Old 10-11-2010, 06:43 PM   #1
Ools
Member#: 177894
99 2.5 RS
Default flat spot in powerband
so i have a 99 rs with an 05 rs longblock.
it still has the 99 rs manifold, egr has an oil pan bolt on it.
my problem is a spot on the rev range from 3600 to 4250 where there is a loss of torque that is huge, it pulls till 3600, where it bogs and then it takes off again at 4250.
what could be causing this?
Ools is offline   Reply With Quote
Old 10-11-2010, 07:11 PM   #2
GrundleJuice
Member#: 165749
sure that the longblock isn't an 06 with the AVLS? failing O2 sensor causing CL/OL switching delay? Any CEL history?
GrundleJuice is online now   Reply With Quote
Old 10-11-2010, 09:44 PM   #3
Ools
Member#: 177894
99 2.5 RS
it came with the aluminum manifold, and is from an auto. i don't know for sure if it has the alvs heads, but since i was told it was an 05 i would assume not.
but then again i was told it was from a manual and i got it with a flexplate.
the most recent CEL i had was a knock sensor, and it happened when standing water from the last rain got in there.
i just replaced both O2 sensors with nippon densos approximately 10k ago, and ever since my exhaust tip hasn't had soot on it, so i'm guessing that they are still working.
it is possible that something is causing the CL-OL delay.
Old 10-12-2010, 12:28 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The combustion chambers and pistons are slightly differently shaped. The intake manifold is VERY different (if you're using that off the 05 as well). In all likelyhood, your stock tune is simply really ****ing bad for the block it was never designed for.
Old 10-12-2010, 12:33 AM   #5
Ools
Member#: 177894
99 2.5 RS
i kept the stock manifold.
i wonder if i can get it tuned and still pass smog.
Old 10-12-2010, 04:43 PM   #6
Ools
Member#: 177894
99 2.5 RS
still occurring, anyone have any thoughts?
Old 10-12-2010, 04:53 PM   #7
Back Road Runner
Member#: 60082
2004 Forester STI
A tune will fix the issue.
Old 10-12-2010, 05:36 PM   #8
vicious_fishes
Member#: 158864
2003 SOHC destroker
it's the cam profile. i have the same thing, although my hole is from about 3300-4100.
vicious_fishes is offline   Reply With Quote
Old 10-12-2010, 08:59 PM   #9
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I had the problem with my MAF. Clean yours.
XanRules is offline   Reply With Quote
Old 10-13-2010, 01:39 AM   #10
Ools
Member#: 177894
99 2.5 RS
thanks for all the suggestions guys.
i'll first clean my maf again, and if that doesn't fix it, i'll try other alternatives.
interestingly though, when it isn't completely warmed up the problem does not persist, but i think it may be because i'm not as hard on it when it's still a little cold.
Old 10-15-2010, 03:13 AM   #11
bhilly82
Member#: 254417
09 Impreza
Peperika
A bad Knock sensor will cause this, or you could have knock.
bhilly82 is offline   Reply With Quote
Old 10-16-2010, 07:01 PM   #12
Ools
Member#: 177894
99 2.5 RS
during the last rain, a little water got under the knock sensor causing a CEL.
but i reset it and it hasn't come back.
this power band flat spot isn't as bad as it was when the light came on, but it is close.
could the knock sensor be bad without throwing a CEL?
Old 10-16-2010, 10:46 PM   #13
renyo
Member#: 93577
98 Impreza
I had a knock sensor that was bad and it intermittenly threw a CEL. Either that or the test for the knock sensor takes awhile. It cleared it once itself. Another couple of times I reset the ECU and it took a week or two to come back on. (The car was driven everyday to, so I doubt the knock sensor tests would take that long to finish).
renyo is offline   Reply With Quote
Old 10-19-2010, 06:09 PM   #14
bhilly82
Member#: 254417
09 Impreza
Peperika
yes it could. what can happen is it picks up knock or what it thinks is knock and pulls timming, or you could have a real knock problem.
Old 10-20-2010, 06:34 PM   #15
Ools
Member#: 177894
99 2.5 RS
next tank i will run premium grade and see if that makes a differance.
Old 10-20-2010, 09:58 PM   #16
vicious_fishes
Member#: 158864
2003 SOHC destroker
it won't.
Old 10-21-2010, 03:38 AM   #17
bhilly82
Member#: 254417
09 Impreza
Peperika
Originally Posted by vicious_fishes View Post
it won't.
It will if he has actual knock but if you don't then it could be the sensor.
Also do you have any piston slap or valve train noise? If so the sensor could be picking up that as a knock.
Old 10-22-2010, 04:22 PM   #18
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
When my knock sensor went it pretty much gut-punched the car. Could re-set it, but it would always set the code again after a day or two---you'd feel the car lose power the the exact moment the light came on. Given how much better the car felt with the new sensor, it must have been going for a while before it was bad enough to set the code.
motohippy is offline   Reply With Quote
Old 10-26-2010, 04:17 PM   #19
Ools
Member#: 177894
99 2.5 RS
it is a subaru, so valve train noise is a given, but no piston slap.
the problem seems to have resolved itself, but if it returns, i will revive this thread.
Old 11-24-2010, 01:57 AM   #20
Ools
Member#: 177894
99 2.5 RS
problem came back, so i put premium fuel in and it went away........
anyone got any ideas?
Old 11-24-2010, 01:58 AM   #21
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
If octane affects it, it's knock.
Old 11-24-2010, 02:00 AM   #22
Ools
Member#: 177894
99 2.5 RS
thanks for the quick response.
i thought as much, but maybe the knock sensor is bad?
it seems unlikely....
maybe there is carbon buildup raising the compression...
Old 11-24-2010, 02:02 AM   #23
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
A bad knock sensor won't respond to changes in fuel. Octane making it better means it's real knock.
Old 11-24-2010, 02:49 AM   #24
Ools
Member#: 177894
99 2.5 RS
what could be the cause other than the intake, engine, ecu combination?
carbon buildup on heads? bad PCV? any ideas?
Old 11-24-2010, 02:50 AM   #25
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Oil recirc
carbon buildup
changing AFR
changing compression
I wore a flat spot in my tires, what should I do ? SubyNewbie Mid Atlantic Impreza Club -- MAIC 36 10-19-2005 06:55 PM
how to kill the flat spots in powerband? MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-25-2005 10:00 AM
Hunting for Idle? Flats Spots in Torque Curve? Costas Normally Aspirated Powertrain 0 08-23-2003 10:42 PM
Flat spot in acceleration!!!!!! grrrrrr! SubieRacer Technical Forum Archive 29 05-23-2000 12:01 PM
