Welcome to the North American Subaru Impreza Owners Club Sunday April 20, 2014
Old 10-11-2010, 09:41 PM   #1
lavid2002
Member#: 226864
2005 PSM WRX
18.5lb. 93 oct, DP, UP
Default Bigger wheels or lowered suspension to get rid of wheel gap?
I dont have the money for something like this right now, merely tossing the idea around, maybe a good spring project.
Anyways... I want to get rid of most of my wheel gap.
*Want*
Cleaner looking car
Less wheel gap
*Do Not Want*
A slower car
A car thats going to rub everywhere
To have to roll my fenders
So whats my best option? Should I look around for some 18" wheels (2" more than my stock 16") Will these bigger wheels make my car noticeably slower? How do they work with the speedometer too do I have to change something so that reads correctly? A larger diameter tire means the RPMistance traveled ratio would be offset and make my speedometer read conservatively right?
Or should I lower the car?
Which one can be done cheaper? If lowering the car is just a set of springs I would consider that sooner. But I need to do a whole kit like shocks and springs I think that would be well out of my budget.
Thanks guys.
-Dave
lavid2002 is offline   Reply With Quote
Old 10-11-2010, 09:44 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
d00000000d...ya needs da dubs....dubs is IT
Old 10-11-2010, 10:03 PM   #3
spinnaker226
Member#: 214359
youve got the right idea...but generally 18s are a little too big for our cars, unless youre into herrafrush
spinnaker226 is offline   Reply With Quote
Old 10-11-2010, 10:06 PM   #4
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
by the time you buy new wheels and tires for said 18" wheels.
you could easily have some Dspecs struts and springs AND have a better riding, better cornering car.
I vote for Dspecs and pick your springs
and yes, 18's are noticeably slower than even the stock 17's on my STi.
They would make the WRX even slower. unless you get some te$as money wheels that are lite... but then you go talking about a budget...
pauli18c is offline   Reply With Quote
Old 10-11-2010, 10:06 PM   #5
Snow Drift
Member#: 75071
'11 WRX Ltd Nav 4dr
Lightning Red
To reduce wheel gap you must get SPRINGS. Larger rims and stock springs will make the gap LARGER.
For your 05, get Eibach Pro Kit Springs. I had it on mine and it was great.
Stock Springs w/ 16s
Stock Springs w/ 17s
Eibach Pro Kit w/ 16s (winter mode)
Eibach Pro Kit w/ 17s
Eibach Pro Kit w/ 18s
Old 10-11-2010, 10:09 PM   #6
SleepyWeasel
Member#: 192060
2004 WRX
Not to be a jerk, but this belongs in Newbies and FAQs, NOT general community.
Second, 18" wheels don't really get rid of wheel gap.... typically the tire height is lower... so if you go from the stock WRX 205/55/16 to a 215/45/17 notice the middle number goes down? So that 17" wheel example doesn't change the wheel gap at all. The diameter of the tire/wheel is almost exactly the same
If you were to stay with a relatively medium profile tire on an 18 inch wheel, your wheel gap would decrease. And your speedo would read lower than the speed you are actually traveling. And your acceleration would decrease.
Simplified answer: you are looking for lowering springs. Somewhere on this forum is a chart with drops. Most people will suggest you don't drop it too much, especially on stock shocks, they will die quickly if you don't listen...
chart: http://forums.nasioc.com/forums/showthread.php?t=695688
Last edited by SleepyWeasel; 10-11-2010 at 10:09 PM. Reason: added link for chart w/ drops :)
SleepyWeasel is offline   Reply With Quote
Old 10-12-2010, 07:08 AM   #7
lovin' it
Member#: 236710
2010 WRX Five Door
WRB!
I say lower it.
lovin' it is offline   Reply With Quote
Old 10-12-2010, 07:40 AM   #8
lavid2002
Member#: 226864
2005 PSM WRX
I have new (Spring) tires on my wheels anyways and I kind of like the way they look, so I am glad keeping them is the best option.
Thanks guys
-Dave
Old 10-12-2010, 12:08 PM   #9
skimobile
Member#: 92114
03 WRX (Neon Blue)
Garage Dust Collector
I run 18 X 8 SSRs and they fit fine inside the fenderwells with no rubbing issues.
However, a larger wheel requires a lower profile tire to keep the outer circumference the same (and not throw off your speedo, etc.).
This will not help with wheel-to-fender gap. For that you need springs/coilovers.
skimobile is offline   Reply With Quote
Old 10-12-2010, 01:00 PM   #10
RaineMan
Member#: 256727
2007 2.5I Wagon
Personally, split the difference. Go with 17's and a slight drop. The 17's will be lighter and cheaper than 18's and you can run a tire with a bigger sidewall, which equals a smoother ride. Generally a drop of an inch or so can be achieved with springs and you won't have to replace your struts.
