Old 10-10-2010, 11:35 PM   #1
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Default GSC Stage 2 cams, upgraded springs with TI retainers, stock STI valves?
I'm looking at possibly going with GSC stage 2 cams with upgraded single valve springs and ti retainers on a stock sti valve and head. Does anyone see problems using this combo? I realize I won't be getting the full potential without a port and polish, but for now this seems the most logical, and affordable option for me.
Car has a GT35r with all supporting mods. Looking at upping redline to 8k, and getting my bottom end rebuilt by Outfront Motorsports with Manley rods, CP Pistons, and ACL Bearings. All oiling upgrades (larger oil pump etc) will be made during the build.
Suggestions and comments appreciated.
Big-Sexy907 is online now   Reply With Quote
Old 10-10-2010, 11:46 PM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
I'd do the dual springs if just for piece of mind .
Otherwise sounds good.Are you going to have them close deck the block as well ?
sense of nature is offline   Reply With Quote
Old 10-11-2010, 02:44 AM   #3
berdugo
Member#: 163108
07 EuroDM STi 2.5L
I have GSC S2 with oem STI valves and PnP heads.
I tried to revved it to 8000 rpm 2 years ago, it didn't go to 8000, I had a misfire before 8k but I guess once the misfire problem is fixed it can rev to 8k with that combo.
I wish I had the money back then to buy the valves when my engine was rebuilt
berdugo is offline   Reply With Quote
Old 10-11-2010, 05:32 AM   #4
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Problem I researched is with dual springs stock sti valves are prone to failure due to increased spring pressures. If I can find a shop to install new valves in Alaska I will most likely upgrade valves, springs, and retainers.
Berdugo, are you using upgraded springs?
Old 10-11-2010, 08:52 AM   #5
berdugo
Member#: 163108
07 EuroDM STi 2.5L
yes I forgot to mention, I have dual spring and Ti retainer. I hope my valves won't break or fail anytime soon
Old 10-11-2010, 10:55 AM   #6
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
How many miles have you put on your current build?
Old 10-11-2010, 10:58 AM   #7
berdugo
Member#: 163108
07 EuroDM STi 2.5L
around 2000 miles, I don't use my STI that much, I use another car for DD but I push it when I use it.
Old 10-11-2010, 11:02 PM   #8
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
I think I'm going stage 2 cams and single springs. Hopefully that's enough for the car.
FS : Brian Crower Stage 2 Cams/Springs/Retainers DrBelmore Engine/Power/Exhaust 12 09-20-2010 06:36 AM
Crower stage 2 cams, including springs/retainers $350 240sxguy MWSOC Private Classifieds 2 08-29-2010 10:18 AM
FS-NJ: NEW STi Manley Dual Valve Spring and Ti Retainer Kit and OEM Engine Internals cynet2k Engine/Power/Exhaust 7 02-23-2009 05:01 PM
FS: Full STi Ferrea valvetrain (NEW)- dual springs, Ti retainers, exh/int valves, etc phlegmon Private 'For Sale' Classifieds 6 05-07-2006 03:24 PM
Twe stage 2 cams, valve springs/retainer , Perfect Power Pat L.I. Normally Aspirated Powertrain 14 09-26-2005 03:22 PM
