Old 10-09-2010, 09:33 PM   #1
wendelkurz
Member#: 256028
1996 impreza L /RS
black
Default Cv shaft
On a 1996 impreza l AWD
What all has to be done to change the cv shafts in the front. Do they just pull out and you put the new ones in?
wendelkurz is offline   Reply With Quote
Old 10-09-2010, 10:22 PM   #2
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
http://www.iwsti.com/forums/how-inst...rear-axle.html
It's about the same thing for the front.
Except you have to disconnect more stuff off the front hubs. Good luck with the lower ball joint. You might want to get sniper's ball tugger off of turninconcepts.com
Have fun and good luck.
formula91 is offline   Reply With Quote
Old 10-09-2010, 10:28 PM   #3
wendelkurz
Member#: 256028
1996 impreza L /RS
black
Well I'm changing the lower ball joints, hubs with new bearings, outer tie rod ends,struts, calipers pads and rotors all in the front when I do it. I've done it all except for cv shafts. My passenger cv shaft pulled inward about 2" and took the bearing with it. So to be safe I'm changing them all idk if anything got bend. Deep pothole @3 grand in 1st gear I smacked it hard.
Old 10-09-2010, 10:43 PM   #4
wendelkurz
Member#: 256028
1996 impreza L /RS
black
You mention it's like the rear I checked out that step by step. So there is a bolt on the front control arm that holds it to the hub and the clips and seals are the same.
Old 10-10-2010, 03:06 AM   #5
renyo
Member#: 93577
98 Impreza
I don't know about the instructions involving the hub part (you don't have to do that just to do the axle, but since you're doing it anyway it'll be easier), but the axle is held onto the transmission stub with a pin. You need to hammer it out to slide the axle off.
renyo is online now   Reply With Quote
Old 10-10-2010, 03:30 AM   #6
wendelkurz
Member#: 256028
1996 impreza L /RS
black
Not quite sure how to hammer it out. I mean on a rear end you can take the cover off an see all the gears. I'm not too familiar with awd.
Old 10-10-2010, 11:46 PM   #7
renyo
Member#: 93577
98 Impreza
The procedure is described here:
http://www.scoobymods.com/axle-remov...20.html?t=8020
Basically, there's a spring pin that goes through the axle and transmission stub. You have to hammer that out with a punch (or something like it) before you can pull the axle off. Then you have to hammer it (or preferably a new one) back in when you put the new axle on.
On another note, this is the wrong forum. There's a transmission and driveline forum further down the page.
Old 10-11-2010, 12:24 AM   #8
wendelkurz
Member#: 256028
1996 impreza L /RS
black
Lol I just posted on na to get an idea
CV Shaft Boot Leak? wrspssshhhh Brakes, Steering & Suspension 5 12-05-2005 08:34 AM
Replacing Rear CV shaft rubber boots rubberman Service & Maintenance 7 11-24-2005 01:24 AM
Where To Get CV Shafts? 012.5RS Brakes, Steering & Suspension 3 09-07-2005 06:48 AM
How do I assemble CV shafts? TheKryptKeeper Transmission (AT/MT) & Driveline 0 05-16-2005 11:18 AM
CV shaft fused to hub... gbelli Legacy Forum 9 11-05-2003 04:05 AM
