Old 10-10-2010, 10:55 AM   #1
jester409
Member#: 64376
04 WRX
Default ej205 or 2.5l hybrid ???
I bought an 04 WRX with 99k that has leaky valve seals which cause it to smoke a lot. It can't be driven in its current condition, so I am pulling the motor to either just replace/rebuild heads or possibly add hybrid 2.5L shortblock at same time. I have most of the parts for a 2.5L shortblock (253 block, 255 crank, 257 pistons and rods) but would still need a few things like bearings, STi oil pump and head gaskets, plus the cost of having a machine shop assemble it. I also have a 6MT, full catless exhaust, and Cobb AP that will be installed at time of engine replacement.
Is it worth it the added cost and tuning hassle to use the 2.5L sb? Up to this point I have only driven 2.5L NA and 3.0L NA Subarus, and I would appreciate any input from those who have driven both stock 2.0L and hybrid 2.5L turbo engine cars.
This will be my daily driver so reliability and MPG are slightly considered into the equation...
jester409 is offline   Reply With Quote
Old 10-14-2010, 07:01 PM   #2
Shayhan27
Member#: 205906
05 WRX
CGM
If fuel economy is in the equasion I would still say do the hybrid with the heads CNC'd instead of the head gasket route. I would say throw in some cosworth 272's for the hell of it as I love mine but it will hurt your fuel economy.
Shayhan27 is offline   Reply With Quote
Old 10-19-2010, 06:50 PM   #3
jester409
Member#: 64376
04 WRX
I think that CNC'd chambers and more aggressive cams would probably be the best way to go. I may just get the 2.0L back together for now and over the next year build a 2.5L the right way as you are suggesting.
WTB: Stock mount turbo for '02 WRX 2.5L hybrid - looking for 18G or 20G mainly. tundra Private 'Wanted' Classifieds 8 08-08-2009 09:05 AM
Stock 2.0 ECU OK to run 2.5l hybrid? Cobb says so... Acostafan AccessPort 8 06-28-2007 05:45 PM
Who is using AP 2.0 for a 2.5l hybrid? Acostafan AccessPort 2 06-18-2007 03:14 PM
JDM EJ207 or 2.5L Hybrid? sandiegowrx Built Motor Discussion 2 09-12-2006 11:39 PM
