Old 10-12-2010, 01:41 PM   #1
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
Default Building motor, bigger than 100mm pistons? + where to get o-rings
My current stage 3 Raw/Axis block is being rebuilt due to oil consumption. Machine shop say the hone was far too aggressive and prematurely wore the pistons and rings. Problem is the bore was already 100mm.
Are there 100.5mm or 101mm pistons readily available?
Ive already got head gaskets, and an oil pickup. I need to get intake mani gaskets. Any other gaskets I will need?
Also, where should I get an o-ring kit? the dealer/subarugenuineparts?
xrocket21 is offline   Reply With Quote
Old 10-12-2010, 01:58 PM   #2
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
I just found this full kit, but I dont need the headgaskets...
http://www.importimageracing.com/p/S...-seal-kit.html
Also, do you need a different sice gasket for a 100mm or 101mm bore? or will stock gaskets work?
Old 10-12-2010, 02:01 PM   #3
al82
Member#: 177913
2011 WRX STi PBP
Who's building your block? Ask them what gaskets you need as we don't know the condition of your motor. If you want to be safe just but a complete gasket kit from flatironstuning.com or at the dealership...it's up to you. Goodluck with the build.
al82 is offline   Reply With Quote
Old 10-12-2010, 02:21 PM   #4
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
A local machine shop is building the block. There were 30k miles on it
Old 10-12-2010, 02:34 PM   #5
al82
Member#: 177913
2011 WRX STi PBP
Get the full gasket kit for the year of your block and the shop would use what they need. As far as bigger head gaskets, you can probably ask Josh at import image.
Old 10-12-2010, 02:47 PM   #6
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
yeah, i am pming him now
But gasket-wise, I already have header gaskets, up-pipe gaskets, head gaskets, etc. I hate to buy a $279 kit when I need about half of it.
and I am talking to Josh about what to do now. I was just looking for input.
Old 10-12-2010, 03:33 PM   #7
foolio
Member#: 9351
2006 trailblazer SS
black
Can you just hone the block again and get away with using the same pistons with new rings? I know Wisceo pistons makes some fairly large bore pistons. and if they dont have them on the shelf they will make whatever size you want. I had a customer that was in the same situation. Im fairly sure we ended up getting him 101mm pistons.
And also standard Cosworth Head Gaskets cover up to 101mm.
foolio is offline   Reply With Quote
Old 10-12-2010, 03:47 PM   #8
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
the machine shop said they would like to go bigger if possible.
Josh said he can get custom CP pistons for more money, but 3-5 weeks wait
I called the machine shop, and they said no, they would just stick with the 100mm bores, lightly machine it and re-hone it, so I guess I will stick with 100mm.
I went with the OEM headgasket, anyone see any big issue with this?
setups is 440 wheel hp, 26 psi, meth injection, garrett gt3076r.
I wasn't aware that the gasket that was on the raw block was cosworth.
Old 10-13-2010, 01:45 AM   #9
Super Nintendo
Member#: 73721
2007 STI
PTE 6266
Can you define "far too agressive" ? Was the piston to wall clearance low ?
Honestly I wouldn't consider going any further than 100mm if you plan on making more power. The more you take out of the bore, the weaker the liners will be.
Super Nintendo is offline   Reply With Quote
Old 10-13-2010, 09:45 AM   #10
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
Pm max (remotehuman) he works in the parts dept. At planet Subaru in Hanover, I'm sure he can help you figure out exactly what you need. Or you could come out to the Boston meet tonight in Braintree at UNO, he will be there.
timeXlost is offline   Reply With Quote
Old 10-13-2010, 10:36 AM   #11
foolio
Member#: 9351
2006 trailblazer SS
black
Raw Block probably didnt use Cosworth gaskets, just letting you know the gasket bore size of the cosworth ones if you wanted to use them. Stockers are probably the same I would think...
Old 10-13-2010, 10:41 AM   #12
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
Im not sure how else I can describe the hone, I am not a machinist. According to them, it was honed too aggressivly and never broke in properly and wore out the pistons and rings prematurely. I saw the cyl walls myself, and the hone marks were still quite deep after 30k miles, compared to my stock block that had 70k miles on it.
We are sticking with 100mm now. i found a thread where someone tried boring out a block more and around 103mm they started breaking through the liner.
I am suprised that the raw block started at 100mm.
Old 10-13-2010, 10:41 AM   #13
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
I physically saw the head gaskets myself and they said cosworth right on them.
Old 10-13-2010, 10:42 AM   #14
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
INteresting, thanks, I think I have a lead on the o-rings though.
I cant make it to the meet tonight, sucks i havent been in a while. id really like to get back into going, they are a lot of fun.
Old 10-13-2010, 11:27 AM   #15
foolio
Member#: 9351
2006 trailblazer SS
black
K.. I wasnt sure if Raw did or did not use them.
Old 10-13-2010, 11:42 AM   #16
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
should have been a stout motor
cosworth bearings, cosworth headgaskets, cp pistons, i think manley rods, cosworth oil baffle, cosworth oil pump, machined crank, etc
sucks it didnt last
Old 10-13-2010, 12:03 PM   #17
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
sucks it didnt last
yea thats a bummer. who is going the machine work now? im sure i asked this before...but i forget.
Old 10-13-2010, 12:28 PM   #18
foolio
Member#: 9351
2006 trailblazer SS
black
It really sucks that you dont have anyone to call and rag them out! Good luck, maybe this time around will be better then ever. Thats how you have to look at it.
Old 10-13-2010, 12:46 PM   #19
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
A local Machine shop.
Old 10-13-2010, 12:46 PM   #20
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
yeah, its been a while since I have been able to rip on it. Thing is a money pit.
at least shes pretty
Bigger wheels or lowered suspension to get rid of wheel gap? lavid2002 Newbies & FAQs 31 10-17-2010 03:28 PM
EJ20G Piston Rings, where to get them? MeanEditor Built Motor Discussion 7 04-11-2008 12:38 PM
Where to get hubcentric rings? wwiifanatic Tire & Wheel 3 04-30-2006 06:22 AM
Building a All Motor drag car.. anybody know where to get a honda shell? LargeOrangeFont Southern California Impreza Club Forum -- SCIC 46 12-04-2003 02:43 PM
Need to get new piston rings, where to get? Andrew Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-06-2002 03:00 PM
