Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-27-2002, 06:20 AM   #1
HubbieScooby
Member#: 7088
Super Slow
Question can't stop running rich from RRFPR
hey guys i have this problem ever since i installed my turbo kit about 3 months ago....when i got my car back i was running super rich for the first week.....plus the installer forgot to pull out my stock plugs....i have a cartech RRFPR and was wondering if the top screw where you can tune with your thumb should be all the way in at all the time?? this controls how soon the FPR starts pumping fuel right?? the side screw where you need some kindda socket wrench is for how much fuel right?? i'm kindda wonder how you guys have your set up?? the problem is my idle temp is around 500-600F and my full tank of gas will probably give me about 225 miles maybe a little more....in think my O2 sensors are fried too from the first week running super rich....i have an air/fuel meter from autometer and it reads all the way to rich all the time while cruising.....when i hammer the gas the meter will slowly creep to about the first block of stoch....and sometimes cross over to lean.....this really sucks cause i'm running a 15.1 at the 1/4 mile and wondering if this time is caused be still running too rich....i am running 4.5 lbs. boost and have an super ITC retarding not more than 3 degrees at the most around the high RPM's and running 92 octane....can you guys tell me how you tuned you cartech RRFPR??? thanx much guys
hugh
HubbieScooby is offline   Reply With Quote
Old 06-27-2002, 08:16 AM   #2
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
You have it backwards. The nut-locked allen screw in the center of the RRFPR is used to adjust the "baseline" fuel pressure. The recommended procedure is to disconnect the vacuum line from the RRFPR, letting it reference atmospheric pressure (i.e. neither vacuum or boost), and setting your fuel pressure to where you want to it be when you are transitioning from vacuum to boost. The thumb adjustable screw is used to adjust the rate that the pressure will rise when under boost. If it is screwed all the way in, you are definitely going to be running too much pressure, too much fuel, and possibly could damage the injectors.
No fuel pressure gauge? I'd recommend hooking one up at least temporarily so that you can get things straightened out.
Hope this wasn't a Subaru tuner shop that left you in this condition!
Steve
SteveS is offline   Reply With Quote
Old 06-27-2002, 04:44 PM   #3
HubbieScooby
Member#: 7088
Super Slow
Steve
oh no!! i have the thumb screw almost all the way out ...if i screw it anymore out the nut will fall off...i better turn that thing in.....i have the socket center screw in about half way.....i guess i should loosen that out since i am running 4.5 lbs....thanx
hugh
Old 06-27-2002, 08:39 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
hugh
no, no, the Thumb screw should be almost all the way out if you are rich. I have both my thumb screw and top screw almost all the way out and am running 38psi at idle and up to 85psi (can;t get lower for some reason) at 7psi
Eric
Eric SS is offline   Reply With Quote
Old 06-28-2002, 04:05 AM   #5
HubbieScooby
Member#: 7088
Super Slow
what really?? i'm getting two different stories here....Tom from Ludespeed said that when the screw is all the way in...it is running really rich....to lean it out is when you loosen it....can someone confirm this??
hugh
Old 06-28-2002, 01:13 PM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
hugh
That's what I said... If the screw is in, it will run richer, if the screw is out, it will lean it out.
Eric
Old 06-28-2002, 08:55 PM   #7
HubbieScooby
Member#: 7088
Super Slow
kool i'll give another whack at it...thanx
hugh
ej207 v5 swapped from vf28 to vf34 not runs rich @ idle impreziv25 Subaru Conversions 6 05-24-2007 05:46 PM
Can't stop listening to this song from Amelie.. Christoff Off-Topic 12 01-13-2007 02:46 AM
Damage from running rich? Petrus General Community 16 04-16-2006 01:27 AM
high egt's from running rich? KitchenerWRX Newbies & FAQs 12 12-01-2005 03:35 AM
Got back from dealer, now running rich!! Javier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2005 12:29 PM
