#1 |
Vendor Sales Rating: (2)
Member#: 146435
South East
AEM Digital Gauges offer quality, accuracy, looks and value! These gauges are some of the very best on the market and we use them on a daily basis in the shop in everything from Shelby Cobra's to Caterham Super Lite's! Check out what we have to offer!
AEM Digit Oil Pressure Gauge: ![]() The AEM 150PSI Oil Pressure Gauge has a bright LED display that shows oil pressure in 1 PSI increments, and a sweeping LED "needle" that lines the edge and changes color as oil pressure changes from 0 to 150. One of the most vital things to know about your engine is it's oil pressure - and now you'll be able to see and log to the exact PSI. Each gauge includes interchangable silver and black bezels and black and white faceplates to personalize the look of your gauge - it's like having 4 gauges in 1! AEM Digital Temp Gauge: (Fuel / Oil / Water) The AEM Digital Coolant Temperature Gauge has a bright LED display that shows temperature in 1 degree increments, and a sweeping LED "needle" that lines the edge and changes color as temperature changes from 100 to 300. We have found OEM gauges usually read 3 things - cold, warmed up, and "shut it off" with the last sometimes coming too late. Now you'll be able to see and log temperature to the exact degree. Each gauge includes interchangable silver and black bezels and black and white faceplates to personalize the look of your gauge - it's like having 4 gauges in 1! Each Gauge Kit comes complete with face plates to display Water, Trans or Oil Temp. Simply apply the face for what you will be monitoring. Kit includes AEM Brass Sensor, Reads from 100-300* F and offers a 0-5v outlet signal for loggers and most engine management systems. AEM Digital Boost Gauge: (To 35psi) ![]() The AEM 35PSI Boost Gauge gives an easy to read numerical digital readout that increments every 1 PSI to anyone wanting to know exactly how much boost they are running. All AEM digital gauges have the digital readout in the center, and sweeping LED "needle" that lines the edge of the gauge that changes colors as boost changes. The digital readout will automatically increase and decrease in intensity due to the built in ambient light sensing photocell. A 50 PSIa brass sensor gives the gauge its accuracy. Each gauge comes with interchangeable black & silver bezels and black and white gauge faceplates for multiple color combinations. AEM Digit Volt Gauge: (8-18v) ![]() The AEM Volt Gauge has a bright LED display that shows voltage in .1 increments, and a sweeping LED "needle" that lines the edge and changes color as voltage changes from 8 to 18V. Most charging systems will slowly start to decrease their output, so you will be driving with a failing system before the light on the dash comes on. With a real voltage gauge you'll know there's a problem before you go to start the car - or worse - get stranded on the track on away from home. Each gauge includes interchangable silver and black bezels and black and white faceplates to personalize the look of your gauge - it's like having 4 gauges in 1! AEM Tru-Boost Controller & Gauge: ![]() AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS! AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 PSIg pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 PSIa boost sensor for high boost applications (sold separately). AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks. -No external interface required for programming! -Complete system includes harness, boost hose, on-board 29 PSIg pressure sensor (external 75 PSIa optional), boost solenoid, gauge display and all necessary fittings -Quick connect technology eases the installation process -Two user selectable boost settings with peak boost memory -Scramble boost setting allows user to momentarily change boost levels -User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost -User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display -One (1) low-side output included for warning lights Please let us know if you have any questions about these gauges or any other quality products by AEM!
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [FONT=Tahoma][SIZE=3] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B][B][COLOR=Blue][FONT=Verdana][SIZE=3] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. AIM: aimformarti / To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Check us out on To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/SIZE][/FONT][SIZE=3] 813-961-0609 x. 1003 [/SIZE][/COLOR][/B][/B] [/SIZE][/FONT] Last edited by S&R Performance; 10-19-2010 at 03:18 PM. |
#2 |
Member#: 146435
South East
still have great deals on all AEM Gauges!
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [FONT=Tahoma][SIZE=3] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B][B][COLOR=Blue][FONT=Verdana][SIZE=3] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. AIM: aimformarti / To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Check us out on To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/SIZE][/FONT][SIZE=3] 813-961-0609 x. 1003 [/SIZE][/COLOR][/B][/B] [/SIZE][/FONT] |
#3 |
Member#: 146435
South East
Please let us know how we can earn your business. =)
__________________
| Thread Tools | |
| Display Modes | |
| FS : AEM tru-boost & AFR gauge & 38mm EWG for sale(pics added) | htowns_finest | TXIC Private Classifieds | 13 | 01-19-2011 03:38 PM |
| FS : NEW IN BOX - AEM Uego WB & TruBoost Guage/Controller | devlish | Interior/Dressup/Audio & Security | 4 | 12-06-2010 05:03 PM |
| FS : Defi White Racer EGT Gauge & install tools | DUB03REX | Interior/Dressup/Audio & Security | 11 | 11-13-2010 10:30 PM |
| FS : AEM Power 30-4100:AEM Power Digital Wideband Air/Fuel UEGO Gauge | valetudospang | Engine/Power/Exhaust | 3 | 07-13-2010 08:37 PM |
| Complete Tuning Tools - AEM / Innovate / Turbosmart / Haltech / Aquamist & More! | Built Industries | Engine Management | 11 | 01-15-2010 12:02 PM |
