Old 06-27-2002, 11:11 AM   #1
gravel
Member#: 11962
SILVER
Default filtration specs of oem filters
Does anyone here happen to know what the filter specs are for oil and fuel filters for the WRX?
ie, filters down to what particle size (eg 10 micron) and required flow/pressure drop numbers?
I'm considering the oil filters from CM that have a replaceable filter element within a reuseable (sp?) housing and also considering the same type of fuel filter, but just want to make sure the specifications are at least the same, if not better.
Thanks
gravel
gravel is offline   Reply With Quote
Old 06-27-2002, 05:16 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Id say you would be better off looking for info on the standar purolator part, the subaru one is an oem of this unit.
Some subaru filters even have the purolator name directly on them.
FilterDot - Snap-on magnetic filtration for your oil filter juvenescence Service & Maintenance 5 07-24-2009 09:44 PM
STI TMIC/ GT-Spec Splitter/ OEM Parts of 2003 WRX gfulk1661 Tri-State Area Private Classifieds 39 08-19-2008 09:07 AM
FS: STI TMIC/ GT-Spec Splitter/ OEM Parts of 2003 WRX gfulk1661 Engine/Power/Exhaust 43 08-19-2008 09:07 AM
Wanted: WRX 04 OEM case of oil filters Jay04WRX Private 'Wanted' Classifieds 9 04-02-2008 09:41 AM
Where to buy lowest price of OEM oil filter? dcwrx2 Service & Maintenance 41 05-17-2007 12:35 PM
