Old 10-11-2010, 06:17 PM   #1
nitro1956
Member#: 230682
Default Piston Slap 02-94-05R
My 2003 Outback is great, except for piston slap.
.......anyone have experience with using 12006AC910/12006AC920 pistons to elminate piston slap ?
........anyone have Bulletin 02-94-05R which describe the use of these pistons for piston slap correction ?
.....Thanks
nitro1956 is offline   Reply With Quote
Old 10-11-2010, 11:40 PM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It's not that simple for you. I'm assuming you have a 03 Outback with the 2.5L NA motor, not the Outback Sport (part numbers for pistons are different between them).
Depending on which destination code your car is, the piston part numbers vary. However, for each destination code, there are Standard A, Standard B, Oversized 0.25mm, and Oversized 0.50mm pistons available. However, neither of the part numbers you list apply to your model year.
To do the repair properly, you'll need to split the block and examine the cylinder walls. Depending on how severely the slap has damaged the walls, you'll have to do a greater or lesser overbore to remove the damage. Once you have a rough guess of how much overbore you'll require, then you order either the OS.25 or OS.50 pistons correct for your car and destination code. Once the pistons arrive, you give the pistons and the block halves to a machine shop who will then bore and hone your block to match your pistons.
Old 10-12-2010, 09:18 AM   #3
nitro1956
Member#: 230682
......I have the "regular" Outback SW, not the Outback Sport.
The 12006AC910/12006AC920 pistons I've been told are 0.06mm oversize.
....If these piston part numbers are not for my
2003 "regular" Outback SW, then what are the analogous piston part numbers for A and B 0.06mm oversize pistons for my wagon ??
Old 10-12-2010, 05:39 PM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
12006AC080 for Standard B
12006AC090 for Oversized 0.25mm
12006AC100 for Oversized 0.50mm
Keep in mind you'll need to bore and hone the block with any of the oversized pistons.
What Piston to use to replace piston slap brett-01 Normally Aspirated Powertrain 18 12-20-2011 06:19 PM
Piston slap after I changed pistons to Arias forged pistons tomoking Service & Maintenance 9 11-06-2003 08:48 AM
Piston Slap Question Kachukaa Normally Aspirated Powertrain 7 06-29-2001 01:08 PM
Piston Slap Quesiton Kachukaa Legacy Forum 3 06-29-2001 10:53 AM
MY '98 Piston slap problems Rovah Normally Aspirated Powertrain 5 11-27-2000 04:53 PM
