Old 10-12-2010, 08:57 AM   #1
dapple
Member#: 252362
Default Forged Pistons
I have an 07STI 35K, mods GT52 turbo, CAI, TBE, 850cc injectors and protune about 340WHP. I had a problem with cylinder4 cracked piston sleeve. I had that fixed but it still smokes when I step on hard and the inside of my car smells like oil. If I drive the car hard and then let it sit and idle for about 5 mins it starts to smoke. So anyway I am thinking of getting forged pistons. What are some good brands, what kind of rings should I get and will I need to get forged rods as well? Ever since I had these mods done I have had smoking issues. I am afraid to beat on it now in fear it will really let loose. I am going to get a FMI next so they can bump me up to 23PSI boost. But I worry that if I dont get the motor built it will create even more problems after cranking up the HP. Any suggestions or help would br great
dapple is offline   Reply With Quote
Old 10-12-2010, 10:26 AM   #2
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Fix the engine
RicersWetDream is offline   Reply With Quote
Old 10-12-2010, 12:38 PM   #3
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
How was the cracked sleeve "fixed"? To my mind that is a new block period. As far as I know most machinist wont even touch an EJ block with a cracked cylinder wall as far as sleeving it...
Forged pistons ain't gonna fix your smokiness... You need to find out exactly what is the cause of the smoking and then you can chose the fix among the applicable options... Your connecting rods are already forged... as are all EJ motor rods...
'07 STI ruined, it's a G-Damn tragedy...
-soobaviator
soobaviator is offline   Reply With Quote
Old 10-12-2010, 01:42 PM   #4
al82
Member#: 177913
2011 WRX STi PBP
-soobaviator
Time for a new block...check your heads while you at it...I've read about an 07 Sti with a bad valve in one of the heads. Wouldn't hurt to check....
As far as brand of piston, do some searching on the forums about pistons
al82 is offline   Reply With Quote
Old 10-12-2010, 02:57 PM   #5
dapple
Member#: 252362
-soobaviator
Not cracked cylinder just piston and the short block was replaced
Old 10-12-2010, 03:01 PM   #6
dapple
Member#: 252362
Got a new short block but the problem is back again I mean the smoking. I was told the OEM pistons are not going to be able to handle the power and this would probably happen again. I am thinking of dumping the car but I luv it. The only thing is I am not going to sink 6K to fix this problem
Old 10-12-2010, 03:01 PM   #7
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
OK...however you did say "cracked piston sleeve". But any case a new short block right? How was it broken in?
Old 10-12-2010, 11:46 PM   #8
Lucky Strike
Member#: 196786
Here let me help you out
Since your unwilling to sink 6g in your car to fix it right.. sell it and buy a rsx type s or civic si. Problemo solved.
Lucky Strike is offline   Reply With Quote
Old 10-15-2010, 04:00 PM   #9
C4NiNjA
Member#: 91964
2003 Impreza WRX WRB
There are too many unanswered questions to even begin to start. Its smoking and you want to buy a TMIC and increase the boost.
Fix the issue or it will get very expensive fase. Was the shortblock you replaced it with new or used? Were the pistons new or used? Did you crack the ringland? If so did you check the compression on the other 3 and if so what were the numbers?
have a compression check and leakdown test on the motor asap. Should not cost ya more then 100-150 bucks. That will tell you alot.
C4NiNjA is offline   Reply With Quote
Old 10-15-2010, 04:30 PM   #10
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Did you get a retune after the first engine went. Chances are if the bad tune killed the first you have what you have now. How long have you been running the newly broken block?
kellygnsd is online now   Reply With Quote
Old 10-15-2010, 05:18 PM   #11
lcjarrett
Member#: 133814
2008 AW STI
Pistons are the weakest point EJ motors. Next are Bearings.
lcjarrett is offline   Reply With Quote
Old 10-15-2010, 07:19 PM   #12
dapple
Member#: 252362
I meant cracked piston skirt sorry still a newbie
Old 10-15-2010, 07:23 PM   #13
dapple
Member#: 252362
About 3K but been taking it easy cause it doesnt like it if I hammer it. I got a more conservitive tune now so it is ok but I want an aggresive tune next year and with the forged **** i should be ok right
Old 10-15-2010, 07:28 PM   #14
Lucky Strike
Member#: 196786
Yea homie u b aite
Old 10-15-2010, 11:45 PM   #15
kellygnsd
Member#: 32669
LINK G4 hybrid STi
So what your are saying is you didn't get a new tune right after putting the new motor in, the motor wasn't happy when you got on it with the old ****ty tune and you are wondering why you new motor possibly failed too?
Originally Posted by Lucky Strike View Post
Yea homie u b aite
He will not be aite if the same tuner is hooking him up
forged pistons -vs- OEM pistons ayreshead7 Mid Atlantic Impreza Club -- MAIC 10 10-14-2005 11:21 PM
Forged Pistons and Forged H beam Rods dynoflo Vendor 'Group Buy' Classifieds 3 01-15-2004 09:55 PM
Piston slap after I changed pistons to Arias forged pistons tomoking Service & Maintenance 9 11-06-2003 08:48 AM
forged pistons?! couldnthinkaone Normally Aspirated Powertrain 23 03-27-2001 11:27 AM
forged pistons?! couldnthinkaone Texas Impreza Club Forum -- TXIC 4 03-25-2001 10:51 AM
