Old 10-14-2010, 11:44 AM   #1
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
Default OEM Fuel Hardlines
I need to know what size the factory hard lines are that run from the fuel tank to the engine bay. Im trying to buy the correct size push lock fitting that works with the factory hard lines. Russell Performance has the following sizes...
-6 AN male to 1/4" SAE quick-disconnect female
-6 AN male to 3/8" SAE quick-disconnect female
-6 AN male to 5/16" SAE quick-disconnect female
Picture of fitting in question...
StupidFastWagon is offline   Reply With Quote
Old 10-14-2010, 12:46 PM   #2
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
5/16" ~ 8mm
Got a caliper? You can just measure it to make sure!
engineerx is offline   Reply With Quote
Old 10-14-2010, 12:52 PM   #3
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I was under the impression they were 5/16" SAE; at least that's what the Aeromotive adapters to the stock lines are.
OrbitalEllipses is offline   Reply With Quote
Old 10-14-2010, 01:05 PM   #4
engineerx
Member#: 42614
0405 WRX STi/S2000
The question is what is the OEM line size. Subarus are made in Japan, they like metric overseas. I think only the big 3 here in the USA still use that crappy English unit system
for the fittings that will fit the 8mm OEM line: 5/16" = 0.3125" = 7.9375mm ~ 8mm
Old 10-15-2010, 03:17 AM   #5
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
Thanks for your help! I got to of them on the way
Old 03-13-2012, 09:39 AM   #6
BLACK02WAGON
Member#: 32574
2012 Nissan GTR BE
Vibrant Red
Did they work?
BLACK02WAGON is offline   Reply With Quote
FS : VF52, OEM Top Mount, OEM Fuel Injectors, OEM Catback, Kartboy Short Throw + Bushings silver_surfer_rex MWSOC Private Classifieds 33 09-02-2011 10:19 AM
WTB: 04+ STI Charcol Canister Bracket, Fuel controller harness, Fuel hardline bstoehr83 Private 'Wanted' Classifieds 1 07-13-2009 02:02 PM
04 WRX OEM Fuel Rail (Good for 02-03 WRX fuel smell TSB fix) Cation Engine/Power/Exhaust 8 07-01-2007 11:50 AM
WTB: OEM Fuel Rails/Fuel Pipes Austin Private 'Wanted' Classifieds 5 03-02-2004 03:52 PM
WTB: OEM Fuel Rails/Fuel Pipes Austin North West Impreza Club Forum -- NWIC 1 02-29-2004 10:26 PM
