Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 06-27-2002, 11:21 AM   #1
pico
Member#: 5254
01 WRX
Default Will a check engine lit cause by bad spark plug and plug wire?
My friends sunfire got a check engine lit, the dealer replace the head gasket but it's still on. They said she needs to replace the wire and plug as well. Is that true?
pico is offline   Reply With Quote
Old 06-27-2002, 11:25 AM   #2
krave
Member#: 13908
2002 WRX Sedan
296 whp
i doubt the wires are a problem, but changing plugs won't hurt...what you really need is an obd2 scanner to pull up the code
krave is offline   Reply With Quote
Old 06-27-2002, 12:06 PM   #3
SilverBoosted
Member#: 7764
11 Edge Sport
Kona Blue Metallic
If you have a bad plug/wire it can cause a misfire which will trigger a check engine light.......
SilverBoosted is offline   Reply With Quote
Old 06-27-2002, 12:07 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
If the CEL is being caused by say a misfire, then plugs and wire certainly could be suspect.
EDIT: Looks like SilverBoosted and I are thinking the same thing
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.deniedmywarranty.org
Old 06-27-2002, 12:17 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Depends on what year the car is. If it's pre-OBDII (95 or earlier) there is no misfire detection, although if the wires/plugs were bad enough that there was no spark in the cylinder at all the resulting richness at the 02 sensor could trigger a code and turn on the light.
Old 06-27-2002, 02:12 PM   #6
pico
Member#: 5254
01 WRX
The mechanic told her that her car has a bad o2 sensor, thus causing the leake of the head gasket. Also he find out that the wires and plug are need to be changed. Her car has 47K miles on it, so I do believe that it's time to change the spark plugs. But isn't the wires suppose to last much longer? BTW her car is 1998, so theres possible that both the plug and wire will cause the check engine light?! If she keep driving with the bad plugs and wires, will it cause a big problem? thanks
Old 06-27-2002, 02:19 PM   #7
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
I'm sorry to be the bearer of bad news, but if the mechanic told her or you that a bad O2 sensor caused a head gasket to blow, find a new mechanic . That's kind of like saying a worn shifter synchro caused your wheel to fall off .
Brian
Old 06-27-2002, 04:57 PM   #8
Chuck H
Member#: 20442
KTR tuned 2003 WRX
VF34 equipped, 270 whp
I was about to say something similar. The bad O2 sensor could cause the car to run lean or rich, triggering codes, but wouldn't cause a head gasket failure. And if she paid for a headgasket replacement just because her check engine light was on, she should get a lawyer and sue the mechanic.
To answer the general question, yes, bad plugs and/or wires can turn on the check engine light with a misfire code. In Neons (which I'm most familiar with), there are some other odd things that can trigger a misfire code, including broken or worn valve springs.
47K is a LOT of miles for spark plugs. Changing them every 20K miles or so is cheap insurance to keep the car running well. And changing the wires every 30,000 to 40,000 miles never hurt either. Plugs and wires are cheap so why take chances.
Chuck H is offline   Reply With Quote
Unknown wire that's causing check engine light!! Sho_Tuned_GC8 Newbies & FAQs 4 03-29-2010 03:25 PM
Check Engine light + Spark Plug problem elum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-14-2004 03:06 AM
Check Engine Light can be triggered by external elements! ezatnova Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 03-27-2003 08:36 PM
how eliminat the check engine light due to a high flow exhaust or a catless exhaust minisiu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2002 03:28 AM
