Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-14-2010, 10:47 PM   #1
Malaka628
Member#: 167745
2007 WRX TR
Crystal Grey Metallic
Default What do you guys think about this part list?
So I need to rebuild my motor. What do you think of these parts?
Eagle rods with upgraded rod bolts
ARP head studs
ARP main studs
Gates timing kit
Full OEM gasket kit
OEM oil pump
ACL race series main and rod bearing
Crawford air oil separator
Wiseco or Mahle 100 mm pistons
Which of the 2 pistons do you guys recommend? And do you think it is worth getting the ARP main studs for 345?
Power Mods
Blouch TD05 20g 8cm^2
Turbo XS 4" Downpipe
P & L 3" Race Catback
P & L High Flow Intake (Powder Coated Red)
P & L 38mm EWG Kit (Modified Turbo XS Up-pipe with Tial Wastegate)
P & L Front Mount Intercooler (Piping Powder Coated Red with Black Core)
Tial BOV
Samco Turbo Inlet
Cobb Access Port
T.G.V. Delete
HOA 3 Port Boost Control Selenoid
Deatschwerks 1000cc Injectors
Walbro 255lph Fuel Pump
Thanks, Greg
Malaka628 is offline   Reply With Quote
Old 10-15-2010, 01:48 AM   #2
bugeye1257
Member#: 188598
sounds pretty good to me! you might want to consider a ej25 11mm oil pump to the list and a killer b setup.
what are your goals with the car drag, autox, ect??
what kind of whp do you want to hit?
how much are you looking to spend?
andrew
bugeye1257 is offline   Reply With Quote
Old 10-15-2010, 02:32 AM   #3
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Id get td06 20gxt turbo 8cm^ hotside
07wrx84 is offline   Reply With Quote
Old 10-15-2010, 12:54 PM   #4
Malaka628
Member#: 167745
2007 WRX TR
I want to get the car to about 400-450 whp. I do like to go to the drag strip, but this coming year I want to get into racing at a track. I'm looking to spend about 2500-3000 on parts.
After I get the engine built, I am I looking to get a new turbo.
Old 10-15-2010, 04:59 PM   #5
slovak
Member#: 168922
I have not heard bad things about either mahle or manley, but I got manley pistons in my car. The reason I went with manley id bc i talked to a manley rep at a nhra event and told me that their pistons have coating on the skirts.
slovak is offline   Reply With Quote
What do you guys think about this??? quintera7 Hawaii Impreza Club Forum -- HIIC 20 10-08-2002 01:28 AM
('93-'01) What do you guys think about this 97 L I might buy? Thoughts Welcome Ethon Impreza Forum 8 07-30-2002 12:05 PM
What do you guys think about this set up SkypatCorbin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-28-2002 05:51 PM
What do you guys think about this? Lix Normally Aspirated Powertrain 4 02-13-2001 04:51 PM
what do you guys think about this swaybar setup bill harvey New England Impreza Club Forum -- NESIC 4 08-27-2000 06:17 PM
