Old 10-13-2010, 01:52 PM   #1
royalnewjersey
Member#: 250954
2013 WRX Hatch
WRB - On Order
Default Weird "knocking" sound after driving
So, this might be a stupid question, so be gentle.
After driving my car for about 20 minutes last night I noticed a strange "knocking" / pinging sound coming from my engine bay. The knocks came about once every second with little clicks in between. I heard it after parking while the car was still running. Then I turned the car off and the sound continued.
I think that it sounds like the exhaust expanding / cooling. My old honda had a similar noise after driving for a bit, but this car seems to be much louder.
In any case, what causes this sound? I'm sure it's not harming my car, but I'm just sort of curious. I have a video of the sound, I'll post it once youtube finishes processing
Thanks guys.
royalnewjersey is offline   Reply With Quote
Old 10-13-2010, 02:03 PM   #2
royalnewjersey
Member#: 250954
2013 WRX Hatch
WRB - On Order
Old 10-13-2010, 03:02 PM   #3
RaineMan
Member#: 256727
2007 2.5I Wagon
Exhaust cooling... mine does the same thing. You are fine.
RaineMan is offline   Reply With Quote
Old 10-13-2010, 10:07 PM   #4
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
the pieces of metal that make up your exhaust and cat and shield your exhaust are made of different materials and heat up and cool at different rates. The thermal expansion/contraction will cause these pieces to move relative to eachother. since they are often attached via crimps/screws/bolts/etc they will build up stress until the force exceeds the strength of the connection and then they move in one quick motion. kinda like a bunch of little earthquakes on your exhaust.
RaceFaceXC is offline   Reply With Quote
Old 10-17-2010, 06:33 PM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
^ very eloquently put!!!!
Old 10-19-2010, 10:43 PM   #6
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
I thought I butchered it with a spoon. but thats why I turn wrenches instead of writing for a living. Thanks, though!
weird whirring or metallic sound after drive car on highway for a while cumechanic Transmission (AT/MT) & Driveline 1 11-20-2009 11:15 PM
Weird Engine Noise After Driving In Deep Snow wrxey General Community 6 02-07-2008 07:21 PM
Strange "knocking" sound at engine shut off SSsleeper96 Factory 2.5L Turbo Powertrain 0 03-13-2007 09:47 PM
Weird turbo sound after up-pipe install. JasoNeon Factory 2.0L Turbo Powertrain 4 11-02-2005 03:35 PM
weird "bhezzzz" sound after shifting jk147 Factory 2.0L Turbo Powertrain 3 07-07-2001 09:15 PM
Message Board Statistics All times are GMT -4. The time now is 06:28 PM.