RaineMan is offline   Reply With Quote
Old 10-12-2010, 01:20 PM   #11
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
this guy has the right idea
happs subi is offline   Reply With Quote
Old 10-12-2010, 02:06 PM   #12
ToxicCrucible
Member#: 254200
2008 WRX - 316hp
Rally Blue
lower it, unless you slam in West Side style your car wont be slower. It will actually handle better
ToxicCrucible is offline   Reply With Quote
Old 10-12-2010, 02:20 PM   #13
svynx
Member#: 210371
2002 wrx wrb
converting money into fun
D-specs and RCE Yellow or RCE Blacks (slighty softer than the yellows) would be my suggestion. Having the stiffness adjustable is great. I ride with a stiffer setting, but if my better half and I go on a trip, I can tune it down and have a near stock feeling.
svynx is offline   Reply With Quote
Old 10-14-2010, 10:27 PM   #14
lavid2002
Member#: 226864
2005 PSM WRX
^ That setup is way too expensive for me. I am looking to spend 200 or less to drop my car an inch or so for a cleaner look. I would like this to help the handling while I am at it too, I wont do it if performance will suffer.
Possible?
Old 10-14-2010, 10:37 PM   #15
mobomelter
Member#: 258480
2002 ECT0 1X
Possible?
Provided you're ok with just using lowering springs.
mobomelter is offline   Reply With Quote
Old 10-14-2010, 10:42 PM   #16
spinningcain
Member#: 176490
2005 STI
Just do both I am lowered on Epic springs with 18"s looks sweet
spinningcain is offline   Reply With Quote
Old 10-14-2010, 10:52 PM   #17
urabus its 40
Member#: 77035
2004 STi - Dom 3xtr
w/ wooden wheels
I also run SSR 18x8 with 235/40/18 and i love them. Only rubbing occurs at full turn with uneven surface. I have coupled those with TEIN Flex coilovers and the end result is very good looking. Also if you get decent wheels, you should not have a noticeable difference in acceleration, just dont buy heavy wheels ( check the weight before you buy). Also keep in mind, you can do it in steps. it might take a while but over about a year maybe you can have the complete package you want.
urabus its 40 is offline   Reply With Quote
Old 10-14-2010, 11:59 PM   #18
lavid2002
Member#: 226864
2005 PSM WRX
Everyone seems to love their epic springs. I think I might grab a set myself. : )
Old 10-15-2010, 07:22 AM   #19
svynx
Member#: 210371
2002 wrx wrb
Possible?
The way I see it, if you go cheap on something like this, you end up buying the more expensive parts later on. Might as well get the "better" parts first. I'm really picky when it comes to suspension. I've done suspension work on 4 different cars. I think I spent more on the first one because I tried to go cheap on the first round. When the parts started to rust and break, I bought a mid grade. They didn't work well. I finally bought a higher end setup. Stayed with that until I sold the car.
Having said that, to each his own. You could find a set of lowering springs and use the stock struts. Just make sure that the struts can handle them. There are quite a few springs out there that are designed for aftermarket struts only.
Old 10-15-2010, 09:59 AM   #20
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Bigger wheels don't reduce wheel gap.
Byzantium is offline   Reply With Quote
Old 10-15-2010, 12:09 PM   #21
sc00by4life
Member#: 97135
Possible?
You probably should just stop thinking about this idea then.
Seriously. If you cant afford to do it right, don't even bother.
Old 10-15-2010, 12:28 PM   #22
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Possible?
With $200 you CAN find a decent set of used springs. But then you still need to get re-aligned, and your struts won't likely be very happy. I would wait until you can afford at least some replacement struts (kyb gr2's) or you will be paying for an alignment twice. Just some numbers for you: $200 on springs, $350 on struts (I think), and $80 on an alignment. That puts you at about $630 for lowered car that handles pretty good. If you add some camber bolts (another $30) and get a performance alignment (like $20 more than a regular alignment), you will have a much better handling car that imo has a more aggressive stance.
Old 10-15-2010, 12:37 PM   #23
spinningcain
Member#: 176490
2005 STI
Ive been running the Epic springs for over 2 years on stock struts.. No issues yet....
Old 10-15-2010, 12:45 PM   #24
dirty_sanchez
Member#: 111682
1981 Yugo hatchback
H tech springs, KYB GR2 or Tokico blues, and 225/45/17 tires will put you where you want to be and still maintain probably the balance I can think of between cost and performance.
Going 2 inches with just one or the other (18" wheels with stock suspension or 2" lowered suspension with stock 16" tires and wheels) will be all wrong in both looks and performance.
dirty_sanchez is offline   Reply With Quote
Old 10-15-2010, 01:20 PM   #25
brianha42
Member#: 193148
2006 WRX Wagon
epic is what i'm running and i love the look on a 45 tire.
brianha42 is offline   Reply With Quote
getting rid of wheel gap on 02 bugeye wrx filipin0y Brakes, Steering & Suspension 8 08-01-2009 02:36 PM
FS: Wheels and tires - Need to get rid of 'em... Please BUY :) onoitsawrx MAIC Private Classifieds 11 05-18-2008 10:03 AM
Trying to pick springs to get rid of wheel gap cmac23 Brakes, Steering & Suspension 2 09-18-2007 09:06 PM
need to get rid of wheels,sti shifter trim, 05fogs with switch/relay and 27LCD TV,etc silver-RS Tri-State Area Private Classifieds 26 07-24-2007 04:18 PM
springs to get rid of front gap and not ride rough? csacom Brakes, Steering & Suspension 26 09-13-2004 02:20 PM
