Old 10-14-2010, 06:52 PM   #1
lbizboy
Member#: 235486
Default 07 STI swap into 04 wrx wagon
Currently im installing a 2007 STI longblock into my 2004 wrx wagon. First problem im having is seperating the trans from the engine. All eight fasteners are out and the clutch shaft has been removed. Trans is jacked up with a jack and im not even getting a c-hair of gap. Attempted to hammer/chisel but mucked up metal too much. Any tips on where I can pry etc etc. If not might end up pulling engine and trans together. Second problem im having is it appears the AVCS solenoids on each head will interfere with the wrx metal bracket that goes on both heads/manifolds. Curious if anyone has done this swap and has had a problem like this. Also the PCV setup is different on the 07. The 07 has 4 ports(2 on each head/valve cover), the 04 only appears to have it on the passenger side head. Possibly thinking of capping off two of the ports and routing the other ports to a catch can. Any insight would be awesome. thank you
lbizboy is offline   Reply With Quote
Old 10-15-2010, 11:08 AM   #2
tyroorosaurswrx
Member#: 245440
08 Impreza WRX
Satin White Pearl
Use some PB Blaster on the ears where the dowl pins are located also get a very large prybar like 5 ft in length try tapping and heating the ears as well dont hear them to hot or they will crack/melt. and start pying it took like 25 min of this to get mine separated when i was going my clutch.
tyroorosaurswrx is offline   Reply With Quote
Old 10-15-2010, 12:15 PM   #3
Yint
Member#: 199751
2002 Impreza TSX
Savanna Green
PB and tapping the pins is a good idea, I use a 1" putty knife to break the pins free, and then workthe top wit some custom ground pry bars, screw drivers also work, just don't use too much force.
Yint is offline   Reply With Quote
Old 10-15-2010, 01:17 PM   #4
lbizboy
Member#: 235486
Ok success on that but now im running into problems with the 07 sti longblock working. Theirs no casting spot for the cam sensor on the drivers side head. Also their is a extra port on each head for pcv
Full V7 STi drivetrain into 04 WRX wagon! big_adventure Subaru Conversions 113 12-08-2012 03:53 AM
Help needed with 07 sti swap into 04 wagon lbizboy Mid Atlantic Impreza Club -- MAIC 17 10-18-2010 10:18 PM
05 STI swap into 04 WRX Wagon. HELP! pismobeachrider25 Built Motor Discussion 6 04-12-2010 09:58 AM
2007 STi swapped into 04 WRX, poss boost leak? Samurai_jim Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-10-2009 09:01 AM
sti tranny into 04 wrx wagon? sakebomb Subaru Conversions 1 07-08-2004 02:34 PM
