Old 06-27-2002, 12:01 PM   #1
phast
Member#: 7957
Default High Altitude Track times
I took my wagon back to Bandimere Speedway in Denver, CO last nite. Elevation at the track is 5800ft above sea level.
I ran a [email protected] to start off the night, then hit a 13.7(misshift), and a 13.5.
For my last run, the stars aligned perfectly and everything fell into place. Here's the times....
r/t .918 <-- no.. i dont bracket race
60' 1.889
330 5.439
1/8 8.441
mph 82.12
1000 11.031
1/4 13.24
mph 102.21
Feel free to plug it into the NHRA correction factors. I personally don't like them.
This is basically a Stage4 car with a Link in place of a Unichip. Interesting what a little elevation does to the 1/4mi times no?
-jay
phast is offline   Reply With Quote
Old 06-27-2002, 12:22 PM   #2
norseone
Member#: 16350
B8.5 Audi S4
Default Elevation.
So you are saying that the elevation helped your times? I am confused. I was under the impression that the air at higher elevations is thinner. Making it harder for the engine to produce power? Can you shed some light on the subject for me?
BTW Good times though, but with a stage 4 setup, shouldnt your times be faster?!?!
N.1
norseone is offline   Reply With Quote
Old 06-27-2002, 12:37 PM   #3
VetteVert
Member#: 5961
2005 STi
CGM
Default Re: Elevation.
You are making his point....
Of course his times are a little slow...he's at 5800 feet!...which was (IMO) his point. Take a mid-high 12 second car to the top of a mountain and viola, low 13 second car.
VV
N.1
VetteVert is offline   Reply With Quote
Old 06-27-2002, 12:41 PM   #4
phast
Member#: 7957
Correct.. that altitude basically sucks. On a lighter note, several stock Z06's couldn't muster their way out of the 14s on the same track last nite. Maybe that will help the comparisons a bit.
Old 06-27-2002, 12:45 PM   #5
norseone
Member#: 16350
B8.5 Audi S4
Default Re: Re: Elevation.
VV
Yeah thats what I thought. But the nature of his post made me think that he was expecting better! BTW Phast no worries man. I can imagine what you would run at sea level!
-N.1
Old 06-27-2002, 12:54 PM   #6
norseone
Member#: 16350
B8.5 Audi S4
Yeah Rocky mtn Raceway in Salt Lake is where I will be going. I have yet to go(I am away for the summer) and the elevation is 4500 feet or something like that. So I am not expecting much.
BTW my girl went last week and was telling me that an RSX made 10's! I said no way, especially at that altitude! I cant imagine what you would have to do to a car to make 10's at such high altitude. Esepcially an RSX.
N.1
Old 06-27-2002, 01:01 PM   #7
VetteVert
Member#: 5961
2005 STi
CGM
Is it an 1/8th mile track? That's all we have around here
VV
N.1
Old 06-27-2002, 01:02 PM   #8
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
it helps, but just to add NA cars suffer MUCH more than boosted cars by altitude.
I've heard all about the 15 second C5's. I would just buy a big SUV and be done with it. On the bright side though, a moded (or even stock!) WRX would own most of the V8 cars out there (non-boosted).
-C
TypeC is offline   Reply With Quote
Old 06-27-2002, 01:22 PM   #9
norseone
Member#: 16350
B8.5 Audi S4
VV
LOL! Thats the first thing I asked her. But its a 1/4. She thinks she knows everything. Like most women , who knows though.
-N.1
Old 06-27-2002, 01:54 PM   #10
NickV
Member#: 12084
1993 Eagle Talon
Red, [email protected]
Good time jay.
I plan on doing some low low low low 11s up here now with my new gt30.
NickV is offline   Reply With Quote
Old 06-28-2002, 01:20 AM   #11
WRX Harvey
Member#: 13025
1998 RS-T
Rally Blue
Talking I were there too
I pulled a 13.86 with Stage 0 and VF-30 combo. There was a Viper GTS there too, his best was a 13.59 C'mon up NA guys.
