#1 |
Member#: 50895
NESIC
Vehicle:. www.48hrs.info donation chairman |
i have been searching for a while now and either my search skills suck or the info isnt out there (im sure its my skills)
long story short wrx with ej257 sb, the 2.0 heads are bad... if putting on sti heads with avcs how do you correctly eliminate avcs? what cam gears/cams/things do you need to do? this car is running an ecutek tuned oem ecu so adding the avcs isnt an option. better off to get a a used set of wrx heads? thanks ted
#2 |
Member#: 166324
NESIC
Vehicle:02 V8 Spec C 03 V9 Limited 2013 Legacy |
quicker and easier to use wrx heads BUT if you want to use the sti ones. you need to plug the avc holes in the sti cams and reuse your wrx cam gears.
there might be more to it than just that so do a quick search and you will find numerous threads with accurate information on this topic. |
#3 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, 1,000,000 whp 2 aw tq |
Ill trade you straight up for the heads.
#4 |
Member#: 50895
NESIC
#5 |
Member#: 171471
Vehicle:2002 35r wrx Silver |
You need to.. tap and plug the avcs holes in the cams, you need to leave the avcs solenoids in the holes, these allow oil to the front cam journals. You can run your wrx cam gears, you may need to buy a Cosworth cam sensor mount, unless you have early STI heads, they sometimes have the mount from subaru... That is everything, but I would just get wrx heads...
#6 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
was this a hybrid build on a 16bit ecu?
#7 | |
Member#: 50895
NESIC
its not my car although i am doing the labor in swapping out the ej257 sb that has a spun rod bearing and found the heads are bad. its originally an 02 wrx, whatever ecu that is. |
#8 |
Member#: 108089
you can run the whole setup with the 2.5l and just get a cam angle sensor bracket.
no need to fiddle with anything else. |
#9 |
Member#: 149262
Vehicle:2003 03WRXw6sp/05FXT PSM |
So what did you end up doing????
#10 |
Member#: 50895
NESIC
"I" havent done anything yet. waiting for the owner of the car to figure out what he wants to do.
as i said in the OP, long story short. i saved you all the gorey details about the car and what it has been thru. |
| Thread Tools | |
| Display Modes | |
| JDM STi pinks on a bugeyes. What is needed to make them work? | Dizmal | Brakes, Steering & Suspension | 4 | 01-29-2006 10:07 PM |
| These TomTom commercials are what is going to make me finally break my TV. | eurojax | Off-Topic | 11 | 10-21-2005 03:40 PM |
| I just thought of what Subaru needs to make... | Corn-Picker | News & Rumors | 6 | 05-01-2003 05:06 PM |
| What is used to make a front grill? | IMPREZA GUY | Interior & Exterior Modification | 5 | 07-14-2001 07:16 PM |
| What is needed to make complete setup.... | Rubasu | Brakes, Steering & Suspension | 7 | 11-18-2000 12:13 AM |
