Old 10-11-2010, 04:34 AM   #1
Jsun
Member#: 160228
2004 WRX VF39
Default AEM UGEO 30-4100 and logging with Romraider
Hey guys, I have a AEM UGEO 30-4100 wideband and I was wondering how to log the wideband readings in romraider data logging. As of right now I have the tatrix cable 1.3, and i'm logging my car using romraider data logging software. My question is, from the AEM UEGO 30-4100 wideband I hooked up the power(red) and the ground(black) so far, now its my understanding that the remaining 2 wires white(0-5V output) and blue(serial output) are used for data logging. How and where would I hook up either or both of these wires (white/blue) to beable to log with romraider using my tactrix cable? thanks in advance.
J
Jsun is offline   Reply With Quote
Old 10-12-2010, 05:24 PM   #2
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
Bump for an answer to this. I just called AEM. Romraider has the ability to log the AEM UEGO, by clicking Plugins and then AEM UEGO. Problem is we need to connect either the white or blue wire onto one of the pins on the tactrix cable. Question is which one?? Help!
subydude02 is offline   Reply With Quote
Old 10-12-2010, 05:36 PM   #3
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
I had a conversation about this a while back. You can use a usb to serial cable or a serial cable and plug the wire into the correct pin ( cant remember which it is) and that will allow you to datalog with rom raider or cobb tuner aswell.
robbieshonda is offline   Reply With Quote
Old 10-12-2010, 06:21 PM   #4
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
so basically you would take the white or blue wire and hook it to the un know pin still on the serial end and then plug the usb end into the laptop. Then rom raider will recognize it? hmmm i guess i'm gonna have to do this the trial and error way. i'll keep searching in here to see if i can find where you talked about it.
Bump for help from anyone else though that may just know this or has experiance
Old 10-12-2010, 08:51 PM   #5
unknown001
Member#: 156326
2011 RA
03 bugiftw for the track
I have used the method in the uego manual to make logging with romraider possible. go to radio shack and purchase a female crimp type db9 connector. they are in the trays with all the other nerdy stuff. afaik the only way to log the uego w/o romraider is here http://forums.evolutionm.net/ecuflas...ial-cable.html with evoscan (dont flame i know its an evo site) or here http://forums.openecu.org/viewtopic....4319&start=525 with the standalone logger but good luck finding the right pigtail to make it work.
unknown001 is offline   Reply With Quote
Old 10-19-2010, 11:00 AM   #6
robbieshonda
Member#: 122306
2002 Sti PTE 6262
one of these convos from back in the day just poppe dup in either the built motor thread or the open source tuning section
Old 11-18-2010, 11:38 AM   #7
Timmay81
Member#: 161575
2002 Wagon
I run this method on my evo and it works great, but i dont see anything in that thread about a subaru. Are you saying that with evo scan you can tie the output wire of the WB to the computer then log through the tatrix cable?
Timmay81 is offline   Reply With Quote
Old 11-18-2010, 02:09 PM   #8
ogboot
Member#: 170906
psm
You get the DB9 Serial Connector from Radio Shack.
The pinout is readily available, you *SOLDER* the UEGO wires to the corresponding pins on the DB9 connector. Do not crimp.
Then, you buy a Serial --> USB adapter online. Done.
All you have to do now is hook up your tactrix and your USB connector from the UEGO and in Romraider choose the plugin. It will have a setting for the COM port just like the tactrix cable, choose the correct COM that coincides with your UEGO.
It's not that hard really.
ogboot is offline   Reply With Quote
Old 11-18-2010, 02:17 PM   #9
Timmay81
Member#: 161575
2002 Wagon
yea thats what ive been reading but it seems like nobody can get it to work worth a crap
Old 11-18-2010, 02:33 PM   #10
ogboot
Member#: 170906
psm
that's how I log it, works great. I'll have the UEGO connection drop out 1 log out of 50. I used the pinout included with the UEGO.
Old 11-18-2010, 02:48 PM   #11
Timmay81
Member#: 161575
2002 Wagon
thanks man, appreciate it, what version of romraider are you running
Old 11-18-2010, 05:34 PM   #12
ogboot
Member#: 170906
psm
I'm running the latest build on windows 7 64bit.
Old 11-18-2010, 05:42 PM   #13
Timmay81
Member#: 161575
2002 Wagon
perfect thats what ill be using, thank a ton man
Old 11-18-2010, 05:46 PM   #14
jaybirde978
Member#: 207868
95 Impreza STI
Sedona Red
Default directions
I got this out of the manual from my wideband,this explains what todo::
Serial Output
The serial output can be used for data logging when an EFI system is not accessible. To run the data stream, a RS-232 (DB-9) Female Receptacle shall be purchased.
1 2 3 4 5
6 7 8 9
Figure 5
Wire View of RS-232 (DB-9) Male Plug Two wires need to be connected to a RS-232 serial port. The BLUE wire from the AEM UEGO Gauge shall be connected to Pin #2 (RX) on the serial port for receiving data. Page 7 Pin # 5 (GND) on the serial port shall be grounded. If a standard 9-pin serial cable is to be cut instead, the (RX) wire is typically RED and the (GND) wire is typically GREEN. However, this should be confirmed with a continuity tester before attempting.
(Figure 5)
Use HyperTerminal for testing the data stream. This software is found on most PCs. To find HyperTerminal go to: Start | All Programs | Accessories | Communications | HyperTerminal. Name the New Connection and click OK. Set the COM port to the one being used and click OK.
