Old 06-27-2002, 06:46 AM   #1
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
Default little pieces that are needed?
wasn't sure what to search for...so here goes.
i have all the main components for my turbo setup..
t3/t4 turbo
tial 35mm wastegate
wrx intercooler (it fits)
up and down pipes with wastegate flanges already welded on
split second vc1
apexi itc
hks ssqv bov
cartech rrfpr
svx fpr
walbro gs317
oil feed
oil return(will be obtained sunday)
oil pan w/fitting(will be obtained sunday)
greddy guages (fuel pres, boost, egt)
TRUST(greddy japan) gc8 wrx exhaust 3" catback
filter
a couple mandrel bend pipes for intake and ic pipes
now here's my question..what are the *little* pieces i need in order to successfully install my setup. i have a brass t-fitting but it looks like its missing one side to the t. do i need two of these? i was looking at the ludespeed kit pics and it shows two brass t fitting with other little things.(i circled them in the pic attached) can anyone tell me which are absolutely necessary, and which have already been sub'd with the parts i listed above. thanks
-akcel
*edit* if the pic doesnt work just right click it then select 'show picture'
akcel is offline   Reply With Quote
Old 06-27-2002, 02:22 PM   #2
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Question
A little of the topic, but how did you get the WRX intercooler to fit?
For a list of items look at the 3rd page of the LudeSpeed Install direction that should give you some good info. You may want to try Baker performance for all the fittings you'll need.
seven881 is offline   Reply With Quote
Old 06-27-2002, 09:02 PM   #3
akcel
Member#: 10268
gc8 I ride ride 24s
just cut the ic to throttle body connection about 8mm and it should fit in tightly, i also unmounted the ac line right behind the ic..not disconnecting it just unbolting it from the car i noticed it fight much better
Little problems that are starting to get to me... dgsblb2 Engine Management & Tuning 4 03-23-2009 12:53 PM
What's that little .30 gasket that I need for my knock sensor? HamFist Private 'Wanted' Classifieds 0 01-12-2006 05:38 PM
Little plastic piece that holds floor mats? Rock_Strongo Interior & Exterior Modification 10 05-06-2005 03:15 PM
any carbon fiber trim kits that are replacements for the stock dash pieces? dark knight Interior & Exterior Modification 5 02-08-2002 10:13 AM
need a part # of the piece that has the vents & the hazard button on it... wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-18-2001 08:47 AM