WRX Harvey is offline   Reply With Quote
Old 06-28-2002, 09:16 AM   #12
nmyeti
Member#: 4980
Default Re: High Altitude Track times
-jay
Jay,
Any ideas as to what the real altitude density of the track was for the night you ran?
-Nathan
nmyeti is offline   Reply With Quote
Old 06-28-2002, 11:16 AM   #13
phast
Member#: 7957
Default Re: Re: High Altitude Track times
Originally posted by nmyeti
Jay,
-Nathan
Based on memory from the weather data on my slips and pluggin those values into the calculator at http://rshelq.home.sprynet.com/calc_hp_dp.htm
My data:
Air Temperature 70 degrees F
Altimeter Setting 30 inches Hg (guesstimate.. I'll look at the slip)
Dew Point 44 degrees F
Altitude 5800 feet
resulted in:
Relative Horsepower 80.1%
Air Density 0.9676 kg/m3
Relative Air Density 79 %
Density Altitude 7855 feet
Virtual Temperature 72.1 deg F
Actual Air Pressure 24.23 inches Hg
Actual Vapor Pressure .248 inches Hg
Relative Humidity 33.5%
Dyno Correction Factor 1.249
Old 06-28-2002, 12:55 PM   #14
hotrod
Member#: 14141
2002 Impreza WRX
Default note on temps at Bandimere
Nathan, Phast:
Just a note, my experience is that the temps they post on the time slips at Bandimere are about 10 deg cooler than the actual track level temps. I think their thermometer is in the tower about 30 feet above the strip.
On my first run I had an actual temp measured at the car of 89 deg, temp reported by the time slip was 76 deg, my second run I recorded a temp at the car of 87 deg the time slip temp was 75.
As far as accuracy, I'm a severe weather spotter so I've checked my thermometer on the car, against an expensive mercury meterological thermometer and it is with in a degree or so of true unless the sun is shining directly on the side of the sensor.
FWIW
Larry
hotrod is offline   Reply With Quote
Old 06-28-2002, 02:44 PM   #15
pace
Member#: 11606
2004 Pilot
1995 Miata
Absolute Barometer quoted for our last runs was 23.38
pace is offline   Reply With Quote
Old 06-29-2002, 12:40 AM   #16
Red RS
Member#: 1433
2000 RS
SRP
i thought that the wastegate would compensate for the thinner air. right?
Red RS is offline   Reply With Quote
Old 06-29-2002, 01:22 AM   #17
pace
Member#: 11606
2004 Pilot
1995 Miata
If you assume that the same manifold pressure can be attained at this altitude from the turbine spinning faster to compensate, then it's obviously going to take much longer to reach that given boost level. Indeed it would seem there would be a much higher boost threshold also. My guess is you'd therefore see MUCH less area under the torque and HP graphs.
Somebody correct me if this assertion is incorrect.
-Pace
Old 06-29-2002, 01:53 AM   #18
hotrod
Member#: 14141
2002 Impreza WRX
Default Nope waste gate controls max boost
The waste gate controls max boost above a preset limit
This is a common misunderstanding possibly because of how turbochargers are used on some aircraft. The plumbing on some aircraft is substantially different than that used on an automobile.
On many air craft the waste gate opening changes with altitude. It starts off wide open at sea level (ie no boost) and as the plane climbs the waste gate slowly closes so the turbo gradually creates boost to _exactly_cancel_ the effects of altitude. The result is the aircraft always acts as though it is at sea level until it reaches some critical altitude where the waste gate is completely closed. At that altitude you begin to experience loss of performance as the turbo charger can no longer provide enough boost to overcome the loss of outside air pressure.
Actually this is not turbo charging but Turbo normalized to sea level performance. An aircraft with this configuration does not increase the engine performance above its basic sea level performance. This is I believe where people get the impression that a turbo completely eliminates the effects of altitude.
On a car, and in some high performance aircraft like WWII fighter planes, the turbo is set up to substantially increase the total sea level power of the engine.
