Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-14-2010, 08:35 PM   #1
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
Default Phase I 2.5 things to look for?
well, now that I have gone from the indestructible SOHC 1.8L to the DOHC 2.5, besides head gaskets, what should i look out for? and If i get on the throttle once in a while, will this make my HG's go sooner? the car has 209k miles, so am I safe to assume the HG's either won't go or have already been done? I love the car, but i don't want to romp on it and look back to see a cloud of white smoke.
Tbird Man is offline   Reply With Quote
Old 10-15-2010, 04:26 PM   #2
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
bump? anyone?
Old 10-15-2010, 04:45 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Other than the headgaskets, you'll want to listen carefully for piston slap and slight rod knock. Piston slap is almost inevitable given the age, and rod knock wouldn't be surprising to hear about.
Other areas of concern would be:
Backing plate of the oil pump, check it for screws that have backed out or are just loose.
Oil separator plate on the back, check it for leaks and replace with updated steel piece.
Timing belt tensioner, check it for proper operation along with all the idlers.
Water pump, check it for leaks or other signs of impending doom.
Replace any or all of these items if there is any doubt to the condition.
Jay
Old 10-16-2010, 03:57 PM   #4
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
any threads about these?
feint05 is offline   Reply With Quote
02 2.5, what to look for? WayBack Normally Aspirated Powertrain 7 03-30-2008 02:42 PM
Top 5 things to look for/at when buying a <$3k car? -=C=- Off-Topic 46 02-20-2007 11:54 PM
Going to look at a few Outbacks - Things to look for travmn Outback Forum 0 10-05-2004 12:40 PM
Things to look for and to expect Han Solo Newbies & FAQs 11 11-24-2003 03:43 AM
('93-'01) Things to look for before buying? XBD Impreza Forum 1 07-02-2001 11:32 PM
