Old 10-12-2010, 11:39 AM   #1
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
Mineral White Metallic
Default Loud squeak
So I had my engine finished up an when the shop tried to start the car it would crank but not start. I went last night at midnight to tow the car and the builder was at the shop retiming my car. I got the car to Andrewtech this morning and as soon as he tried to start it the car started Making a very loud screeching noise from near the clutch/rear two cylinders. Any idea what that could be?
Bugeyeballa is offline   Reply With Quote
Old 10-12-2010, 01:17 PM   #2
rodknock02
Member#: 150484
2000 RShybrid35rPPG
SRP
Ya there a clutch inspections plate that usually gets bent when installin the motor.Check that and see if its hitting the flywheel.Its right above the crossmemmber with 6m bolts that hold it on .This is a very common problem.
Drake
rodknock02 is offline   Reply With Quote
Old 10-12-2010, 06:58 PM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
You are really having a rough go of this motorswap man. My sympathies go out to you.
MartinSTi05 is offline   Reply With Quote
Old 10-12-2010, 11:00 PM   #4
subi35r
Member#: 260696
when it made the noise was the car running?
subi35r is offline   Reply With Quote
Old 10-13-2010, 08:39 AM   #5
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
Yeah this has been the hardest build so far. The car was not running at the time it was only attempting to start. I will ask Andrew if that might be the problem! I pray!
Also I found out from the co-owner of the shop that the +1 mm valves I purchased were not installed in the motor, they are sitting in the shop
Old 10-19-2010, 01:44 PM   #6
subi35r
Member#: 260696
man thats not good. but i guess at least you got the valves from the co-owner. good luck with everything
Old 10-19-2010, 02:35 PM   #7
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
so what's actually IN your motor??? If you have heads built for +1mm valves, and you don't have your +1mm valves in there...what IS in there?
I read your other thread....$9K? I hate to say it, but I'd be filing lawsuit papers if I were you.
good luck....
UP2MTNS is offline   Reply With Quote
Old 10-19-2010, 05:16 PM   #8
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
Well Andrew told me today that my brand new bc 272 cams are destroyed. I do have stock valves in there not my +1 mm bc valves. Tons of stuff is destroyed
No AC and loud squeaking sound! kmwrx224 Service & Maintenance 4 01-01-2008 09:49 PM
installed Hawk Ceramic pads - 04 STi. Very loud squeaking. will667 Brakes, Steering & Suspension 15 06-06-2006 03:53 PM
Loud squeak at low speeds EJ1 Service & Maintenance 6 05-25-2004 03:40 PM
Loud squeak/creaking noise coming from differentials? JDiMpreza Brakes, Steering & Suspension 0 08-29-2002 02:17 PM
Loud Squeak From Brakes Syntax Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-17-2002 11:11 AM
