Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 10-13-2010, 12:47 AM   #1
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Default Exhuast leak problems
So I have a 2.5" prodrive exhaust from a '02 WRX. The muffler guy cut the flange off my stock exhaust and welded it to this one so it would bolt up. I have had to replace the exhaust donut twice now. Both times it almost falls out when I unbolt the midpipe and cat back flange. Its all rusted. So I popped for the OEM donut today. It looks like a lot better construction. I Bolted it all back up and still had a leak. So i took the spring and bolts off and used regular bolts to try to get a tighter fit. 3 broken bolts later and I still had a small exhaust leak. I realized its actually coming from a pin hole leak behind the midpipe side flange.
Can I use some sort of high temp RTV to seal this or do I need it re-welded?
(thinking before I replaced the donut) Would a pretty big exhaust leak at that flange cause any kind of drive-ability or performance issues?
Thank you.
Subyroo2.5 is offline   Reply With Quote
Old 10-13-2010, 10:12 AM   #2
suex
Member#: 243393
o6 impreza rs
Take it back to the guy who did it...he shouldn't charge you to fix his mistake, it should only take about 15mins..
suex is offline   Reply With Quote
Old 10-13-2010, 06:54 PM   #3
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
This! Yes you probably could use a sort of gasket maker compund but with so much road debris, grime, heat, stuff, there is no way it would last very long. He should fix it for free!
Will
GrimmSpeed is offline   Reply With Quote
Old 10-13-2010, 07:11 PM   #4
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
he should def fix this. idiot never should of used your oem midpipe flange in the first place. But make him fix it. if not. JB metal weld will seal it right up. hardware store carries it.
gingertooth is offline   Reply With Quote
Old 10-13-2010, 07:20 PM   #5
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
There could be a problem if your car is equipped with a rear o2 sensor, but don't worry about it too much. I've ran older Subarus with just headers and nothing else and didn't have a problem. I don't know if it would be different because your's is newer, I'm talking about running just headers with some old L series that I used to just toss around the yard.
Jessekrs123 is online now   Reply With Quote
Old 10-13-2010, 09:55 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Running without a rear 02, or even with a rear 02 and an exhaust leak is not ideal on an '07. bad rear 02 readings will cause some fueling issues on 06+ model years.
JB will last about 0.238747652 seconds once the cat reaches operating temps. The only way to fix this for more than a cpl mins is to touch up the weld.
Exhuast Leak??? redhat778 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-29-2004 07:56 PM
exhuast leak? matt888111 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-01-2004 09:12 PM
Would a exhuast leak hurt the motor? Night Kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-01-2002 11:53 PM
12.244 @ 111 with an exhuast leak! BYBYV8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 05-27-2002 07:51 PM
Pre-turbo exhuast leaks diagnosed by boost at idle? mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-22-2002 05:31 PM
