV connection is not removable any longer? how does that effect install?
kirbwrx is offline
Old 10-16-2010, 11:39 PM   #5
PERRIN
NASIOC Manufacturer
Member#: 6776
why Is The PERRIN Turbo Inlet So Much Better?
PERRIN is offline
Old 10-16-2010, 11:41 PM   #6
PERRIN
NASIOC Manufacturer
Member#: 6776
Click HERE for installation details.
PERRIN is offline
Closed Thread
New Turbo Inlet hose and Exedy Clutch neuspeed SCIC Private Classifieds 9 03-18-2009 10:18 AM
I need a new turbo inlet hose tortuga Texas Impreza Club Forum -- TXIC 16 11-13-2007 09:45 AM
Fs: New Turbo Inlet Hose gingertooth Tri-State Area Private Classifieds 8 02-04-2007 01:19 PM
wtb turbo inlet hose from jdm sti turbocolin Private 'Wanted' Classifieds 1 12-18-2005 10:49 PM
New turbo inlet hose. jnorth85 Service & Maintenance 13 12-07-2005 10:51 AM
