Welcome to the North American Subaru Impreza Owners Club Friday August 29, 2014
Old 06-27-2002, 08:14 PM   #1
adamsrs
Member#: 3768
Unhappy P107 What does this code mean!! HELP!
P170 OBD2 Code:
Fuel Trim Malfunction (Bank 1)
What does this mean? Which bank is Bank 1? What could be causing this? Any ifo will help! i also have 4 Misfire codes......but this is because i am running an EJ22t shortblock with EJ25 Heads... Any ideas? Thanks! Stock ECU, with a JC sports TC2, and stock Injectors and SARD Adjustable FPR....thanks!
adamsrs
adamsrs is offline   Reply With Quote
Old 06-27-2002, 08:15 PM   #2
adamsrs
Member#: 3768
Mods...please change the title for me! i meant to say Code P170.....thanks!
adamsrs
Old 06-27-2002, 09:52 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I'll bet you a cookie one of your O2 sensors is actually the problem- ie: fuel trim is off because the ECU isn't reading air/fuel mixture properly .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.deniedmywarranty.org
Old 06-27-2002, 11:06 PM   #4
adamsrs
Member#: 3768
Ok, but how do i find out if that is indeed the case??? And would this explain my misfires? And how would this only affect one bank of injectors......and which bank is Bank one?
adamsrs
Old 07-03-2002, 09:59 PM   #5
adamsrs
Member#: 3768
Bump! Anyone! Still searching!!!!!
adamsrs
Old 07-03-2002, 11:18 PM   #6
Hondaslayer
Purified Dick
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Adam Is there anyway you can get the Front O2 sensor voltage? also the correction rate could help. ( the dealer can get this just tell tehm that you need the freeze frame data)
Old 07-03-2002, 11:42 PM   #7
adamsrs
Member#: 3768
WIll the dealer charge me to do this? WHat do you mean the correction rate...sorry about my lack of knowledge! Thanks!
adamsrs
Old 07-04-2002, 12:17 AM   #8
Hondaslayer
Purified Dick
Member#: 4562
1995 Legacy LSi
Not sure if the dealer will charge you or not. Depends on your relationship with them. Maybe you can offer a ride when its done. The correction rate is how much the ecm has to correct the A/F ratio. It should not be higher than 25%
Old 07-04-2002, 12:28 AM   #9
adamsrs
Member#: 3768
Question
Yeah i am in good with my service dept. so not more than 25% eh? Ok, and how long does this take? Can they check the voltage of the o2 sensor there too? WHat should the voltage be? I really appreciate your help!
adamsrs
Old 07-04-2002, 12:50 PM   #10
Hondaslayer
Purified Dick
Member#: 4562
1995 Legacy LSi
Takes about five minutes to get the info. They probably can even tell you if the sensor is fried or not.
Old 07-04-2002, 04:56 PM   #11
adamsrs
Member#: 3768
Thanks!
adamsrs
What does this error mean? phantom Off-Topic 12 02-29-2004 03:49 PM
What does this picture mean to you? rex_ruthor Off-Topic 25 10-15-2003 08:46 PM
What does this pic mean? Hyper Off-Topic 8 09-25-2003 08:23 PM
What does this gesture mean? rspoel64 Off-Topic 20 07-25-2003 11:47 PM
what does this noise mean? IMPREZAmike Normally Aspirated Powertrain 6 01-28-2001 12:31 AM
