Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 10-08-2010, 09:09 PM   #1
Barry Goldberg
Member#: 259853
Default Correct rear main seal for JDM engine
I recently bought a '97 outback with approx 200K miles for my daughter as her first car. It has a rear main oil seal leak that I've not been able to fix..(The repairs have been done by my friend who is the chief mechanic at a local Subaru dealership who I trust completely). He has replaced the rear seal twice and it is still leaking. The problem is that this car has a (replaced) twin cam JDM engine ( which I'm told is probably a newer engine than "97) and I'm guessing that he is using the seal for a '97. The number on the engine is 898115. Can anyone tell me what year engine this is and what the correct rear oil seal part number would be?
My mechanic is telling me that there should be no significant differences in seals for different years but I'm not so sure. If he is right, can anyone tell me why this would still be leaking (major leak). He has sealed the pan and everything else just in case. Also, can silicone sealer be used with this seal? MANY thanks...Barry
Barry Goldberg is offline   Reply With Quote
Old 10-08-2010, 09:36 PM   #2
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
I'm fairly certain all rear main seals are the same for all EJs. I have a seal from a new (phase 2) gasket kit in my old phase 1 motor.
Is he sure the leak is coming from the seal and not the pcv or piston pin cover? Otherwise I would think there is a nick or gouge in the cranshaft or block preventing a good seal.
AQ Motorsports is offline   Reply With Quote
Old 10-08-2010, 09:47 PM   #3
Barry Goldberg
Member#: 259853
Default Thanx very much
I will pass this on to my mechanic..I had asked him if there was a gouge in the Crank or block and he said that there was none...Barry
Old 10-09-2010, 01:01 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
What about the oil separator cover plate on the rear of the engine? That's a much more common leak location than the rear main seal.
And I'm with Harman - the EJs all use the same rear main seal.
Old 10-09-2010, 10:55 AM   #5
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
Yep, +1 on this...Plastic plate=Doodie
snoopyone8 is offline   Reply With Quote
Old 10-09-2010, 06:44 PM   #6
Barry Goldberg
Member#: 259853
Thanx once again for your help..This "small" problem has been a large problem for my daughter as the leak is just above the spot where the 2 pipes come together and the smoke is outrageous..Do you have any thoughts again about using sealer on the seal (if the main seal is truly the problem)? Will the oil eventually just get past the silicone?
Old 10-09-2010, 07:09 PM   #7
Barry Goldberg
Member#: 259853
Hi..Thanx for your help..My mechanic said that he sealed the separator cover plate...He also said that when he redid it the seal HAD NOT pushed back out of its seat..If there was a PCV problem, could it force oil around the seal without actually forcing the seal out??
Many Thanx....B
Rear main seal on engine is leaking oil. Help ChronicSphinx Rocky Mountains Impreza Club Forum -- RMIC 3 06-27-2010 11:49 PM
Part Number for Rear Main Seal 02 WRX? jproland Private 'Wanted' Classifieds 0 12-14-2006 12:17 PM
rear main seal mybluesubi Service & Maintenance 11 02-09-2004 07:28 PM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 11:42 AM
('93-'01) Rear main seal gone - 650kms? Help! JNaubur Impreza Forum 6 05-25-2001 01:29 AM
