#1 |
Member#: 56345
Vehicle:93 Swapped L Green |
Which Years and Models Came With Two Metal Cam Gears?
I have a set of EJ251 heads and one gear is metal and the passenger side is bakelight. What year and model do I need to tell the stealership to get both metal gears? Thanks.
#2 |
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
No idea- but the bakelite ones are durable enough. I wouldn't make any effort to switch it out personally.
#3 |
Member#: 56345
I'm building an SOHC headed hybrid with lots of other goodies that don't belong in NA powertrain, so I'd rather do it right once.
#4 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
You know that even the STi's come with some plastic gears on the non-dual-AVLS ones, right?
Just use the plastic one, that counts as doing it right. |
#5 |
Member#: 28685
Yeah, there are a lot of little things that you want to pay attention to, but that particular part is fine.
#6 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
I would agree with this. The lighter plastic cam gear is not an area to seek upgrade from.....even with big lopey cams.
Jay |
#7 |
Member#: 104821
South East
Vehicle:2002 2.5 RS PSM |
All this being said... is there an advantage to using the bakelite gears? I realize the minor weight savings but how bout NVH when running cams?
#8 |
Member#: 187936
Vehicle:97 Legacy w12:1CR 05 LL Bean outback |
the early sohc 2.2's had 2 metal cam gears...
#9 |
Member#: 56345
#10 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
The OE did it in an attempt to save a few engines when timing belts slip or in accidents. What happens is the gear shatters stopping the rotation of the timing belt, therby saving the valves. I've purchased more than one core engine with a popped timing belt and a broken cam gear that had no damage, so I think it works.
#11 | |
Member#: 192709
W. Canada
Vehicle:2007 2.5iSE Wagon CG 2001 2.5RS Coupe RBP |
At the time I was pretty upset that they would make a plastic piece of junk, but reading Monson's post, that actually make a good deal of sense from an engineering stand point. Last edited by wmdoucette; 10-14-2010 at 10:36 AM. |
| Thread Tools | |
| Display Modes | |
| metal cam gears | lardass | Private 'Wanted' Classifieds | 0 | 01-27-2010 11:16 PM |
| FS: sti valve covers, and both metal cam gears | wrxej205 | Engine/Power/Exhaust | 3 | 02-04-2009 09:23 PM |
| 98 Standard steel wheels fit which other years and models? | Chuck the swimmer | Normally Aspirated Powertrain | 3 | 07-05-2006 08:53 PM |
| Which years and models do these wheels fit?? | Chuck the swimmer | Tire & Wheel | 2 | 07-05-2006 08:52 AM |
| legacy turbo years and models... | Rubasu | Factory 2.0L Turbo Powertrain | 10 | 10-05-2001 11:12 AM |