The plumbing starts out like a turbo normalized plane at critical altitude. The waste gate is closed until it is told to open. As a result as soon as some exhaust flow rate is reached to spin the turbine, the compressor starts to build boost _above_atmospheric_pressure_
when you reach some predetermined boost pressure the waste gate opens so boost does not continue to climb.
In the case of the stock turbo on the U.S. WRX it reaches critical altitude at about 13,600 ft. At this altitude even if you keep the waste gate closed all the time, it cannot achieve 14.5 psi boost.
The thing a lot of people don't understand is that a turbo actually works on a pressure ratio. If the turbo is set to achieve a pressure ratio of 2:1 ( a nominal boost of 14.7 psi), then at sealevel it will create 14.7 psi boost above _local_ atmospheric pressure.
You take the same turbo to 6000 ft and run it at the same rpm to create a 2:1 pressure ratio and you will only produce 11.78 psi of boost because that is the local air pressure you are doubling (under standard conditions).
A turbochargers output mass flow is dependent on its compressor RPM and the density of the inlet gas. Higher density inlet gas, more mass flow out.
Bottom line, a turbo makes up for about 1/2 the effect of altitude.
If a NA 400 hp engine, looses 50 hp at some altitude, a 400 HP turbo charged engine (with no changes) will loose about 25 hp at this same altitude. To a limit you can dial up the boost a bit to compensate for this, but you quickly reach a point of diminishing returns. You dial up the boost by 10%, but because of loss of effeciency the turbo might only flow 5% more lbs of air even though it creates a boost pressure that looks like it should completely compensate for the altitude. ( more heating, higher rpm, more internal friction, higher exhaust back pressure etc. all cost HP )
Its just one of those no free lunch things. Turbos reduce power loss due to high altitude, but can't completely eliminate it.
Does that make any sense ??
Larry
Old 06-29-2002, 09:13 AM   #19
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Was 4EAT '02 WRX [email protected]
Default Re: Nope waste gate controls max boost
Larry
Yes, that's the best explanation I've read yet. Since I run at 4100 ft, this is a big issue for me. It also explains why the NHRA correction factors for turbo cars is half that of N/A cars, IIRC.
Padre
PadreWRX is offline   Reply With Quote
Old 06-29-2002, 10:11 AM   #20
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
hotrod,
Thanks for the information and explanation. Even I can understand it!
GoodFinder
GoodFinder is offline   Reply With Quote
Old 06-29-2002, 11:25 AM   #21
ridebmx
Member#: 20170
Default hi
hey nmyeti, i was jus wondering if your times from roswell were corrected of if thats what you actually ran? thanks
ridebmx is offline   Reply With Quote
Old 06-30-2002, 11:02 AM   #22
nmyeti
Member#: 4980
Default Re: hi
Those were my actual times.
-Nathan
Old 06-30-2002, 01:06 PM   #23
ridebmx
Member#: 20170
"Those were my actual times. "
thats very very fast.
Old 06-30-2002, 02:29 PM   #24
nmyeti
Member#: 4980
Thanks,
Some people understand, and others don't.
For the record, the night i ran [email protected] the altitude density at the track was 5800 feet.
I forget what that corrects to, but i've not been a big fan of corrected numbers for turbo cars since i don't think they are quite that accurate. However at sea level i have no doubt that i would have been faster.
Now that i've moved to Gaithersburg, and changed the setup a little bit, i am very intrested in seeing what happens now.
-Nathan
Old 06-30-2002, 02:33 PM   #25
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
So are we. Keep us posted.
Padre
High altitude owners - How do you like your MBCs? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-01-2001 11:31 AM
(sigh)...high altitude NA tuning woews ColinL Normally Aspirated Powertrain 5 05-14-2001 02:22 PM
Do our cars have to be "tuned" for high altitude? Arnie Normally Aspirated Powertrain 3 04-04-2001 09:10 AM
Lower octane at high altitude? Eric Gagnon Normally Aspirated Powertrain 2 11-29-2000 12:51 AM
0-60mph times for high altitude spshultz Rocky Mountains Impreza Club Forum -- RMIC 4 10-15-2000 07:59 AM
