Old 10-15-2010, 07:44 AM   #1
gallo-lo
Member#: 258755
2003 baja.
Default code p0438
I have check engine light on, and the scan tool is showin me p0438 code fan performance, has any1 got the issue, and I also see the temp risen.
gallo-lo is offline   Reply With Quote
Old 10-15-2010, 09:27 PM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
None of the Subaru manuals I have list P0438 as a defined code. Try a different scan tool.
Unless you kicked the numbers. They do define P0483 Fan Rationality Check. Basically it means that one or both of the fans aren't turning as expected. Let the car idle. Check the coolant temperature by the readout from the ECU (not the gauge on the dash). By the time the coolant temp hits 212F, both fans should be turning at full speed.
Old 10-18-2010, 06:55 AM   #3
gallo-lo
Member#: 258755
2003 baja.
Ok I will chek it out , drives me nuts when it happens. Thanks !
OBD-II P, B, C codes, and Subaru OEM codes Julian Normally Aspirated Powertrain 1 11-05-2013 11:03 PM
codes,codes and more codes grinch77 Newbies & FAQs 8 01-07-2009 05:27 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 01:40 AM
attn paint code experts:volk/rota paint codes MixeD_MenacE Interior & Exterior Modification 0 05-29-2003 06:04 PM
Code Red and Code Red II worm Luftyone Bay Area Impreza Club Forum -- BAIC 4 08-07-2001 11:14 PM
