Old 10-10-2010, 03:22 PM   #1
JASWRX
Member#: 40742
Default 2002-2003 Gauge Cluster Swap from STI
Hi everyone,
I have read about 30 pages on this and have read different things which is the reason for posting this. It seems there is not a direct thread or sticky on how to take an 04 gauge cluster and put in into a 2002-2003 WRX. All the other threads are from other years and it can misleading.
I have posted the following to help people out as I am about to order a 04 STi gauge cluster.
If any if my info is incorrect, please, please let me know for me and others!
1. Buy 04STI gauge cluster (less work than 05)
2. Cut B28 wire (yellow wire with a green trace to avoid shorting out fuse in radio)
3. If you want to be able to dim, you must follow post 20 from this thread:
http://forums.nasioc.com/forums/show...dm+sti+cluster
4 . If you want Outside Temp to work instead of just reading a number in the 40's at all time, then follow this link: http://www.scoobymods.com/sti-versio...ight=sti+gauge
5. And lastly, if you want to get the Rear Diff Light to go off, you must follow this link: http://forums.nasioc.com/forums/showthread.php?t=926620
Also, if someone could post the diagram for the 2002 WRX and STi gauge cluster, it would greatly be appreciative.
Thanks,
Justin
JASWRX is offline   Reply With Quote
Old 10-11-2010, 11:17 AM   #2
BizzarBoxerXt
Member#: 77200
WRB w/BoBo trunk monkey
This is a great help thank you! I'm looking at doing the same thing for mine.
BizzarBoxerXt is offline   Reply With Quote
Old 10-11-2010, 11:29 AM   #3
BizzarBoxerXt
Member#: 77200
double post fail
Old 10-11-2010, 07:49 PM   #4
JASWRX
Member#: 40742
it is not a double post... show me where this exact info is shown for making an 04STi cluster into a 02-03WRX is all written up and organized like my post.
Old 10-11-2010, 07:58 PM   #5
WRX USA
Member#: 11192
.. VF48'd Bugeye
JASWRX - relax man, BizzarBoxerXT is the one that failed by double posting.
WRX USA is offline   Reply With Quote
Old 10-11-2010, 08:00 PM   #6
auzy07
Member#: 207036
2007 Outback 2.5i
I'm digging this thread, I'll def be using it when I decide to swap mine. Just wondering, but how much the 04 cluster set ya back?
And yea, I've looked into it too, not too many are as organized as this one, so props to you on that.
auzy07 is offline   Reply With Quote
Old 10-11-2010, 08:02 PM   #7
WRX USA
Member#: 11192
.. VF48'd Bugeye
Most of the STi clusters I have seen for sale are around $300...
Old 10-11-2010, 08:39 PM   #8
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
what about the jdm ones? i found this one on ebay...less than 300
http://cgi.ebay.com/ebaymotors/JDM-S...Q5fAccessories
scoobystas is offline   Reply With Quote
Old 10-11-2010, 08:44 PM   #9
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
^ jdm v7 sti is direct plug and play.
you just need to wire for it up read OUTSIDE TEMP - (Celsius)
* be advise its in kph *
and my prodrive cluster
bbun is offline   Reply With Quote
Old 10-11-2010, 08:48 PM   #10
WRX USA
Member#: 11192
.. VF48'd Bugeye
^ That is not a bad deal on the JDM V7....I think it is the kph-factor that makes these less desirable in the US (especially for a DD).
I like on that listing how it states "8k RPM redline !" so even if your motor has a lower redline will this cluster will magically change things?
Old 10-11-2010, 09:11 PM   #11
JASWRX
Member#: 40742
I have no interest in the JDM ones as it is not in MPH plus they do not look anything like the USDM STi ones the sweep and light up amber.
The gauge cluster runs about $330 used (give or take).... Also can someone please update this with the diagram to show the wires that need to be cut?
Old 10-12-2010, 08:39 PM   #12
JASWRX
Member#: 40742
bump bump
Old 10-15-2010, 11:21 PM   #13
JASWRX
Member#: 40742
somebody please help with providing a diagram to help people wire...
Old 06-15-2011, 04:22 AM   #14
gzarate85
Member#: 142398
03 WRX
Was doing some browsing and I remembered that I was going to do a write up of this... So rather than double post, I'll simply contribute some pics of what needs to happen. Keep in mind that I've simply cut the B28 wire to eliminate the radio fuse from shorting.
Here you go:
Remove Bezel (two screws on top and two right in front towards the bottom)
Remove screws attached to original clusterwhite tabs,)
Unplug: (there are three green connections... unplug all three):
Cut the B28 wire: (green/yellow. this will be on the middle connection harness)
Prep wire: (you can skip this and simply tape them off with electrical tape)
Reconnect the harnesses and reverse your steps on putting it back in...
Don't mean to get too thorough, but I know there are some that want all the help they can get.
gzarate85 is offline   Reply With Quote
Old 06-15-2011, 04:23 AM   #15
gzarate85
Member#: 142398
03 WRX
Here are the tools/materials I used:
Old 07-06-2013, 10:44 PM   #16
spendlove57
Member#: 361581
2002 WRX Wagon
Default Temp Mod
Does anyone have a current link for a temperature gauge fix?
spendlove57 is offline   Reply With Quote
Old 09-18-2013, 07:53 AM   #17
STiWayno
Member#: 359799
2004 Imreza WRX STi
Default Sti Cluster Swap
Hi All!
I have just swapped a JDM- sweeping type gauge cluster(180kph) for a South African - sweeping type gauge cluster(260kph).
The gauges are Identical apart from the kph. Both are off Blobeye.. Both with DCCD.
My problem is even after trimming the locating tongues(to allow my clip to slide into 260kph cluster) on the left sided(facing front of cluster) harness, the fuel gauge, temp gauge & DCCD don't work - also the ABS light stays on..
Can anyone please help with a mod for this?
STiWayno is offline   Reply With Quote
Old 01-25-2015, 08:34 AM   #18
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
I need a wiring diagram for a 2002 WRX trying to get my airbag light to turn on then off like the seat belt light for inspection purposes.
renegadeSTi is offline   Reply With Quote
Update a 2002 WRX Gauge Cluster with 2004 Cluster DamonL Electrical & Lighting 8 03-26-2010 05:04 PM
2002 wrx gauge cluster with indeglow gauges Waking The Fallen Interior/Dressup/Audio & Security 10 09-26-2009 01:04 PM
02 wrx STi gauge cluster swap DIY?? DDScooby Interior & Exterior Modification 4 10-27-2008 11:23 PM
Gauge Cluster Swap, STi in a 2002, Fuse problem MTR_Suby02 Electrical & Lighting 2 03-25-2007 03:49 AM
Gauging Interest: 2002 WRX Gauge Cluster samwY Private 'For Sale' Classifieds 1 05-14-2005 02:10 PM
