Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 10-12-2010, 08:57 PM   #1
centeno711
Member#: 184638
2002 wrx wagon wrb
97 cummins 1ton 4x4
Default built 2.0 5k cut out
Ok motor is ej205 in a 02 wrx wagon. Sti rods arp bolts 9:1 pistons revised crank,cosworth bearings. Top end was gone through but is stock motor has 4,000 miles. Won't boost over 7 psi and it shuts down at around 5k
Obviously it needs a tune but what is causing the cutout?
centeno711 is offline   Reply With Quote
Old 10-12-2010, 11:18 PM   #2
Yint
Member#: 199751
2002 Impreza TSX
Savanna Green
Sounds like limp mode, I was having EXACTLY those symptoms when my car was running without the vehicle speed sensor. Not sure what else could be putting you in limp.
Yint is offline   Reply With Quote
Old 10-13-2010, 02:19 AM   #3
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I think you just answered your own question.
If you knock enough, the ECU will disable boost control, leaving you with wastegate boost. Depending on the turbo, that might be 7 psi.
Shutdown at 5k generally sounds like the boost limit fuel cut, but if you're only boosting 7 psi then that's not it... unfortunately I don't have any good theories on that one.
Old 10-13-2010, 11:05 AM   #4
centeno711
Member#: 184638
2002 wrx wagon wrb
97 cummins 1ton 4x4
car was back in the shop yesterday due to a bad ground, runs the same now.
I was hoping that fixing the ground would solve my problem.
So the issue is its not throwing codes that are readable. when it cuts out the cel light flashes but there is nop stored code to read.
will a data logger be able to catch it?
what i dont want is to take it for the tune and have to spend my dyno time fixing stuff. would rather have it all kosher then take it to dyno but im not sure what my issue is or if just the tune will fix it.
Old 10-14-2010, 12:26 AM   #5
centeno711
Member#: 184638
2002 wrx wagon wrb
97 cummins 1ton 4x4
little more info,
the cut out is load realted, it will spin out to 6800 if its done very slowly but once it sense a little more load it shuts it down.
could this be due to the forged pistons tripping the knock sensor?
built 2.0 or 2.5 hybrid DausWRX Built Motor Discussion 3 05-04-2009 11:13 PM
Built 2.0 or 2.5 swap? superfast_wrx Built Motor Discussion 35 11-13-2008 08:36 PM
built 2.0? spoolinred Built Motor Discussion 6 06-13-2006 07:32 PM
attn gurus: wastegate issues on a built 2.0 peewee111 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-06-2005 07:24 PM
gauging interest in built 2.0 WRX motor BoostdScubaru Normally Aspirated Powertrain 1 10-19-2004 06:09 PM