Bits Per Second = 9600
Data Bits = 8
Parity = None
Stop Bits = 1
Flow Control = Hardware
Verify the settings above and click OK. When power is supplied to the AEM UEGO Gauge, AFR (or Lambda) data will be displayed, as shown below. (Figure 6)
Figure 6
Data logging with Hyper Terminal UEGO Sensor
If attempting to route the UEGO Sensor through a tight space, AEM recommends temporally removing the light grey latch from the Bosch connector, as shown below, or, routing the smaller six pin connector through the hole.
jaybirde978 is offline   Reply With Quote
Old 11-18-2010, 10:36 PM   #15
unknown001
Member#: 156326
2011 RA
Not on subies i was stating that there are different ways to log a uego on a subaru other than with romraider.
Why would you *SOLDER* a crimp style connector? http://www.radioshack.com/product/in...ductId=2103806 Radio Shack also sells the *PROPER* crimp tool for the job. It wouldn't fit in the female connector of the DB9 plug if it had a glob of solder where the wire slides in the connector. I have made a half dozen of these and logged one for over a year without any issues.
Old 11-19-2010, 09:36 AM   #16
ogboot
Member#: 170906
psm
I wouldn't *SOLDER* a *CRIMP* style connector... I would get the correct connector in the first place. Crimps fail, there are many things that you do under the dash where soldering is highly recommended. If you have "globs" of solder then you're doing it wrong, but if you like crimps that's fine. My UEGO used to be crimped, because I was in a hurry to get it installed. It held for about a year, then the ground crimp wore out; I had to get back under there and solder it all together anyway. Now it's a much cleaner install and I know I don't have anything to worry about. Do it once, and do it right.
Good luck OP, you shouldn't have any trouble getting your UEGO logging for you in no time regardless of how you connect it.
Old 11-22-2010, 12:41 PM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
if you're not comfortable with all that you could just try this cable
http://www.bustedfingermotorsports.com/aem.html
Old 11-22-2010, 12:54 PM   #18
Timmay81
Member#: 161575
2002 Wagon
good link!
Old 11-22-2010, 09:31 PM   #19
ogboot
Member#: 170906
psm
Good call on BFM, seeing a need and filling it.
Old 12-23-2010, 10:19 PM   #20
skates04
Member#: 264658
2002 WRX Wagon
This is what I did for about 20 bucks.
Amazon.com: StarTech.com - Serial adapter - DB-9 (F) - RJ-45 (F): ElectronicsAmazon.com: StarTech.com - Serial adapter - DB-9 (F) - RJ-45 (F): Electronics
The back side is a connection for a ethernet cable, I just cut it off and ran the wires out the back.
Amazon has the serial to usb adapters pretty cheap as well,
Amazon.com: TRENDnet USB to Serial Converter TU-S9 (Blue): ElectronicsAmazon.com: TRENDnet USB to Serial Converter TU-S9 (Blue): Electronics
Works great, I'm logging with a UTEC with the UTI from jeffsoftware.
The serial wire from the UEGO goes to pin 2 and a ground wire to pin 5 as stated above.
skates04 is offline   Reply With Quote
Old 03-08-2012, 11:11 PM   #21
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Awesome, I was looking for this info on which cable goes where to the db9 female connector. I'm hoping I have better luck logging with this instead of the LC-1 I have, I have not been able to hook to RR so I gave up on it. I'm gonna need it for my next tune!
punchjamesarnol is offline   Reply With Quote
Old 03-09-2012, 06:47 AM   #22
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You could have just read the owners manual for your wideband. But your search bumped a semi-quality thread.
Black94Snake is offline   Reply With Quote
Old 10-24-2013, 09:39 AM   #23
TurboRex
Member#: 8635
04 STI, 07 FXT
I bought the AEM uego and wired the serial to usb cable. I can't see any data on rr. It is like rr does not recognize any com link. When I click on the com link on rr there is nothing there. Any advice what to do?
TurboRex is offline   Reply With Quote
Old 10-24-2013, 10:15 AM   #24
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
http://www.romraider.com/forum/topic4857.html
nmlittlebigman is offline   Reply With Quote
Old 05-16-2014, 02:29 PM   #25
fizay
Member#: 64011
BUMPING for a bit of feedback!
Been searching here and there, but haven't found any information specific to my issue.
30-4100 itself reads and responds fine. Wired a serial port with ebay serial-USB2 cable. When plugging into the port, there's data being fed, but most of the time, under a minute into live reading, something hangs, and all that is reported is the last value before the hang. Gauge itself is still reporting accurately, it's just the RR log will show the last good value.
Anyone have a similar experience?
I have messed with different USB ports and the receive/transmit buffer. Seems like a lower transfer rate helps delay the eventual hang, but I haven't messed with any other settings.
fizay is offline   Reply With Quote
Trouble Logging with RomRaider mr.four Open Source Reflashes 13 02-11-2010 08:00 PM
My first log with romraider jacksonjrs Open Source Reflashes 15 11-29-2009 06:51 PM
Can't Log with RomRaider KUrex Open Source Reflashes 2 05-19-2009 08:19 PM
Logging With Romraider 06 wrx lagodcm Open Source Reflashes 4 01-15-2009 09:02 PM
AEM UEGO for tuning and logging with Enginuity clemsonteg Commercial ECU Reflashes 0 10-01-2007 04:03 PM
