Old 10-14-2010, 07:10 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Manley piston rings - which way is up?
Sounds dumb, but the instruction give direction for piston rings with a beveled inner edge or a dot. My top ring only has a beveled outer edge... does anyone know which way it should be installed?
Bad Noodle is offline   Reply With Quote
Old 10-15-2010, 06:44 AM   #2
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
morning bump
Old 10-15-2010, 08:54 AM   #3
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
Dont quote me on this....
edit:
SEE EDIT POST #6
xrocket21 is offline   Reply With Quote
Old 10-15-2010, 11:44 AM   #4
jaimejrivera
Member#: 112943
Bevel down
jaimejrivera is offline   Reply With Quote
Old 10-15-2010, 01:56 PM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Cool, thanks
Old 10-16-2010, 01:10 PM   #6
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
WAIT
we were wrong
in my CP piston "installation specification sheet" it shows the bevel goes toward the head, and the flat part goes toward the crankcase!!!!
http://www.cp-carrillo.com/LinkClick...Ls%3D&tabid=83
Old 10-16-2010, 09:04 PM   #7
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I think that illustration is for the second ring rather than the top ring. S oif the top ring is beveled down, I would think that it would created a better seal with the combustion chamber. If the second ring is beveled up, then the square edge would scrape off any oil that gets past theoil ring. What do you guys think?
Originally Posted by xrocket21 View Post
WAIT
we were wrong
Old 10-17-2010, 10:35 AM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Here's the best pic I can get of the piston ring profile:
Old 10-18-2010, 09:43 AM   #9
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
bump anyone? It looks like they could be installed either way
Old 10-18-2010, 10:29 AM   #10
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
^^^ atleast in the pic it looks like top and bottom outside edges are beveled.
rexworx is offline   Reply With Quote
Old 10-18-2010, 05:24 PM   #11
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
+1, try a macro setting on your camera for a better shot.
340Duster is offline   Reply With Quote
Old 10-18-2010, 06:56 PM   #12
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Here's the best i could do:
I also called manley and they said if there are no markings, they can go either way
Old 10-19-2010, 08:17 AM   #13
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
I dont even see a bevel on that ring
Old 10-19-2010, 11:10 AM   #14
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
There really isn't. The first ring I worked gave off more of a reflection from the chrome liner on one side than the other so I assumed that was form it being beveled. I couldn't tell the difference between sides in the rest of the rings.
Old 10-19-2010, 12:14 PM   #15
IAG Performance
Member#: 158123
If there is a dot on either ring, they face up. If there are no markings, the bevel goes up on the top ring and the bevel goes down on the second ring. Hope that helps.
Regards,
JJ
IAG Performance is offline   Reply With Quote
Old 10-20-2010, 09:44 PM   #16
RacePartsGuy
Member#: 246644
2008 Forester XT STI
CGM-360HP/365TQ
Default Manley Rings
Sorry I didn't see this sooner, JJ is correct If they have dots , dot goes up.
No dots, Bevel Up on Top ring, Bevel down on bottom ring.
RPG
RacePartsGuy is offline   Reply With Quote
Old 10-21-2010, 06:44 AM   #17
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
What if there is no dot? I know it can be hard to see especially with the matte black surface. That was the case with the second ring. So I took a sharpie and colored the top of the ring and the dot showed up no prob. Did the same thing for the top ring, and still no dot. Looked at it against the light and it was smooth, no indented dot.
Old 06-27-2011, 02:55 AM   #18
Serkan
Member#: 180514
2004 Sti
The Manley's first and second rings have no bevels in the outer edge (cylinder wall) but has slight bevel in inner edges (piston ring groove)
The second ring (matte black, cast) has a dot marked so it is looking up.
But what about the top ring ? It has no markings but has a bevel in the inner edge. Should it be looking up or down ?
Also why didn't Manley put bevels in the outer edges ?
This is the first ring, you can see the inner bevel :
This is the dot on the second ring:
Serkan is offline   Reply With Quote
Old 06-28-2011, 06:50 PM   #19
stu
Member#: 25768
35R bugeye
Slowbaru
call total seal in phx az they supply the rings they would know the answer.
stu is offline   Reply With Quote
Cobb (JE) offset pistons - which way is up? 1GR8WRX Built Motor Discussion 15 02-28-2008 06:41 PM
eibach pro-kit, which way is up whitesubie Brakes, Steering & Suspension 0 04-03-2006 02:35 AM
Crush Washer - Which Way is Up DriveFast Service & Maintenance 11 09-15-2005 01:22 PM
brain fart- turning abc on utec which way is more/less boost M32WRXin3seconds Engine Management & Tuning 3 09-19-2003 12:04 AM
Which way is better to get rid of understeer? LiquidForce Brakes, Steering & Suspension 23 09-19-2002 01:03 AM
