Old 10-16-2010, 08:28 AM   #1
Denali
Member#: 81604
Default leaking v-band
not really sure where to post this but w/e.. my turbo has a vband connection to the downpipe, i think it uses a vibrant clamp. with the clamp torqued to proper spec it was leaking from between one of the gaps in the clamping area, got the exhaust nice and hot then tightened as much as i dared.. still leaks but not as bad. should i just buy another clamp and tighten this one as much as it will take till the leak stops .. or the clamp breaks. remove the exhaust and grind any imperfections of flanges, crush the clamp a bit or maybe some of that copper exhaust rtv?
Denali is offline   Reply With Quote
Old 10-16-2010, 08:49 AM   #2
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
i suggest you clean the mating surfaces of the v-band flanges, get the corners cleaned up well. if its a new addition and your finding the leak now, it was welded without the flanges being correctly mated. or lastly, if it is just the slightest bit of black you see, dont worry about it as it is post turbo.
nhsilversti is offline   Reply With Quote
Old 10-24-2010, 06:09 PM   #3
Denali
Member#: 81604
heres a pic the turbo's flange is stock from garett, the downpipe is part of the turbo kit i will try taking it apart and checking for anything
there is a little bit of black on the top that i am not worried about, but you can see the wastegate looks to have quite a bit of exhaust crap on it... this it from 250km worth of driving on low boost just breaking in and slowly tuning the motor
Old 10-24-2010, 06:11 PM   #4
MartinSTi05
Member#: 145145
2006 wrx STi
Take the turbo flange and the DP flange and lap them on a sheet of glass. They will seal like a million bucks. I also use a VERY small amount of permatex ultra copper on the sealing face.
MartinSTi05 is offline   Reply With Quote
Old 10-24-2010, 06:13 PM   #5
Denali
Member#: 81604
by lap i guess you mean sand?
Old 10-24-2010, 06:26 PM   #6
MartinSTi05
Member#: 145145
2006 wrx STi
You could use a flat table with sand papaer, or use a pane of glass and lapping compound. Just make sure you use a fig8 motion to ensure the surfaces stay flat.
Old 11-20-2010, 12:45 PM   #7
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
take down pipe off, clean flanges, spray wd40 on clamp and tight it down.
The design of the flange is to retarder its just 2 flat flanges lay on each other!
! There should be a groove like on the tial turbo to make it 100% leak free!
Bariga is offline   Reply With Quote
Old 12-11-2010, 06:34 AM   #8
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
methaddict is offline   Reply With Quote
Old 12-12-2010, 12:49 AM   #9
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
tell me wtf is the point of vband if its steal leaks lol
Music Afficianados: Dream Band (like a dream team, but with band geeks) Asinine Off-Topic 9 02-07-2005 04:59 PM
Bands covering other Bands Songs... Remy E. LeBeau Off-Topic 49 05-30-2003 04:29 AM
The Official Support Your Local Band/Friends Band Thread Unit 91 Off-Topic 91 02-18-2003 01:30 AM
Wide band vs narrow band O2 mitch808 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 06-12-2002 04:13 PM
How to adjust 4EAT Band Brake/Brake Band? CRZ_MSL Normally Aspirated Powertrain 7 01-16-2001 07:40 PM
